160 byte framebuffer at 50 fps, internal RAM or external SRAM?
+ Reply to Thread
Results 1 to 4 of 4
    Default 160 byte framebuffer at 50 fps, internal RAM or external SRAM?
    Hello.
    I'm doing a graphic project, where content of WS0010b OLED display will be updated really fast, 50fps at least.
    The framebuffer size is 160 bytes. Will PBPs arraywrite/arrayread operations provide enough speed at 18F running at 64mhz, to read and write that array at that speed, or better to use external, parallel SRAM for that?
    Aug 2011
    Default Re: 160 byte framebuffer at 50 fps, internal RAM or external SRAM?
    Pretty much any external ram is going to be slower than internal storage.
    Bombay, India
    I think the bottleneck will be the serial interface speed (SPI) which is normally used in small OLEDs. I could not find this display WS0010B on searching for it. Unless the PIC supports a SPI DMA engine, the bit banging will slow you down tremendously
    160bytes @ 50Hz is only 64kbits/s (average). Even SHIFTOUT should be able to handle that.
    Running the SPI or MSSP module at a moderate 1Mbit/s will transfer those 160bytes in less than 2ms leaving 18ms for processing between frames.
    Not sure why you're even considering external RAM.
    Even a double buffer should easily fit an 18F series part unless you're using a lot of RAM for other tasks of course.
    Also not sure what part ARRAYREAD plays. Transfering the buffer would be done using a normal loop or, as Jerson mentions, DMA if you want to go the extra mile.
  1. Speed optimization (framebuffer scrolling)
    By HenrikOlsson in forum PBP3
    Last Post: - 12th October 2022, 12:06
  2. Replies: 8
    Last Post: - 20th March 2017, 10:34
  3. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 15:58
  4. 160 Baud aldl scantool
    By ahmed_salah in forum Serial
    Last Post: - 6th August 2008, 22:43
  5. Effects of Current Draw Using Internal VS External PullUps
    By rixtalbert in forum mel PIC BASIC Pro
    Last Post: - 16th September 2006, 10:43
Members who have read this thread : 6
