How about String Variables?
Results 1 to 40 of 41
    I am curious about the application using a MCU where that type of string handleing would be needed?
    The serial and LCD commands can work with strings via arrays now.
    I see most people using a MCU for monitoring/control of something. Just wondering what you have in mind?
    Jul 2008
    Who would waste time with code-consuming arrays when you could use something like "Buffer = "Hello World!" as shown above.
    In recent coding i've played with, i've had the need for using 2character strings, it would seem inefficient to use several for-next arrays for only 2 characters.
    Why can't a buffer be assigned to xx-amount of ram locations and be given a name or symbol that can be called upon by name?
    Don't get me wrong, Picbasic Pro is EXCELLENT, but has a LONG way to go
    I can't believe many of the simple tasks i used to do with GWbasic 25+ years ago, still isn't supported in Picbasic....
    Marty.
    Quote Originally Posted by gtvmarty View Post
    Marty.
    Wow! I did not know that GWbasic worked with the architecture of a MCU.
    Jul 2008
    U must have had the older version
    Dec 2008
    Los Angeles, CA
    Unhappy
    Strings are needed ALL THE TIME! I wish PBP would face the music and implement them! Every other compiler I see has them, why not PBP? (And No, I don't want to switch because I've got years and $ invested in this one.)
    Quote Originally Posted by circuitpro View Post
    Like I asked before, what type of project would you do that needs this?
    I am not trying to be difficult, I just have not had the need beyond what is already there.
    It might be fun/interesting to write a library/include to handle some of this stuff. If an example of it's usage was given I might give it a go...
    Dec 2008
    Los Angeles, CA
    Red face
    Well, my last embedded project was a remote control for some specialty plasma monitors. The language used in the remotes uses exclusively strings for control. As I said before in another post, strings are a fact of life, get over it. Just as numbers, and variables, strings are used in everyday life and becoming more and more necessary for any kind of efficient programming. Rediculious little FOR...NEXT loops to parse out a string character by character are S T U P I D and a waste of time. IMO. Words are a fact of life. Adjust.
    Nov 2009
    Here's an example and something that I'm working on now. I am debugging a program that will read 3 axes of an accelerometer via A/D conversion. The sampled value is a number and I'd like to convert it to an array of text that I can send to the USB port. The pic is enumerating as a USB serial port so I can read it via a terminal program.
    Anybody know an efficient way to convert a 10-bit value to a number string?
    Nov 2009
    Wagoner, USA
    I send a lot of strings to LCD's and some of the "STD" basic string functions would be really handy. Of coarse strings suck up a bunch of memory but Constantly used strings can be stored in EEProm and called when needed.
  1. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 02:16
  2. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 04:39
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 14:36
  4. String Parsing
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 17:20
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 10th July 2005, 23:17
