Proximity Card Reader
Results 1 to 7 of 7
    Aug 2005
    Default Its not a weigand reader
    Just to let you know its not a weigand reader. With reguards to the crystal ive only got 4Mhz but ill try 20Mhz.
    Thanks for the reply Sphere.
    Could you post the type of the reader? Or link for datasheet?
    Aug 2005
    Sorry dont no the model number of the reader the make is hid it has a clock, data, sense, red led, green led, buzzer, 5v ,0v. Its of an old site which was being demolished. The system was working before removal from the site.
    Sphere.
    Aug 2005
    Denver
    Default Another idea...
    You might want to go to http://www.hidcorp.com/products/readers.php and see if you can match your reader up with on of their models.
    Aug 2005
    Default Does my code look ok
    Does my code look ok or im I missing something out. No joy on identifing the model but I tried it on a door controler an it works fine. The door controler is compatable with clock and data readers only acording to the spec sheet. Would I need pullup resistors on the clock and data lines.
    Thanks for the help Sphere
  1. TTL magnetic card reader interface ith PC
    By attabros in forum Schematics
    Last Post: - 24th February 2016, 07:04
  2. Proximity Reader (Weigand) aka RFID
    By GoldStar in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2009, 05:41
  3. Mag Card Reader
    By Melanie in forum mel PIC BASIC Pro
    Last Post: - 4th February 2006, 17:29
  4. gsm card reader using pic
    By ninebarmaximus in forum General
    Last Post: - 6th December 2005, 18:08
  5. Smart card reader with PIC16F84A
    By bangunprayogi in forum Serial
    Last Post: - 12th August 2005, 10:36
