AT/PS2 Keybord - PIC Interface?
Results 1 to 40 of 74
    gatlartech's Avatar
    gatlartech Guest
    Quote Originally Posted by PJALM View Post
    Are you guys looking to emulate a PS/2 keyboard or get data from a PS/2 keyboard?
    I have pure PBP code for both if you need it.
    I am interested in code to emulate a PS/2 keyboard using a 16f88 interfacing to an embedded PC. Is it possible to view your PBP code?
    Sep 2003
    INDIA
    Default PBP code for PS/2 emulation
    showed the carrot and now missing in action.
    Where is the guy with the PBP code ?
    Mar 2005
    CROATIA
    i have to do 4x4 scan key to ps2 intf. with (one time) programmable keys, numeric part + some fonction key ie. P, A, X, Y...
    but I'm not shure is it a lot of work in that system area,: tx ack, rx sys requests, init in PCstart, and others, if there is a way to put paralel with old kb board to do that portion, (if I dont hawe to switch betwen) then, sems to be easy ?
    PS2 emulation is harder than it seems. Maybe possible to fit a PIC in parallel of an existing controller, but i feel some potential bit collision one day or another.
    I've done it with a single PIC, and frankly... enough time spent and wasted on it to hate it now
    I've seen keyboard emulators in different gaming forums (mostly mame related), where it IS put in parallel with the keyboard.
    anyways, I came across this function/macro/whatever for reading a ps/2 keyboard in great cow basic. says it's free and ok to copy sooo...
    '    PS/2 keyboard/mouse routines for Great Cow BASIC
    '    Copyright (C) 2006 Hugh Considine
    '    This library is free software; you can redistribute it and/or
    '    modify it under the terms of the GNU Lesser General Public
    '    License as published by the Free Software Foundation; either
    '    version 2.1 of the License, or (at your option) any later version.
    '    This library is distributed in the hope that it will be useful,
    '    but WITHOUT ANY WARRANTY; without even the implied warranty of
    '    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
    '    Lesser General Public License for more details.
    '    You should have received a copy of the GNU Lesser General Public
    '    License along with this library; if not, write to the Free Software
    '    Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
    'IMPORTANT:
    'THIS FILE IS ESSENTIAL FOR SOME OF THE COMMANDS IN GCBASIC. DO NOT ALTER THIS FILE
    'UNLESS YOU KNOW WHAT YOU ARE DOING. CHANGING THIS FILE COULD RENDER SOME GCBASIC
    'COMMANDS UNUSABLE!
    #define PS2Data SysTemp.0 'Set to data pin
    #define PS2Clock SysTemp.0 'Set to clock pin
    #startup InitPS2
    'Initialise
    sub InitPS2
     DIR PS2Clock IN
     DIR PS2Data IN
     KeyShift = 0
     MouseX = 0
     MouseY = 0
    end sub
    'Return ASCII value of input key
    function INKEY
     'Initialise, and get key scan code
     INKEY = 0
     ScanCode = PS2ReadByte
     if ScanCode = 0 then exit function
     '2-byte key?
     if ScanCode = 0xE0 then
      do while INKEY = 0
       INKEY = PS2ReadByte
      loop
      INKEY = INKEY OR 128
     end if
     'Shift/Capslock
     if ScanCode = 0x12 or ScanCode = 0x59 then KeyShift = 1: exit function
     if ScanCode = 0x58 then
      if KeyShift = 2 then KeyShift = 0: exit function
      KeyShift = 2
      exit function
     end if
     'Translate scan code to ASCII
     'Control Chars
     if ScanCode = 0x5A then INKEY = 13	'Enter
     if ScanCode = 0x66 then INKEY = 8	'Backspace
     if ScanCode = 0x76 then INKEY = 27	'Esc
     if ScanCode = 0x29 then INKEY = 32	'Space
     'Arrows
     'Numbers
     if ScanCode = 0x45 then INKEY = 48
