Hi guys,
I was wondering if someone can help me out here on a simple task.
I've been learning a lot by reading about sending data to a keyboard's PS/2 port, but I am unable to send a simple letter and have it show up in notepad.exe on the host computer.
I know the following: data sent must have Start Bit = 0, Scancode (LSB First), Odd Parity, Stop Bit = 1.
Now, I don't care about keyboard initialization, because I will be booting up the PC with a normal keyboard attached, then swapping out the keyboard with my device.
All I want to do is send the letter 'q' ($15).
I am doing so by sending q (0+$51+0+1), then the release code (0+$0F+1+1), then q again (0+$51+0+1).
However, I am not getting anything on the host side of things.
Here is my code:
Any advice appreciated.Code:; PS2SendCode ; ; PIC16F648A ; _________________ _______________ ; 1|RA2/AN2/VREF RA1/AN1|18 ; 2|RA3/AN3/CMP1 RA0/AN0|17 ; 3|RA4/TOCKI/CMP2 RA7/OSC1/CLKIN|16 ; VPP ---> 4|RA5/MCLR/VPP RA6/OSC2/CLKOUT|15 ; Gnd 5|Vss Vdd|14 +5 ; 6|RB0/INT RB7/T1OSI/PGD|13 <--- PGD ; 7|RB1/RX/DT RB6/T1OSO/T1CKI/PGC|12 <--- PGC ; 8|RB2/TX/CK RB5|11 <--> PS2DATA ; PUSH BUTTON ---> 9|RB3/CCP1 RB4/PGM|10 <--- PS2CLK _|¯|_|¯|_|¯|_|¯|_ ; ---------------------------------- ; ;=============================================================================== ; Keyboard to Host Protocol ; ___ _ _ _ _ _ _ _ _ _ _ _ _ ___ ; CLOCK |__| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_| ; ; DATA | S | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | P | E | ; ; S = start bit = 0 P = odd parity E = stop bit = 1 ; data valid on falling edge of clock ;=============================================================================== @ errorlevel -223,-207,-306 ; Suppress useless messages @ LIST P=PIC16F648A @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF & _BODEN_OFF & _PWRTE_OFF & _LVP_OFF ;Using 4MHz oscillator define OSC 4 ;DEFINE SHIFT_PAUSEUS 43 PortB = 0 'Clear Port B INTCON = 0 'Interrupts Off CMCON = %00000111 'Disable Comparators OPTION_REG.7 = 0 'Enable Port B Weak Pull-Ups BitCnt VAR BYTE KBTimeout VAR BYTE ScanCode VAR Word Parity Var BYTE StartButton Var PortB.3 PS2Clk var PortB.4 '0 PS2Dat var PortB.5 '0 TRISB = %11111111 'Set PORTB pins direction to input Start: pause 500 if startbutton = 0 then: goSUB StartSend goto start StartSend: 'SEND Q ($15 LSB FIRST) Parity = 1 'Odd parity scancode.0 = 0 Gosub sendbit 'send START BIT scancode = %00010101 'send 'q' For bitcnt = 1 To 8 'set for 8 data bits Gosub sendbit 'send DATA BIT If scancode.0 = 1 Then: parity = parity + 1 scancode = scancode >> 1 'shift out next bit Next bitcnt scancode.0 = parity.0 Gosub sendbit 'send PARITY BIT scancode.0 = 1 Gosub sendbit 'send STOP BIT 'SEND RELEASE ($F0 LSB FIRST) Parity = 1 'Odd parity scancode.0 = 0 Gosub sendbit 'send START BIT scancode = %11110000 'send '$F0' For bitcnt = 1 To 8 'set for 8 data bits Gosub sendbit 'send DATA BIT If scancode.0 = 1 Then: parity = parity + 1 scancode = scancode >> 1 'shift out next bit Next bitcnt scancode.0 = parity.0 Gosub sendbit 'send PARITY BIT scancode.0 = 1 Gosub sendbit 'send STOP BIT 'SEND Q ($15 LSB FIRST) Parity = 1 'Odd parity scancode.0 = 0 Gosub sendbit 'send START BIT scancode = %00010101 'send 'q' For bitcnt = 1 To 8 'set for 8 data bits Gosub sendbit 'send DATA BIT If scancode.0 = 1 Then: parity = parity + 1 scancode = scancode >> 1 'shift out next bit Next bitcnt scancode.0 = parity.0 Gosub sendbit 'send PARITY BIT scancode.0 = 1 Gosub sendbit 'send STOP BIT Return SendBit: 'Looking for keyboard clock and data line to go high, then send data bit to it! ;If NOT(PS2Clk = 1 AND PS2Dat = 1) Then sendbit 'loop until clock line goes low PS2Dat = scancode.0 'send data bit return
