How about String Variables?
Results 1 to 40 of 41
    Oct 2009
    Utah, USA
    Default Re: How about String Variables?
    OK Now that last string of posts are just about the funniest thing I have read around here in a while.
    Or else I am just so tired that I need to get some sleep... Been chasing satelite outages for the last 14 hours and about 500 miles. Spacenet decided to change frequencies in the middle of last night and I woke up to 16 sattelites down. (we use them to bring in electricity load information on a 5 minute basis from major substations in Utah, Wyoming and Nevada.
    Probably just tired...
    You guys and gals are a great bunch.
    Dwight
    Jul 2011
    Yeah, how about STRING variables?????
    Strings are needed ALL THE TIME! I wish PBP would face the music and implement them! Every other compiler I see has them, why not PBP? (And No, I don't want to switch because I've got years and $ invested in this one.)
    May 2007
    There are many other features besides strings available in other compilers that are not available in PBP.
    Sep 2005
    Campbell, CA
    I like strings as well. All my projects have either RS-232 or Ethernet connectivity, and they all have
    menus, user input, etc. I need to handle strings constantly.
    I generally put all my strings into arrays. This is the only way they can be manipulated. Check out
    the ARRAYWRITE command. It is an easy way to load and clear arrays.
    Here is some stuff that I cobbled together that may help the situation. Note that I pulled this from
    various programs, so it has not been tested completely, although most routines should work as-is.
    Use at your own risk!
    Lester may want to move this into the 'code examples' section later.
            IgnoreCase var bit
            Xs var byte
            Ys var byte
            Zs var byte
            Js var byte
            Ws var byte
            Cmd var byte
            Length1 var word
            Length2 var word
            MaxSearchLen var byte
            Str1ArrayLength CON 30
            Str2ArrayLength con 30
            MaxCompareLength var byte
            Str1 var byte[Str1ArrayLength]
            Str2 var byte[Str2ArrayLength]
       ; Zero out the strings
         arraywrite Str1,[rep 0\Str1ArrayLength]
         arraywrite Str2,[rep 0\Str2ArrayLength]
    ; Fill input arrays with some test stuff
          ARRAYWRITE Str1,["0123456789ABCDEF"]
          arraywrite Str2,["345"]
    'LeftString:  ; Str2 contains the leftmost chars of Str1
    ;     Ys = Number of Chars to separate off from Str1
            YS = 6  ; for testing only
          If Ys != 0 then
             For Js = 0 to YS-1
                Str2[Js] = Str1[Js]
             next Js
                Str2[Js] = 0  ; make certain we always end with a nul
    MidString: ; Str2 contains a string of Ys chars derived from Str1 starting at position Zs (zero based)
        ys = 2 :Zs = 4 ; for testing only
          If Ys !=0 then
            For Xs = Zs to ((Zs + Ys)-1)
               Str2[Xs-Zs] = Str1[Xs]
            next Xs
               Str2[xs] = 0  ; terminate with a nul
          Endif
    RightString:  ; Str2 contains a string consisting of the right-most chars (number defined by Ys) of Str1
           Ys = 4   ; for testing only
           Js = Ys - 1
           for xs = Str1ArrayLength to 0 step - 1
                 If Str1[xs] != 0 then
                     Str2 [Js] = Str1[Xs]
                     if Js = 0 then DoneRS
                     Js = Js-1
          next xs
    DoneRS:
    ;      return
    LenSTring:  ; Ys contains the length of STR1
            Js= 0
            While Str1[JS] != 0
               JS = Js + 1
            wend
            if Js > 1 then
               Ys = Js - 2
               YS = 0
    ;        return
    InString:   ; Ws contains the position in STR1 where the match with STR2 started
                ; if there is no match, Ws contains 255
                ; if Ignore Case is set to '1', it will, of course, ignore the case.
