This code works great for reading 5 sensors however I want to decrease the amount of time it takes to run through this subroutine by not trying to read a sensor if its not being used. My problem starts with the line "if sensor = 1 then" because it thinks I'm trying to compare the value stored in sensor which is not what I want it to do. I need it to compare the port associated with the number against a specific value. Any ideas on how to resolve this issue?
read_sensors:
    for sensor = 0 to 4
    temp_c = 0
    temp_f = 0
    temp_k = 0
    dummy = 0
    dq = 0
    gosub ds_init
    gosub read_temp
    sign_c_array[sensor] = sign_c
    sign_f_array[sensor] = sign_f
    temp_c_array[sensor] = temp_c
    temp_f_array[sensor] = temp_f
    temp_k_array[sensor] = temp_k
    next sensor
ds_init:
    low sensor                              ' Set the data pin low to initialize
    pauseus 500                             ' Wait for more than 480us
    input sensor                            ' Make data pin port an input
    pauseus 100                             ' Wait for more than 60us
    if sensor = 1 then                      ' Is there a DS18B20 detected
        debug cmd,line3,"Not Present"       ' If not set flag indicating so
        SensorMissing = 1
    pauseus 400                             ' Wait for end of presence pulse
    debug cmd,line3,"Present    "           ' Set flag indicating there is a
    SensorMissing = 0                       ' sensor present
read_temp:
       if SensorMissing = 1 then            ' If the sensor is not present load
            temp_c = 32767                  ' these values in place of the
            temp_f = 62181                  ' temperature indicating there is
            temp_k = 60082                  ' a problem with the sensor
            sign_c = "+"
            sign_f = "+"
        owout sensor,1,[$CC,$44]            ' Send start temperature conversion
                                            ' command
        low portb.5                         ' Turn on transistor between rail and
                                            ' data pin
        pause 750                           ' Allow enough time to process Tconv
        high portb.5                        ' Turn off transistor between rail and
                                            ' data pin
        owout sensor,1,[$CC,$BE]            ' Send read scratch pad command
        owin sensor,0,[STR dq\9]            ' Read all 9 bytes and store them in dq
                                            ' array
        raw_temp.Byte0 = dq[0]              ' Isolate raw temperature from the rest
        raw_temp.Byte1 = dq[1]
        gosub get_crc                       ' Calculate the CRC of the data
        gosub convert_temp                  ' Convert raw data into real temps
