Why SOUND statement produces loud and clear sound, but FREQOUT - does not?
+ Reply to Thread
Results 1 to 8 of 8
    Default Why SOUND statement produces loud and clear sound, but FREQOUT - does not?
    Hello
    AI has no answer.
    even at 64mhz, FREQUOUT provides very low volume, distorted audio, while SOUND, even on 4Mhz 628A chip, produces loud and clear sound.
    This is not chip or hardware issue - tested on numerous 12F-16F-18F devices. This is PBP issue as it seems. Can we fix it somehow?
    Default Re: Why SOUND statement produces loud and clear sound, but FREQOUT - does not?
    Because FREQOUT is using PWM with the ability to output two tones at the same time, so filtering is required to produce a, relatively clean, sinewave-looking tone.
    On the otjher hand, SOUND produces only one, rectagular TTL signal, with no filtering. So yes the amplitude is very different.
    But you did not showed how you use the output signal, what is your circuit.
    Sorry for late reply
    All I need is for it to play loud and clear.
    I've added extra RC filtering circuit, as shown in manual, also I have external transistor amplifying the sound, but output is still not sounding good.
    By the way, claude excells in generating PBP code from the uploaded midi files - the code below plays the some cartoon music, converted from the midi file, with 2 voice polyphony using FREQOUT statement:
        FREQOUT SPEAKER, 125, 523
        PAUSE 125
        FREQOUT SPEAKER, 125, 261, 523
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 261, 587
        PAUSE 125
        FREQOUT SPEAKER, 125, 659
        PAUSE 125
        FREQOUT SPEAKER, 125, 261, 659
        PAUSE 125
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 250, 783
        FREQOUT SPEAKER, 125, 329, 783
        PAUSE 125
        FREQOUT SPEAKER, 250, 659
        FREQOUT SPEAKER, 125, 329, 659
        PAUSE 125
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 698
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 698
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 659
        PAUSE 125
        FREQOUT SPEAKER, 125, 587
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 587
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 880
        FREQOUT SPEAKER, 125, 880
        FREQOUT SPEAKER, 125, 195, 783
        PAUSE 125
        FREQOUT SPEAKER, 250, 698
        FREQOUT SPEAKER, 125, 195, 698
        PAUSE 125
        PAUSE 125
        PAUSE 125
        PAUSE 250
        FREQOUT SPEAKER, 125, 261, 698
        FREQOUT SPEAKER, 125, 261, 783
        PAUSE 125
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 220, 880
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 220, 987
        PAUSE 125
        FREQOUT SPEAKER, 250, 1046
        PAUSE 125
        FREQOUT SPEAKER, 250, 880
        PAUSE 125
        FREQOUT SPEAKER, 125, 1174
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 1174
        PAUSE 125
        FREQOUT SPEAKER, 250, 1174
        FREQOUT SPEAKER, 125, 293, 1046
        PAUSE 125
        FREQOUT SPEAKER, 250, 987
        FREQOUT SPEAKER, 125, 783
        FREQOUT SPEAKER, 125, 195, 1174
        FREQOUT SPEAKER, 125, 261, 1046
        FREQOUT SPEAKER, 125, 1046
        FREQOUT SPEAKER, 125, 261, 987
        FREQOUT SPEAKER, 125, 987
        FREQOUT SPEAKER, 375, 880
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 293, 783
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 195, 987
        PAUSE 125
        FREQOUT SPEAKER, 125, 195, 880
        PAUSE 125
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 250, 1318
        FREQOUT SPEAKER, 125, 261, 1174
        PAUSE 125
        PAUSE 250
        PAUSE 125
        PAUSE 125
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 125, 220, 523
        FREQOUT SPEAKER, 250, 587
        FREQOUT SPEAKER, 125, 220, 659
        PAUSE 125
        PAUSE 125
        FREQOUT SPEAKER, 250, 195
        PAUSE 125
        FREQOUT SPEAKER, 125, 195, 293
        PAUSE 125
        PAUSE 125
        PAUSE 500
        GOTO Main  ' Loop forever
    As posted above, the two commands work completely different so one cannot compare them.
    They were designed for different tasks.
    What exactly is your need?
    If you need one tone only, use SOUND and get clear loud TTL wave form of 0-5 volt amplitude. Otherwise you need a lot of amplification. Just a transistor is not enough.
    You did not showed how you connected that transistor. For FREQOUT I guess you need more than a transistor as the filtering is making the square wave look more like a sinus waveform. From 0-5 volt you are getting a sinus of mVolts. So your transistor amplifier should have a lot of gain, and work as a linear amplifier, not like a switch (which makes a lot of distortion).
    I need to play music, standard musical notation.
    For FREQOUT you can specify frequencies and they do work.
    For SOUND you can not specify frequency, so can't use standard musical notations.
