MicroCose Studio Plus problems
Results 1 to 10 of 10
    Question
    Do you mean PBP version 2.46?
    ---> picnaut
    Pinckney, Michigan
    Quote Originally Posted by picnaut
    Yup! My Phat fingers!
    Pinckney, Michigan
    Default Update
    I discovered that my program would "Compile and Run" just fine, it just wouldn't "ICD Compile and Run" reliably, which is neccessary for single-stepping, animation and breakpointing, etc.
    Further, I discovered that if I did a "ICD Compile and Run" on one of the small sample programs, that it would work fine, then afterwards a "ICD Compile and Run" would work temporarily with my program.
    I've sent my source program to Mechanique for review.
    Oct 2003
    Australia
    Unhappy MicroCode Studio Compile + IC-Prog
    Anyone know the command line setting for Microcode studio to automatically compile and program a PIC?
    I haven't been able to get IC-Prog to LOAD the program. It does everything else, ie sets the com port, selects the right pic chip etc but always starts up with an empty hex file.
    The microcode studio help files says to use $hex-filename$, but this doesn't work.
    so far I am using this, without luck:
    -L$hex-filename$ -P -I -O1 -T146 -Q
    Help much appreciated.
    J
    PS just downloaded the latest version of MC studio. Very nice.
    Pinckney, Michigan
    Mechanique responded to my inquiry but did not have a magic bullet. They checked out my program at their facility, and experienced no issue with it. They asked how long my serail cable is (6 feet), and if I was using a MAX232 chip (yes), but could only suggest that I try enabling/disabling debug at various places in my program to help isolate the problem.
    Has anyone else experienced unreliable operation of MicroCode Studio Plus on their systems?
    Feb 2004
    Germany
    Quote Originally Posted by J. Mark Wolf
    MCS+ works just fine for me, never had any problem with the loader or ICD.
    What kind of help are you expecting if you don't post your code and schematic?
    regards
    Ralph
    Pinckney, Michigan
    Quote Originally Posted by NavMicroSystems
    What I'm hoping is that someone will have had similar experience with their large programs and suggest possible fixes.
    I doubt you would want to review my code. It nearly fills an 8KByte 16F877, which is why I'm porting it to PicBasic Pro, which supports the larger 18F devices.
    The schematic of the serial port interface is directly from the Mechanique app notes.
    Jun 2013
    Default Re: MicroCode Studio Compile + IC-Prog
    Any answer to this?
    Quote Originally Posted by Squibcakes View Post
    J
  1. can't find include file!
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 10th November 2009, 09:44
  2. MicroCode Studio Plus Problems
    By Mike2545 in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 03:11
  3. Problems with MicroCode Studio ICD
    By Muzza in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 03:37
  4. Microcode Studio Problems
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th March 2006, 19:00
  5. Replies: 0
    Last Post: - 8th February 2006, 14:52
