HELP''''line foolowing module with 16F84A'''''
Results 1 to 3 of 3
    INaPickle's Avatar
    INaPickle Guest
    Red face Programming the 16F84A
    Go to Square 1 Electronics (http://www.sq-1.com/), purchase his book "Easy Microcontrollin" or MeLabs sells his books as well, so you don't have to even leave the site. In my opinion this book is a great place to start to learn about PIC's especially the 16F84A. It seems that there is more to these chips than just plug and play Back up, learn to just blink an LED, then controll the LED with a simple sensor (switch), then fool around with controlling one motor, from there you can combine the modules. Before you know it you'll have your own robot design and be able to build upon it. I myself have just started on this learning curve, and believe me when I say "Take Baby steps"! The other books by David are great as well, but you need this first one to get a good feel for the PIC environment. Each PIC is different as well, so you'll need the data sheets (or should they be called books?) to go along with the PIC's you use. Good luck, the circuit isn't bad and could be simplified further, think about it.
    INaPickle
    nechatronics's Avatar
    nechatronics Guest
    Talking
    Hımmm thanks for your interest in this subject, i used the c program language which can be powerfull and very easy (I think )my first robot is very cude
    Then have you got a diffirent curcuit for kind of robot.
  1. Version Control
    Last Post: - 16th October 2011, 18:12
  2. Replies: 1
    Last Post: - 27th July 2008, 07:14
  3. Vinculum VNC1L Vdrive2 module problems
    By the_virus in forum Serial
    Last Post: - 21st July 2008, 08:01
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 09:51
  5. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 08:14
