10f206 Blink led
Results 1 to 3 of 3
    Dec 2004
    Scarborough UK
    Angry 10f206 Blink led
    Hi all
    Anyone know how to get a 10f206 going ?.
    i tried a simple blink prog to start but cant even get that to run, i've looked at datasheet and tried all sorts of option_reg and trisgpio combinations but the damn thing just sits there doing nothing, please help if you can.
    TRISIO = %11111101
    OPTION_REG = %00000000
    High GPIO.1
    Pause 50
    Low GPIO.1
    Pause 50
    GoTo main
    Reading the datasheet & understanding it are two different things.
    i used those few times in the past without too much problems. I can't check everything where i'm right now but as i remind, you have to disable the analog comparator with CMCON0 register if my memory is good.
    try this line at the top of your code... but double check in the datasheet before... i can be wrong here... as often...
    CMCON0.3=0
    or
    CMCON0=0
    i can't remind how to exactly... but the first one sounds familiar to me... anyways let us know
    Look for your default config fuses... if i'm right MCLR= enable so MCLR should check that.
    HTH
    Dec 2004
    Scarborough UK
    Smile 10f206 blink led
    Hi Mister_e
    It worked first go, THANK YOU !!.
    It was the CMCON0=0.
    CMCON0=0
    High GPIO.1
    Pause 30
    Low GPIO.1
    Pause 30
    GoTo main
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  2. Novice 16F83A BLINK LED program help
    By owali in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 05:02
  3. LCD will not start
  4. Using HPWM to blink an LED?
    Last Post: - 7th August 2006, 00:48
  5. Can't get a 12F629 to blink a led
    By Sharky in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 11:28