     if ScanCode = 0x16 then INKEY = 49
     if ScanCode = 0x1E then INKEY = 50
     if ScanCode = 0x26 then INKEY = 51
     if ScanCode = 0x25 then INKEY = 52
     if ScanCode = 0x2E then INKEY = 53
     if ScanCode = 0x36 then INKEY = 54
     if ScanCode = 0x3D then INKEY = 55
     if ScanCode = 0x3E then INKEY = 56
     if ScanCode = 0x46 then INKEY = 57
     'Letters
     if ScanCode = 0x1C then INKEY = 65 'A
     if ScanCode = 0x32 then INKEY = 66
     if ScanCode = 0x21 then INKEY = 67 'C
     if ScanCode = 0x23 then INKEY = 68
     if ScanCode = 0x24 then INKEY = 69 'E
     if ScanCode = 0x2B then INKEY = 70
     if ScanCode = 0x34 then INKEY = 71 'G
     if ScanCode = 0x33 then INKEY = 72
     if ScanCode = 0x43 then INKEY = 73 'I
     if ScanCode = 0x3B then INKEY = 74
     if ScanCode = 0x42 then INKEY = 75 'K
     if ScanCode = 0x4B then INKEY = 76
     if ScanCode = 0x3A then INKEY = 77 'M
     if ScanCode = 0x31 then INKEY = 78
     if ScanCode = 0x44 then INKEY = 79 'O
     if ScanCode = 0x4D then INKEY = 80
     if ScanCode = 0x15 then INKEY = 81 'Q
     if ScanCode = 0x2D then INKEY = 82
     if ScanCode = 0x1B then INKEY = 83 'S
     if ScanCode = 0x2C then INKEY = 84
     if ScanCode = 0x3C then INKEY = 85 'U
     if ScanCode = 0x2A then INKEY = 86
     if ScanCode = 0x1D then INKEY = 87 'W
     if ScanCode = 0x22 then INKEY = 88
     if ScanCode = 0x35 then INKEY = 89 'Y
     if ScanCode = 0x1A then INKEY = 90 'Z
     if INKEY >= 65 and INKEY <= 90 and KeyShift = 0 then INKEY += 32
     'Symbols
     if ScanCode = 0x0E then INKEY = 96 '`
     if ScanCode = 0x4E then INKEY = 45 '-
     if ScanCode = 0x55 then INKEY = 61 '=
     if ScanCode = 0x5D then INKEY = 92 '\
     if ScanCode = 0x4c then INKEY = 59 ';
     if ScanCode = 0x52 then INKEY = 39 ''
     if ScanCode = 0x41 then INKEY = 44 ',
     if ScanCode = 0x49 then INKEY = 46 '.
     if ScanCode = 0x4A then INKEY = 47 '/
     if KeyShift = 1 then KeyShift = 0
    end function
    function PS2ReadByte
     PS2ReadByte = 0
     if PS2Clock ON THEN exit function
     'Start Bit
     wait until PS2Clock OFF
     if PS2Data ON then exit function
     wait until PS2Clock ON
     '8 data bits
     For PS2Bit = 1 to 8
      set STATUS.C OFF
      if PS2Data ON then set STATUS.C ON
      ROTATE PS2ReadByte RIGHT
     next
     'Parity
     'End
    end function
    sub PS2WriteByte (PS2Byte) #NR
     'Take control
     dir PS2Clock Out
     set PS2Clock Off
     wait 12 10us
     dir PS2Data Out
     set PS2Data Off
     dir PS2Clock In
     'Start Bit
     wait until PS2Clock on
     wait until PS2Clock off
     PS2Parity = 0
     '8 data bits
     For PS2Bit = 1 to 8
      if PS2Byte.0 Off then Set PS2Data off
      if PS2Byte.0 On then Set PS2Data on: PS2Parity += 1
     next
     'Parity
     if PS2Parity.0 off then Set PS2Data on
     if PS2Parity.0 on then Set PS2Data off
     'Stop
     set PS2Data On
     'Ack
      Set PS2Data Off
      dir PS2Data in
     wait 100 10us
    end sub
    don't know if it'll do anyone any good, but....
    Feb 2005
    Kolkata-India
    Thumbs up Thanks Michael
    Hi Michael,
    I used your routine and it saved my life. Works like a breeze. Thanks for the great job and sharing it on this forum..
    Sougata
    Mar 2006
    Smile Routine
    Hi Sougata:
    Good day Bro, Can you share with me the routine?
    Ryan
  1. MXcom "C-BUS" interface to PIC question
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 1st May 2014, 03:59
  2. Interface a pic with a Iphone/Itouch
    By Luckyborg in forum General
    Last Post: - 6th May 2009, 16:02
  3. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 05:21
  4. USB Interface using PIC
    Last Post: - 22nd May 2006, 16:04
