Decimal values from string
Results 1 to 2 of 2
    Default Decimal values from string
    Hi .
    For many reason I can't use Hserin Timeout,Label,[dec par1,dec par2,dec par3] .
    I have my serial input routine that receive ascii caracters and put them in a buffer.
    There is a way to convince HSERIN to get data from buffer instead of serial port.
    Or someone has a routine that scan the buffer and return the decimal values.
    Gianni
    Hangover, Germany
    This is a way to the basics of digital calculation and base-conversion....
    Why don't test your mind ?
    Take a digit out of the Buffer (ASCII),
    subtract "0" ($30),
    take your Dummy-Variable, multiply it by 10, add the result from the last action...
    Loop until there is an End or so....
    f.eg.: (Quick and very dirty!)
    Dummy=0
    I=0
    TakeThem:
    Digit=Dummy[I]-$30:I=I+1
    If (Digit>0) and (Digit<10) Then Dummy=Dummy*10+Digit:Goto TakeThem
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 08:50
  3. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 22:09
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 11:30
