max7221 cascade mode
Results 1 to 2 of 2
    lutherblissett's Avatar
    lutherblissett Guest
    Default max7221 cascade mode
    if i connect two max7221 in cascade mode(dout of the first on din of the second)how i can switch between the two?
    lutherblissett, What you would do is commect them in series as you have but then use a seprate I/O line for each going ti the chip select line. The shift register is pass thru so you would just send the first 16 followed by the second 16 bits then strobe the chip select lines on each of the devices. The data is only read form the registers of each of the 7221's when the chip select line is toggled.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 08:01
  3. Using MAX7221
    Last Post: - 14th January 2009, 05:48
  4. Oscillator stops when touching with a wire
    By Wilbert Ingels in forum mel PIC BASIC Pro
    Last Post: - 25th April 2008, 08:51
  5. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 11:18