            MaxCompareLength = Str1ArrayLength Min Str2ArrayLength
            for Xs = 0 to Str1ArrayLength
               If IgnoreCase then
                    Str2[0] = Str2[0] & %11011111
                    Str1[Xs] = Str1[XS] & %11011111
                   If Str2[0] = Str1[Xs] then   ; Found a match on 1st char of Str2
                   Ws = Xs
                   Js = 1
                     for Ys = Xs + 1 to MaxCompareLength
                        if Str2[Js] = 0 then FoundMatch  ; hit the end of Str2
                           If IgnoreCase then
                               Str2[Js] = Str2[JS] & %11011111
                               Str1[Ys] = Str1[Ys] & %11011111
                        if Str2[Js] != Str1[Ys] then NoMatch
                        Js = Js + 1
                     next Ys
                     goto FoundMatch
            next Xs
    NoMatch:
          WS = 255
    FoundMatch:
    CommandParser:
    ; Fast searcher! Case sensitive.  Closely based on info provided by Darrel Taylor.
    ; Searches through Str1. If it finds the strings listed in the quotes, it returns which one it found.
    ; the max length of STR1 that will be searched is in MaxSearchLen
        Cmd = 255  ; In case of no match
        MaxSearchLen = 20
        Parse01: Cmd=01 : ARRAYREAD Str1,MaxSearchLen,Parse02,[WAIT("Command1")] : GOTO Foundit
        Parse02: Cmd=02 : ARRAYREAD Str1,MaxSearchLen,Parse03,[WAIT("Age")] : GOTO Foundit
        Parse03: Cmd=03 : ARRAYREAD Str1,MaxSearchLen,Parse04,[WAIT("Weight")] : GOTO Foundit
        Parse04: Cmd=04 : ARRAYREAD Str1,MaxSearchLen,Parse05,[WAIT("Address")] : GOTO Foundit
        Parse05: Cmd=05 : ARRAYREAD Str1,MaxSearchLen,Parse06,[WAIT("Command5")] : GOTO Foundit
        Parse06: Cmd=06 : ARRAYREAD Str1,MaxSearchLen,Parse07,[WAIT("Command6")] : GOTO Foundit
        Parse07: Cmd=07 : ARRAYREAD Str1,MaxSearchLen,Parse08,[WAIT("Command7")] : GOTO Foundit
        Parse08: Cmd=08 : ARRAYREAD Str1,MaxSearchLen,Parse09,[WAIT("Command8")] : GOTO Foundit
        Parse09: Cmd=09 : ARRAYREAD Str1,MaxSearchLen,Parse10,[WAIT("Command9")] : GOTO Foundit
        Parse10: Cmd=10 : ARRAYREAD Str1,MaxSearchLen,Parse11,[WAIT("Command10")] : GOTO Foundit
        Parse11: Cmd=11 : ARRAYREAD Str1,MaxSearchLen,Parse12,[WAIT("Command11")] : GOTO Foundit
        Parse12: Cmd=12 : ARRAYREAD Str1,MaxSearchLen,Parse13,[WAIT("Command12")] : GOTO Foundit
        Parse13: Cmd=13 : ARRAYREAD Str1,MaxSearchLen,Parse14,[WAIT("Command13")] : GOTO Foundit
        Parse14: Cmd=14 : ARRAYREAD Str1,MaxSearchLen,Parse15,[WAIT("Command14")] : GOTO Foundit
        Parse15: Cmd=15 : ARRAYREAD Str1,MaxSearchLen,Foundit,[WAIT("Command15")] : GOTO Foundit
    Foundit:
    Charles Linquist
    Feb 2011
    Thanks Charles for your subroutines.
    This is a snippet of code from a two temperature probe controller, chiller and alarm
    Alarm MIN and MAX
    Chiller MIN and MAX
    Crammed it into a 12f1822, should of used a 12f1840 for more space.
    Use gosub Print_Phrase: with zb pointing to the string.
    eg zb= Ofuzzy1 : gosub Print_Phrase
    will print out the copyright string:
    (C)2011 Ofuzzy1 All Rights Reserved - Not for Life Critical Use!
