How about String Variables?
Results 1 to 40 of 41
    Default Re: How about String Variables?
    ARRAYREAD/WRITE, I guess it's time for me to upgrade as well.
    Dec 2008
    Los Angeles, CA
    No kidding. Good thing we weren't holding our breaths! It isn't that it can't be done some other contrived way, it just seems like the effort should be put forth to implement some of BASIC's functions to make it easier for people familiar with BASIC, and simply get the job done. My last comment here was Dec 2008. Still waiting.
    May 2007
    This has everything you want http://www.sfcompiler.co.uk/swordfish/ only for PIC18 though. The author hangs out here from time to time.
    Swordfish is a highly structured, modular PIC® BASIC compiler for the PIC18 family of PIC® microcontrollers. Swordfish is a true compiler that generates optimised, stand alone code which can be programmed directly into your microcontroller. Extensive library support is provided with full source code, some of which include LCD, GLCD, EEPROM, ADC, software and hardware SPI, software and hardware I2C, software UART, USART, string manipulation, USB and math libraries. Support for strings, arrays, structures, boolean, bit, unsigned and signed 8, 16 and 32 bit ordinal types and 32 bit floating point is also provided. Swordfish is supplied with a powerful and flexible Integrated Development Environment (IDE) which includes an advanced code explorer, full syntax highlighting, third party programmer integration, serial communicator and integrated boot loader application. Just a single mouse click, or key press, will compile, assemble and program your project into the target microcontroller.
    Sep 2005
    Campbell, CA
    Isn't it too bad that we can't get MELabs, John David Barker and MikroE to REALLY work together. Just think of all the good code that would come out. Perhaps if we bought them plane tickets and a few beers...
    I'll pitch in!
    Charles Linquist
    Not at all, if people can't make some effort by themself, too bad for them.
    There's an alternative for each problem... stop moaning, work and learn from, or GT*O
    Oct 2009
    Utah, USA
    Yea, and those who wanted to go faster than the Horse and Buggy should have just kept quiet and enjoyed the slow meandering ride
    Nothing wrong with wishing for (and expecting) improvements to an allready great compiler... that is the reason PBP3 is out.
    Dwight
    I agree that common string manipulation things should have been there, but Melabs decided to not do it and be like a BasicStamp alike replacement. Nothing wrong with it. Sometime you need to draw the line somewhere... they did.
    There's some hope I guess.
  1. How to convert HEX Value as formatted BIN String ?
    By Robson in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 03:16
  2. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  4. String Parsing
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 18:20
  5. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 11th July 2005, 00:17
