Command Line operation ni a BATCH file
+ Reply to Thread
Results 1 to 7 of 7
    SWITZERLAND (french speaking)
    Default Command Line operation ni a BATCH file
    Hi All,
    I'd like to launch the compiler/assembler and the PICKit3 programmer, all in COMMAND LINE mode, in a DOS batch file.
    Unfortunately, I'm getting error messages at compile/assemble time.
    According to Melanie's posts, I have programmed my batch file as here (the PICKit part is left out for now):
    Path C:\Program Files (x86)\PBP3_1;C:\Program Files (x86)\PBP3_1\temp
    PBPX -p16F690 -aMPASMX Blink_16F690.pbp -v
    Obviously, my PBP3 compiler's location is "C:\Program Files (x86)\PBP3_1" and the assembler's one is C:\Program Files (x86)\PBP3_1\temp.
    Launching the BATCH file, I'll get these messages:
Size:  15.0 KBName:  2026-02-16 19_33_28-PBP _ Explorateur de fichiers.jpg
    I get 5 "Access violation" errror windows I can clear and at final, everything seems okay = every thing works (I get the HEX file I can send to the PIC).
    Any idea how I can make things work the "clean way" please?
    Roger
    Default Re: Command Line operation ni a BATCH file
    Problem solved: just needed to run the BATCH file with administrator's rights.
    Roger
    No, still not solved yet
    When the batch file is launched with admin rights (I made a shortcut file to my batch to be able to launch it with admin rights), all HEX, ASM, etc files are not created?!?!?
    Roger
    Default Command Line operation in a BATCH file
    I tried to move my batch file in the PBP folder but the problem still perists.
    Roger
    Default Re: Command Line operation in a BATCH file
    I'm now using MPASMWIN.EXE (even if the assembler's window says "MPASM v5.14") which solved the problem about the warnings.
    Now, is there a way, like for Microcode Studio, to close this assembler's windows once done successfully?
    Name:  2026-02-20 16_36_38-MPASM v5.14.jpg
    I can't find any command line argument doing this for me
    Roger
    try an
    echo/ after the mpasm line in your batch file
  1. FREQOUT command for continuous operation
    By Aussie Barry in forum PBP3
    Last Post: - 22nd September 2016, 06:27
  2. Command Line Compile
    By Normnet in forum PBP Extensions
    Last Post: - 30th August 2009, 03:40
  3. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  4. Command line
    By Bopo in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 09:13
  5. ICProg Command Line
    By crematory in forum General
    Last Post: - 8th August 2005, 14:26
Members who have read this thread : 6
