AT/PS2 Keybord - PIC Interface?
Results 1 to 40 of 74
    Delaware
    Default PS/2 to 18F4620 timing issues isolated to "putkey" routine
    Quote Originally Posted by BobPigford View Post
    Thank you sougata,
    I did allow enough time for the keyboard to start. I see the LEDs flash, so I think that is not the issue.
    I will follow you suggestion and look into the buffer situation. I will also order a 40mhz oscillator just to be sure.
    I will report back on my progress.
    Thank you again,
    Bob Pigford
    Newark, Delaware, USA
    I just isolated the issue! If I eliminate any output going TO the keyboard, everything works just fine! I disabled the "putkey" routine buy placing a "RETURN" immediately after the beginning of the routine.
    Even with the internal oscillator at 8mhz, it all works very well (even with "TOcntDLY set back to 10)! I can live without seeing the LEDs on the keyboard for now. When my 40mhz oscillator arrives, it will try it again and report back.
    Bob
    Feb 2005
    Kolkata-India
    Default Use HSPLL
    Every PIC18 has got a x4 HSPLL oscillator mode. So you can use an external 10MHz crystal to effectively get 40 MHz Fosc. For internal 8MHz you need to configure osccon to enable HSPLL and get 8 x 4 = 32MHz from the internal oscillator.
    Sougata
    Delaware
    Default Will try HSPLL
    Quote Originally Posted by sougata View Post
    Thank you Sougata. I will give this a try and report back. And thank you for teaching me about HSPLL.
    Bob
  1. MXcom "C-BUS" interface to PIC question
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 1st May 2014, 03:59
  2. Interface a pic with a Iphone/Itouch
    By Luckyborg in forum General
    Last Post: - 6th May 2009, 16:02
  3. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 05:21
  4. USB Interface using PIC
    Last Post: - 22nd May 2006, 16:04