    Was cramped for space so phrases were pieced together.
    MIN Alarm would be pieced together
    Print_Alarm_Min:
    gosub Print_Alarm: gosub Print_Min:
    ; Strings are stored in the EEPROM leaving more room for Programs
    ; The last char of the string has $80 added to it mark then end of the string.
    ;  this simplifies string maintenance.
    ; Strings are sent out via DEGUG for Async Serial - RS232
    ; Debug is smaller than serout and serout2
    ' print character defines
    CR              con 13
    LF              con 10
    VTAB            CON 11  ' VERTICAL TAB   = Clear Screen
    DEGREE          CON $DF
    Dash            con 45
    Space           con $20
    ' ---- The temps  they do all the grunt work with little or no pay :)
    AB          VAR BYTE    ' TEMP
    BB          VAR BYTE    ' TEMP
    xb          var byte    ' temp
    yb          var byte    ' temp
    zb          var byte    ' temp
    ' These are stored on the EEPROM Data area -- Leaves room for bigger programs
    '   *** Mark the end of the words with Char + 128
    ; @$10 starts the strings at location $10 [16] in the eeprom
    CharBump        con $80
    Ofuzzy1 data @$10,   "(C)2011 Ofuzzy1 All Rights Reserved - Not for Life Critical Use", "!" + CharBump
    W_Alarm  Data        "Alarm", "_" + CharBump     ; Alarm
    W_Min    Data        "Mi", "n" + CharBump        ; Min
    W_Max    Data        "Ma", "x" + CharBump        ; Max
    W_Normal Data        "Norma", "l" + CharBump
    W_Both_Probes Data   "Both Probe", "s" + CharBump
    W_Enter  Data        "& Ente", "r" + CharBump
    W_YNRQ   Data        "Y=Yes R=Redo N=No Q=Qui", "t" + CharBump
    ; begin MAIN program code
    Gosub Print_Copyright
    ;end MAIN program code
    Print_Copyright:
    gosub CR_LF3 ': gosub CR_LF
    Print_Phrase:   ' Call with zb = ROM_Memory_Location [byte] last char is >$80
    bb = 1          ' this could be re-written slicker but it works.
      Do until !BB '  = 0
        read zb, ab
        if ab > CharBump-1 then
            ab = ab - CharBump
            bb = 0
        debug ab
        zb= zb + 1
      loop
    CR_LF3:        ; 3 line feeds
    debug LF,cr
    CR_LF2:        ; 2 line feeds
    debug LF,cr
    CR_LF:
    debug CR,LF    ; 1 line feed
    Print_SP2:
    debug " "
    Print_SP:
    debug " "
    Print_LT:
    gosub Print_SP : gosub Print_lt1: gosub Print_SP
    Print_LT1:
    debug "<":
    Print_GT:
    gosub Print_SP : gosub Print_GT1: gosub Print_SP
    Print_GT1:
    debug ">":
    Jan 2007
    Well, BANG goes my idea of making a Ethernet controlled device using PICBASIC to deliver the menus etc.
    I was an early adopter of this compiler, but to do what I need I'm moving over to Mikro C (SORRY) But it has string handling by the bucket load.
    My latest project included a 3 way Bluetooth comms using 3 HC05 modules. The only way I could get them to talk was to do an AT+RNAME? to ID each unit, thus ensuring that the master had connected to the correct two units assigned to it (in the environment where this device will work there will be 100's of similar units and at pairing the master needs to know that is has one of each TYPE connected rather than relying on an "IP" address.
    May 2007
    Quote Originally Posted by Sean_Goddard View Post
    ...but to do what I need I'm moving over to Mikro C (SORRY) But it has string handling by the bucket load.
    This post will probaby be deleted (like skimask's entire thread) for mentioning the advantages of a superior competitive product.
  1. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 03:16
  2. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  4. String Parsing
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:20
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
