18F2580 with strange behaviour when using Hserin and RX interrupt
+ Reply to Thread
Results 1 to 8 of 8
    Jul 2024
    Default 18F2580 with strange behaviour when using Hserin and RX interrupt
    Hi guys,
    I'm facing a weird behaviour with my 18F2580 using Hserin and RX interrupts and I was hoping someone could help.
    I'm trying to run a code that when an incoming 2 characters is received, it triggers the interrupt and reads the message.
    Once it reads the message, it goes back the the main routine.
    The issue is that, once it is turned on, it does not show the correct characters being sent.
    However, the interrupt trigger is being done and once it reads the message, goes back to the main routine.
    But if I send a long message, from that point on, it will show the correct characters being sent but no longer goes back to the main routine!
    Not sure why it does not show the correct message in the first place and also, can't understand why it fails to jump from the interrupt routine back to the main routine!
    The message is being sent via bluetooth with a BT module connected directly to the MCU.
    The TX from the MCU is disabled because i only need to receive and not transmit.
    I filmed this behaviour which can be seen in the link below.
    This is the code:
    '*  Name    : IC_3_COMTEST2.PBP                                 *
    '*  Author  :                                                   *
    '*  Notice  : Copyright (c) 2024 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 19/12/2024                                        *
    '*  Notes   : 18F2580 MCU                                       *
    ;----[18F2580 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "18F2580"
      #DEFINE MCU_FOUND 1
      CONFIG  OSC = IRCIO67      ; Internal oscillator block, port function on RA6 and RA7
      CONFIG  FCMEN = ON        ; Fail-Safe Clock Monitor ENABLED
      CONFIG  IESO = OFF         ; Oscillator Switchover mode disabled
      CONFIG  PWRT = OFF         ; PWRT disabled
      CONFIG  BOREN = OFF        ; Brown-out Reset disabled in hardware and software
      CONFIG  BORV = 3           ; VBOR set to 2.1V
      CONFIG  WDT = ON           ; WDT ENABLED (control is placed on the SWDTEN bit)
      CONFIG  WDTPS = 512        ; 1:512
      CONFIG  PBADEN = OFF       ; PORTB<4:0> pins are configured as digital I/O on Reset
      CONFIG  LPT1OSC = OFF      ; Timer1 configured for higher power operation
      CONFIG  MCLRE = OFF        ; RE3 input pin enabled; MCLR disabled
      CONFIG  STVREN = OFF        ; Stack full/underflow will NOT cause Reset
      CONFIG  LVP = OFF          ; Single-Supply ICSP disabled
      CONFIG  BBSIZ = 1024       ; 1K words (2K bytes) boot block
      CONFIG  XINST = OFF        ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
      CONFIG  DEBUG = OFF        ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
      CONFIG  CP0 = OFF          ; Block 0 (000800-001FFFh) not code-protected
      CONFIG  CP1 = OFF          ; Block 1 (002000-003FFFh) not code-protected
      CONFIG  CP2 = OFF          ; Block 2 (004000-005FFFh) not code-protected
      CONFIG  CP3 = OFF          ; Block 3 (006000-007FFFh) not code-protected
      CONFIG  CPB = OFF          ; Boot block (000000-0007FFh) not code-protected
      CONFIG  CPD = OFF          ; Data EEPROM not code-protected
      CONFIG  WRT0 = OFF         ; Block 0 (000800-001FFFh) not write-protected
      CONFIG  WRT1 = OFF         ; Block 1 (002000-003FFFh) not write-protected
      CONFIG  WRT2 = OFF         ; Block 2 (004000-005FFFh) not write-protected
      CONFIG  WRT3 = OFF         ; Block 3 (006000-007FFFh) not write-protected
