Maximum Baud Rate at 4Mhz
Results 1 to 8 of 8
    Jun 2005
    Up the bush, Western Plains, NSW Au
    I am right this minute using a 'F877 at 9600. I am reading 14 bytes with errors on the last 4 eceived. So I would have to say that I will need to go up to a 8MHz xtal. Just a bit too "iffy" at 4MHz.
    I might try the DEBUGIN as mentioned above and see what difference that makes. Stay tuned.
    Hmm...Nope, still the same. Gunna hafta get a faster xtal next time I'm up town..
    Oh Well....
    Jun 2005
    Well, fancy that!!
    After a bit of jiggery pokery with the decoding of the input array, it is working PERFECTLY with the DEBUGIN command. Very Pleased.
    Some issues with DEBUGIN is that I believe that you can only use receive information on the pin that is defined at the beginning of the program and whatever baud rate you choose to DEFINE can not be changed in the program.
    Last Post: - 8th March 2010, 20:58
  2. Maximum Baud Rate error tolerance
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 13th February 2007, 11:10
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 02:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 16:48
