Problems with IF ENDIF
Results 1 to 4 of 4
    Could you explain what problem you are having with your code?
    Mar 2005
    Iowa, USA
    Lightbulb
    Try re-writing them without the ()'s. Look at the PBP manual for different ways of using IF,Then, Else statements. Good luck!
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    jetpr,
    I'm not sure how you even got this to compile.
    STEP is a reserved word. Part of the FOR/NEXT syntax.
    Try using a different variable name.
  1. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  2. Complete Keypad Example
    Last Post: - 27th July 2011, 19:09
  3. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 19:54
  4. Help needed with Select Case?
    Last Post: - 2nd January 2008, 00:12
  5. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:11