      CONFIG  WRTC = OFF         ; Configuration registers (300000-3000FFh) not write-protected
      CONFIG  WRTB = OFF         ; Boot block (000000-0007FFh) not write-protected
      CONFIG  WRTD = OFF         ; Data EEPROM not write-protected
      CONFIG  EBTR0 = OFF        ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR1 = OFF        ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR2 = OFF        ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTR3 = OFF        ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
      CONFIG  EBTRB = OFF        ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    OSCCON =%01110010 '8MHz INTOSC
    OSCTUNE=%01000000 '
    DEFINE OSC 8
    INCLUDE "ALLDIGITAL.pbp"
    DEFINE SHOWDIGITAL 1
    Define HSER_BAUD 9600
    'DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH = 1
    DEFINE HSER_SPBRG 12  '
    'DEFINE HSER_CLEAR = On
    RXBYTE  VAR BYTE
    RXFLAG  VAR BIT
    RX1 VAR BYTE
    RX2 VAR BYTE
    RX3 VAR BYTE
    RX4 VAR BYTE
    RX5 VAR BYTE
    RX6 VAR BYTE
    CT			VAR		BYTE
    CT2			VAR		BYTE
    INTFLAG		VAR		BYTE
    MOODCHANGE	VAR		WORD
    'PIE1.5 = 1              ' RCIE
    INTCON = %11000000      ' GIE + PEIE
    PORTA=%00000000
    PORTB=%00000000
    PORTC=%00000000
    TRISA=%00000000
    TRISB=%00000000
    TRISC=%10000000   'RC7 - RX pin as input
    'PORTS & PINS
    A0                  VAR  PORTA.0   '
    A1                  VAR  PORTA.1   '
    A2                  VAR  PORTA.2   '
    A3                  VAR  PORTA.3   '
    A4                  VAR  PORTA.4   '
    A5                  VAR  PORTA.5   '
    A6                  VAR  PORTA.6   '
    LED1                VAR  PORTA.7   '
    B0                  VAR  PORTB.0   '
    B1                  VAR  PORTB.1   '
    B2                  VAR  PORTB.2   '
    B3                  VAR  PORTB.3   '
    LED2                VAR  PORTB.4   '
    B5                  VAR  PORTB.5   '
    B6                  VAR  PORTB.6   '
    B7                  VAR  PORTB.7   '
    C0                  VAR  PORTC.0   '
    C1                  VAR  PORTC.1   '
    C2                  VAR  PORTC.2   '
    C3                  VAR  PORTC.3   '
    C4                  VAR  PORTC.4   '
    C5                  VAR  PORTC.5   '
    IC_TX               VAR  PORTC.6   'TX HARDWARE PIN / Not Used as TX
    IC_RX               VAR  PORTC.7   'RX HARDWARE PIN
    INCLUDE "modedefs.bas"
    '[DISPLAY SETTINGS]*****************************************************************************
    char var byte
    x    var byte
    y    var byte
    BUFF VAR BYTE[16]
    ;use this define for hw i2c
    '#define hwi2c 1
    ;set and uncomment these to use softi2c
    SCL var PortA.6      ' I2C Clock
    SDA var PortC.0      ' I2C Data
    ;set these  to match display
    ssdheight con 3      ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
    ssdwidth  con 127    ; 128 PIXELS WIDE
    sdd1306_addr con $78
    Include "ssd1306_I2C.INC"  ' bring it in
    include "font7x5_18.bas"
    '[INTERRUPT SETTINGS]*****************************************************************************
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INT_LIST  macro    ; IntSource, Label, Type, ResetFlag?
        INT_Handler   RX_INT, _RxISR,   PBP,  yes
        ENDM
        INT_CREATE
        INT_ENABLE    RX_INT  ;enables external (INT) interrupts
    'wsave var byte $20 system ;location for W if in bank0
    'wsave var byte $70 system ;location for W if in bank0
    '..... If any of these next three lines cause an error ...Comment them out to fix the problem...
    '............which variables are needed, depends on the chip you are using.......
