AT/PS2 Keybord - PIC Interface?
Results 1 to 40 of 74
    skimask , Look before you leap.... Look at where the colon lies........
    Dave Purola.
    Dave Purola.
    Well, I was talking about the code attached above. He has this line (along with another that's the same way):
    If scancode.0 = 1 Then: parity = parity + 1
    I don't know how that'll compile, if it will compile good and not cause an error, if it'll work as written, or what will happen. It just doesn't look right to me, that's all...
    And I'm always keeping track of where my colon's lie...
    skimask, The way I interpret a colon is to terminate a line of code and, allow the start of another command string to be placed on the same line. If this is the case then all of his IF/THEN statements should have and ending ENDIF command. I have not tried this as I never write code in this fashion. It is much to confusing and hard to follow the flow... Have you ever tried this format? If it works then GREAT...
    I guess I use whatever fits/works and takes up as few actual lines on the screen.
    As far as being confusing, well, I usually don't write code for other folks (reference the High Colonic Master ), and if I wrote it for myself, then I'd better be able to follow it! And as long as a guy keeps a constant format...well, that should be all ya need...
    But, I'm going to play with the If/Then colon format thing tonight when I get home and see what happens...
    Jan 2006
    Toronto
    Are you guys looking to emulate a PS/2 keyboard or get data from a PS/2 keyboard?
    I have pure PBP code for both if you need it.
    Jan 2006
    Istanbul
    Quote Originally Posted by PJALM View Post
    May I see the emulation code, then?
    IF, of course, it is responding to the system commands ??
    Quote Originally Posted by sayzer View Post
    I second that commotion...no sense reinventing the wheel...
    It's the responding back to the PC bit that gets me...
    Sep 2006
    Venezuela - Caracas
    PJALM's
    is possible upload the code?
    i use http://www.picbasic.co.uk/forum/arch...hp/t-2736.html but not work leds
    many thanks
    ..: Don't worry, be happy :..
    gatlartech's Avatar
    gatlartech Guest
    I am interested in code to emulate a PS/2 keyboard using a 16f88 interfacing to an embedded PC. Is it possible to view your PBP code?
    Sep 2003
    INDIA
    Default PBP code for PS/2 emulation
    showed the carrot and now missing in action.
    Where is the guy with the PBP code ?
  1. MXcom "C-BUS" interface to PIC question
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 1st May 2014, 04:59
  2. Interface a pic with a Iphone/Itouch
    By Luckyborg in forum General
    Last Post: - 6th May 2009, 17:02
  3. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 06:21
  4. USB Interface using PIC
    Last Post: - 22nd May 2006, 17:04