    I'm considering writing own "library" for musical note playback.
    The FREQIUT is the way to go.
    You did not post the circuit of transistor amplifier. I suppose you did add a good bias to the transistor, right?
    The audio output after the good filtering I suppose will be of some mVolts, so good amplification is needed. Don't expect to drive directly a loudspeaker but use say an LM386 chip amp or bigger for more watts.
    I even tried to connect external amplifier.
    Freqout has way too many harmonics, at frequencies close to the original sound, so unfortunately, not usable.
    Here's the code, generated by Claude, which does what I need. While it contains only one active, the idea is clear and code can be modified for wider coverage:
    ty;----[16F1937 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1936"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_ON                 ; Program memory code protection is enabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; All VCAP pin functionality is disabled
    cfg2&= _PLLEN_OFF             ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    'nixie led clock electronics direct drive
    ADCON1=%11110011 'enable adc internal reference and justify
    FVRCON=%11001111   'set internal reference to 4.096V
    OSCCON=%11110000 'SET INTOSC TO 8MHZ
    'ANSELE=%00000000 'enable adc input porte.2
    ANSELA=%00000000 'disable ADC on A
    ANSELB=%00000000 'disable ADC on B
    'ANSELD=%00000000 'disable ADC on D
    TRISC=%00000000 'set PORTC as output all
    'TRISD=%00000000 'set PORTD as output all
    TRISB=%00001111 'set PORTB as output all
    TRISA=%00000000 'set PORTA 2 as input, others as output
    TRISE=%00000000  'set PORTE as output all
    WPUB=%00000000 'DISABLE B PULL UPS
    OPTION_REG=%100000000
    LCDCON=%00000000  'disable LCD controller pins
    LCDSE0=%00000000
    LCDSE1=%00000000
    'LCDSE2=%00000000
    DEFINE OSC 32
    PORTA.3 = 0
    ' --- Variables ---
    nCycle  var WORD  ' loop counter
     i      var BYTE  ' note index
    '  Subroutine: PlayNote
    '  Parameters passed via variables (PBP3 style)
    '    nHalf  = half-period in microseconds (WORD)
    '    nCount = number of cycles            (WORD)
    nHalf  var WORD
    nCount var WORD
    GOSUB WaitStart      ' small startup delay
    '  MAIN - play C4 through C5
        ' --- C4  261.63 Hz  half=1911µs  cycles=261 ---
        nHalf  = 1911 : nCount = 261 : GOSUB PlayNote : GOSUB Gap
        ' --- D4  293.66 Hz  half=1703µs  cycles=293 ---
        nHalf  = 1703 : nCount = 293 : GOSUB PlayNote : GOSUB Gap
        ' --- E4  329.63 Hz  half=1516µs  cycles=329 ---
        nHalf  = 1516 : nCount = 329 : GOSUB PlayNote : GOSUB Gap
        ' --- F4  349.23 Hz  half=1432µs  cycles=349 ---
        nHalf  = 1432 : nCount = 349 : GOSUB PlayNote : GOSUB Gap
        ' --- G4  392.00 Hz  half=1276µs  cycles=392 ---
        nHalf  = 1276 : nCount = 392 : GOSUB PlayNote : GOSUB Gap
        ' --- A4  440.00 Hz  half=1136µs  cycles=440 ---
        nHalf  = 1136 : nCount = 440 : GOSUB PlayNote : GOSUB Gap
        ' --- B4  493.88 Hz  half=1012µs  cycles=493 ---
        nHalf  = 1012 : nCount = 493 : GOSUB PlayNote : GOSUB Gap
        ' --- C5  523.25 Hz  half=955µs   cycles=523 ---
        nHalf  = 955  : nCount = 523 : GOSUB PlayNote : GOSUB Gap
        PAUSE 2000           ' 2-second rest before repeating
        GOTO Main
    '  PlayNote: toggles RC0 nCount times with nHalf µs delay
    PlayNote:
        FOR nCycle = 1 TO nCount
            HIGH PORTA.3
            PAUSEUS nHalf
            LOW PORTA.3
            PAUSEUS nHalf
        NEXT nCycle
    '  Gap: 50ms silence between notes (pin stays LOW)
    Gap:
        PORTA.3 = 0
        PAUSE 50
    '  WaitStart: 200ms power-on settle delay
    WaitStart:
        PAUSE 200
  1. Depending on value, SOUND statement leaves port output high
    Last Post: - 5th October 2023, 12:05
  2. Sound polyphony
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 14th November 2007, 05:43
  3. Sound chips
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 5th May 2007, 01:15
  4. recording sound to an IC
    By saturnX in forum Off Topic
    Last Post: - 11th October 2005, 17:44
  5. Sound and sound control with minimal parts
    By bartman in forum General
    Last Post: - 18th January 2005, 14:08
Members who have read this thread : 9