    wsave1 var byte $A0 system ;location for W if in bank0
    wsave2 var byte $120 system ;location for W if in bank0
    wsave3 var byte $1A0 system ;location for W if in bank0
    '[INIT]*****************************************************************************
    INIT:
    clear
    PORTB=%00000000
    BIG_TEXT = 0
    PAUSE 1000
    high led1
    high led2
    low led1
    low led2
    PAUSE 500
    gosub glcd_init
    GLCD_CLR
    ARRAYWRITE BUFF,["INIT OK",0]
    GLCDSTR  0,0,BUFF
    PAUSE 500
    '[MAIN ROUTINE]*****************************************************************************
    gosub glcd_init
    GLCD_CLR
    ARRAYWRITE BUFF,["WAITING",0]
    GLCDSTR  0,0,BUFF
    toggle LED1
    gosub calculat
    '[INTERRUPT ROUTINE]*****************************************************************************
    RxISR:
    HSERIN [RX1, RX2, RX3, rx4]
    'ASCII TO DECIMAL CONVERSION
    rx1 = (rx3 - "0") * 10
    rx1 = rx1 + (rx4 - "0")
    gosub glcd_init
    GLCD_CLR
    ARRAYWRITE BUFF,["RX1= ", dec RX1,0]
    GLCDSTR  0,0,BUFF
    PAUSE 1000
    @ INT_RETURN
    '[CONFIRMATION ROUTINE]*****************************************************************************
    calculat:
    if RX1=57 then
    gosub glcd_init
    GLCD_CLR
    ARRAYWRITE BUFF,["GOOD DATA RECEIVED",0]
    GLCDSTR  0,0,BUFF
    PAUSE 500
    high led2
    PAUSE 5000
    LOW led2
    Link for the video showing how it behaves:
    https://www.canva.com/design/DAHBZ6V...ce=sharebutton
    Thanks in advance for any tips on how to get this code working as it is supposed to.
    Default Re: 18F2580 with strange behaviour when using Hserin and RX interrupt
    yet your rx routine wants 4 chars
    what is the actual msg you receive [in ascii chrs] is there a start chr how does the msg terminate /n, /CR, /LF?
    Jul 2024
    Hi Richard,
    thanks for the help.
    According to the information on the display (when set to show the 4 incoming characters), 2 initial characters are being sent as carriage return (10 and 13) from the terminal.
    That is why it's capturing 4 but i only use the last 2.
    Random ramblings and guesses here, take for what it is:
    That's not how it works. The ISR triggers when there's a byte is received. You can't configure it to fire after n character (short of setting up DMA and using that perhaps).
    Typically, you'd write the interrupt to receive one byte at a time, putting them into a buffer (array) while looking for some sort of qualifier for "end of message" (number of characters, time-out, certain byte sequence, whatever). Once that qualifer is met you set a flag signaling the main rotuine that data is available. LCD updates etc is handled outside of the ISR.
    You say that whatever sends the data sends 10,13 first, then two bytes of interest but you're not looking for the 10,13 sequence in order to "sync" and since you have a lot of slow code in the ISR it might get out of sync and therefor get stuck in the ISR since, once the interrupt fires your code expects 4 bytes.
    If it gets 3 it'll sit there waiting for the 4th. Then a new burst of 4 bytes comes a long, where the first one counts as the 4th. Then the code moves on to to update the display while remaining three incoming bytes overflows the UART buffer because you're updating the display and/or executing a massive PAUSE in the ISR.
    another issue
    OSCCON =% 01110010 '8MHz INTOSC OSCTUNE=% 01000000 '
    DEFINE OSC 8
    will enable the PLL making OSC 32MHz
    making the eusart defines incorrect
    and
    the oled display should only be initialised once
    and you dont need to clear the entire screen for every write , just clear the area that needs to be updated
    eg GLCD_CLR 0,1,127,8 ; clear a full width text line
    Jul 2024
    Greetings HenrikOlsson and Richard,
    thank you so much for your help.
    I will make a few changes and run some tests to see if I get it running correctly.
    @Richard, regarding the osc settings, yes, you are correct,however, if I change to Define Osc 32 the code will run slower (tested before with pause 1000 and led blink). Weird things happen with this 18F2580 MCU
    pll only works with primary clock sources , if you set the int-osc as primary clock then it works as expected
    DEFINE OSC 32
        OSCCON =% 01110000 '8MHz INTOSC
    Jul 2024
    Hi Richard,
    you are correct (as always)!
    I thought we had to choose internal insteal of primary since it's set to an internal osc.
  1. Strange WRITECODE behaviour
    By mikebar in forum mel PIC BASIC Pro
    Last Post: - 5th December 2015, 01:43
  2. Strange IT behaviour
    By MikeBZH in forum mel PIC BASIC Pro
    Last Post: - 10th February 2012, 09:00
  3. Strange behaviour
    Last Post: - 8th October 2009, 22:35
  4. Strange Serout Behaviour
    By bluesmoke in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 04:12
  5. strange int behaviour
    By tom in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 15:41
Members who have read this thread : 10
