Hello!
I have implemented the wonderful code PS/2 keyboard code from mytekcontrols in my PIC18F4620. It will only work if I set
TOcntDLY CON to a value of 100 (originally set to 10 per mytekcontrols).
Furthermore, if I hit and hold any of the these three keys (Caps Lock, Num Lock, or Scroll Lock), there is no response from the keyboard LEDs and the program just hangs. These keys will work if I hit them VERY quickly (less than .1 second - just hit with a glancing blow).
Everything else works as it should (with the CON change above).
Is this a big timing issue for me? Settings when programming?
Reference:
PIC 18F4620
Internal OSC at 8Mhz
OSCCON = %01110010
BUT even with an external 20Mhz oscillator, same performance, still hangs!
I sense severe timing issues. I will welcome all suggestions with regard to fixing this code for me.
Thank you to all,
Bob Pigford
Newark, Delaware
