Go to Square 1 Electronics (http://www.sq-1.com/), purchase his book "Easy Microcontrollin" or MeLabs sells his books as well, so you don't have to even leave the site. In my opinion this book is a great place to start to learn about PIC's especially the 16F84A. It seems that there is more to these chips than just plug and play Back up, learn to just blink an LED, then controll the LED with a simple sensor (switch), then fool around with controlling one motor, from there you can combine the modules. Before you know it you'll have your own robot design and be able to build upon it. I myself have just started on this learning curve, and believe me when I say "Take Baby steps"! The other books by David are great as well, but you need this first one to get a good feel for the PIC environment. Each PIC is different as well, so you'll need the data sheets (or should they be called books?) to go along with the PIC's you use. Good luck, the circuit isn't bad and could be simplified further, think about it.
INaPickle
