MicroCose Studio Plus problems
Results 1 to 10 of 10
    Pinckney, Michigan
    Quote Originally Posted by NavMicroSystems
    What kind of help are you expecting if you don't post your code and schematic?
    What I'm hoping is that someone will have had similar experience with their large programs and suggest possible fixes.
    I doubt you would want to review my code. It nearly fills an 8KByte 16F877, which is why I'm porting it to PicBasic Pro, which supports the larger 18F devices.
    The schematic of the serial port interface is directly from the Mechanique app notes.
    As most of my design use more than 16K now, i always use the Bootloader. Never had manyt problems with. The only problem that persist, and it's not a big one, is when i use the compile/program Button. Sometimes it works sometimes no. I have a message like "Reset target processor' blah blah. No big deal, use compile, wait 1-2 secondes, then program the PIC... must be caused by a slow machine.. i don't care too much about that problem..
    I'm not a big ICD fan/user so i can't really comment one. The only thing i could suggest is, as you said, use multiple Disable/Enable... Sorry, this is not helpfull
    Sure you must run your PIC at least @20MHZ for better results
  1. can't find include file!
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 10th November 2009, 09:44
  2. MicroCode Studio Plus Problems
    By Mike2545 in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 03:11
  3. Problems with MicroCode Studio ICD
    By Muzza in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 03:37
  4. Microcode Studio Problems
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th March 2006, 19:00
  5. Replies: 0
    Last Post: - 8th February 2006, 14:52
