Realtime video
Results 1 to 38 of 38
Thread: Realtime video
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Ah Ive almost got it now. I downloaded MPLAB IDE v7.22 and loaded up the .asm file that picbasic pro compiled. I started the stopwatch and ran the program with MPLAB SIM as the tool but it just ends up saying "Time (mSec) 3.276800". How can I use it to measure the time between two points in my program?
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    My TV is NTSC.
    Italy
    The link below is about PAL and the main power frequency is 50 Hz.
    http://www.rickard.gunee.com/project.../pic/howto.php
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I based my code on the ASM example given in that link. Since both PAL and NTSC use the same signal structure it should work on my TV. I dont have a vertical synch inserted so it just repeats the same thing (synch, pause, gray, white, gray) over and over again.
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I followed the Spark Fun MPLAB Stopwatch tutorial and I understand that now but I can not get it to work with my program. I have started a new project and imported the .asm file created by picbasic pro but when I click build it gives me tons of errors. Shouldnt the .asm file be correct?
    You have to download the PBP MPLAB plugin
    http://www.microengineeringlabs.com/support/mplab.htm
    Then you don't need to use the asm file. Start a new project with the wizard, choose PBP as toolsuite, and set your breakpoint directly in your PBP code lines. That's it
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I feel like the biggest noob on the face of the earth.
    Gold stars for everyone.
    EDIT:
    ALMOST! Im so close. Only one thing left. When I hit "Build" I get errors that didn't appear in MicroCode Studio. Most of them are like this:
    Error[105] C:\PICBASIC PRO\18F252.INC 19 : Cannot open file (Include File "P18F252.INC" not found)
    Error[113] C:\PROGRAM FILES\MECANIQUE\MCS\VIDEO\VIDEO_TEST.ASM 86 : Symbol not previously defined (PORTB)
    Error[113] C:\PROGRAM FILES\MECANIQUE\MCS\VIDEO\VIDEO_TEST.ASM 88 : Symbol not previously defined (PORTC)
    Error[113] C:\PROGRAM FILES\MECANIQUE\MCS\VIDEO\VIDEO_TEST.ASM 90 : Symbol not previously defined (TRISB)
    Error[113] C:\PROGRAM FILES\MECANIQUE\MCS\VIDEO\VIDEO_TEST.ASM 92 : Symbol not previously defined (TRISC)
  1. OT: Cell Phone Video Screen Design
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 21st February 2009, 02:30
  2. How to switch between video inputs
    Last Post: - 5th May 2008, 13:27
  3. Video system
    By Christopher4187 in forum Off Topic
    Last Post: - 27th April 2008, 17:49
  4. Composite NTSC Video
    By mcglacy in forum Off Topic
    Last Post: - 3rd March 2008, 11:29
  5. RF video reciever - digital tuning
    By RYTECH in forum Schematics
    Last Post: - 15th September 2006, 01:05
