lcd problems
Results 1 to 10 of 10
Thread: lcd problems
    Nitro's Avatar
    Nitro Guest
    Unhappy lcd problems
    i am not new to pics, but very new to picbasic, and i can only get a few tyings to work.
    right now i'm interested in controlling a 2*20 line lcd, i have writen numerous programs for lcd's in assembler, but couldn't get even a blip though pbp demo
    i'm sure you must get annoid of nubies trying to leech knowledge, but this is trhe only sensible place i found to learn pb.
    i tryed thius code on the 877 to no success.
    please help me!
    Pause 500 ' Wait for LCD to startup
    loop:
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "Hello" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout "World"
    Goto loop ' Do it forever
    Mentor, Ohio
    Smile
    Hi Nitro,
    So where's the beginning part of the code that sets up the 16F877 with the LCD defines? How can we help you without all of the information?
    BobK
    Dec 2004
    Scarborough UK
    Default lcd problem
    Hi Nitro
    BobK suggests what i was going to say that the defines are missing.
    You have to define the port and pins you want to use for your lcd.
    Once you sort that out try this little file i made it might help you.
    http://www.picbasic.co.uk/forum/showthread.php?t=2701
    Brian
    Reading the datasheet & understanding it are two different things.
    Nitro's Avatar
    Nitro Guest
    Cool
    thanx for the reply, but as far as understand there are preset pin configurastions on portA and one on portB as shown in the manual
    ...it seems there is something wrong with my pic, i'll try another on one of my other lcd's. i'll see if the problem persists.
    ... tried it. now it does is devour pics faster. i didnt even get anything done before the pic blew out! maby the voltage on my breadboard not 5v? thanx though.
    Mentor, Ohio
    Smile
    Hi Nitro,
    Yes that is true, PBP assumes that the LCD is connected to PortA.0 to PortA.3 for the 4 bit data lines and RS to PortA.4 and enable to PortB.3. I have found throughout life not to assume anything! Put it in writing, as the lawyers say. Did you also disable the analog features? Do you have a pull up resistor on PortA.4?
    It sounds from your last post that you have a more important problem. Hope the above helps when you have the other problems under control.
    BobK
    Nitro's Avatar
    Nitro Guest
    Talking ok
    thanks for all the help, i should be able to get it going.
    Dec 2004
    Scarborough UK
    Default lcd problem
    Hi Nitro
    This is the lcd defines i always use, just alter it to what your configuration is.
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTE
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTE
    DEFINE LCD_EBIT 1
    Brian
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
