3v3 LCD
Results 1 to 6 of 6
Thread: 3v3 LCD
    barkerben's Avatar
    barkerben Guest
    That sounds great - in fact, I have managed to get my original circuit to work:
    2 AA batteries ---> Step up to 5v to run RS232 level converter and LCD----> step down to 3v3 to run GPS and PIC
    I had some problems, because the MAX233 ties its input lines to 5v. I externally tied them to a more helpful voltage, and now eveything works fine.
    Out of interest, how can you up the voltage using PWM - did it use a voltage doubler capacitor circuit?
    Cheers,
    Ben
    Sep 2003
    Vermont
    Quote Originally Posted by barkerben
    Cheers,
    Ben
    You are better off, from a battery standpoint, to raise the voltage as little as possible. I would jump it to 3.3 and use the HPWM for the 5 volt line if you only need a few mils.
    It is a capacitor doubler, I attached a .1 uF from the HPWM output pin to the anode of a shottky diode. This diode is then attached to the circuit to be powered. A second shottky diode feeds 3.3 volts to the junction of the cap and the diode. A second cap is attached to the output of the first diode and to ground. When the HPWM pin is at 0 volts, the first cap charges to 3.3 volts. When the pin goes high. the bottom of the cap goes to 3.3, so the top goes to 6.6 volts(less the diode drops). This goes through the second diode, and charges the cap. Pretty neat huh? You can feed the 3.3 volt supply from another PIC pin, so you can shut down the display when not in use. I needed to do this because my app needed to sit for a year on a set of batteries.
    Ron
    barkerben's Avatar
    barkerben Guest
    I might try that - at the moment, I have no time to reetch the board - but there is an enourmous list of things I'd like to change when I get a chance, and your suggestion has made the list a tiny bit longer :-)
    Thanks for your help,
    Ben
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
