Converting PBP interrupt to ASM - 18F25K20
+ Reply to Thread
Results 1 to 8 of 8
    Huntsville, AL
    Default Converting PBP interrupt to ASM - 18F25K20
    I have a couple interrupt routines using DT's instant interrupts in PBP that I'd like to convert to asm to reduce execution time. One of the ISRs uses an external interrupt to time pulses and store the results in an array (ppm) and increments to the array index (ppm_n). Bit 4 of ppm_n is set to 0 so that ppm_n rolls over from 15 to 0. I read the array outside of the interrupt and verify the bit ppmwrite hasn't changed while reading the data, else the interrupt could have occured while reading the data.
    This compiles but it appears none of the array values are updating except for index 15, which appears to be randomly assigned and never changes even though the array is cleared at startup. However it appears the index ppm_n is incrementing and ppmwrite is being toggled. Typical output from the code below looks like this (first 16 values are the ppm array, red is ppm_n, and blue is ppmwrite):
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 8 0
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 6 0
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 5 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 3 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 2 0
    I cobbled together the code below from some helpful posts in these forums and the datasheet. I still include "ReEnterPBP-18.bas" since I use that for another ISR that still uses PBP, but that is not included in this test code. I'm not that experienced with asm (yet), so any pointers are greatly appreciated!
    pausetime   var   word
    ppm         var   word[16]
    ppm_n       var   byte
    n           var   byte
    ppmwrite    var   bit
    T3CON = %10110000 'ppm timer: Prescaler = 8:1,  Timer off; bit 5-4 is prescaler (00=1:1, 01=2:1 ... 11=8:1)
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    '----[High Priority PPM Interrupt]----------------------------------------------
    INT_Handler INT0_INT, _PULSE_WIDTH, ASM, yes
    'clear ppm array
    for n=0 to 15
    ppm[n]=0
    next n
    ppm_n=0
    @ bsf     T3CON, TMR3ON   ; Start timer
    @ INT_ENABLE INT0_INT ; enable external (INT) interrupts
    ppmloop:
    @ INT_DISABLE INT0_INT ; disble external (INT) interrupts
    serout2 PIN_OUT,6,[dec ppm[0]," ",dec ppm[1]," ",dec ppm[2]," ",dec ppm[3]," ",dec ppm[4]," ",dec ppm[5]," ",dec ppm[6]," ",dec ppm[7]," ",dec ppm[8]," ",dec ppm[9]," ",dec ppm[10]," ",dec ppm[11]," ",dec ppm[12]," ",dec ppm[13]," ",dec ppm[14]," ",dec ppm[15]," ",dec ppm_n," ",dec ppmwrite,13,10]
    goto ppmloop
    PULSE_WIDTH:
       movff  TMR3L, _pausetime           ; Read LB and store in variable 'pausetime' - also loads TMR3H into buffer
       movff  TMR3H, _pausetime + 1       ; Read HB from buffer
       movf   _ppm_n, W                   ; Get index value from variable 'ppm_n' for array address, store in WREG
       rlncf  WREG, W                     ; Multiply by 2 since ppm array is words (16bit)
       addlw  _ppm                        ; add base address of ppm array to offset in W
       movwf  FSR0                        ; store the calculated address in FSR0
       movf   _pausetime, W               ; load pausetime LB into WREG
       movwf  INDF0                       ; move LB into ppm[ppm_n]
       incf   FSR0                        ; move to next pointer loation for HB
       movf   _pausetime + 1, W           ; load pausetime HB into WREG
       movwf  INDF0                       ; move HB into ppm[ppm_n]
       incf   _ppm_n, f                   ; increment array index variable ppm_n
       bcf    _ppm_n, 4                   ; clear bit 4 so array starts over after index 15 (b1111)
       btg    _ppmwrite                   ; toggle ppmwrite to check if interrupt occured in main program
    INT_RETURN
    Huntsville, AL
    Default Re: Converting PBP interrupt to ASM - 18F25K20
    I might have figured it out. It looks like I wasn't loading the full pointer into FSR0 since it's a 12-bit pointer. Also I hit on the POSTINC0 option, which is nifty. I believe the ISR should be something like this (see below). I am currently assuming that word arrays in PBP are allocated with the low byte in the lower address and the high byte at the next address (I need to verify this). Any errors in the code or any suggestions to consolidate instructions are much appreciated!
    PULSE_WIDTH:
       lfsr   FSR0,  _ppm                 ; Load the full 12-bit address of ppm into FSR0
       addwf  FSR0L, f                    ; Add offset to low byte of pointer
       movlw  0                           ; clear WREG although carry flag is still active in STATUS REGISTER bit 0 (pretty sure that's how it works?)
       addwfc FSR0H, f                    ; Add carry to high byte of pointer
       movf   _pausetime, W               ; Load pausetime LB into WREG
       movwf  POSTINC0                    ; Store pausetime LB in ppm location and automatically increment FSR0
       movf   _pausetime + 1, W           ; Load pausetime HB into WREG
       movwf  INDF0                       ; Store pausetime HB in ppm location
    INT_RETURN
    looks close but if the vars used in asm are not in access ram you still need to ensure the correct bank is set, it may look likes it works depending on where the compiler places your vars but its not safe
    eg
    movf _ppm_n, W // movf takes an 8bit address field, ppm would need to be in the currently set bank
    ditto for bcf,btg etc
    Huntsville, AL
    Thank you for your feedback! The test code seems to work ok, but when I roll this ISR into my main program, it could occur at any time so it seems setting the correct bank would be important.
    What I have now puts variable ppm_n at 000000DFh and ppm at 000001F6h. Since ppm is 16 words (32 bytes), I believe the ppm array rolls over into bank 2. The next variable starts at 00000216h, so I believe that it did roll over.
    It looks like I'm not completely filling bank 2 according to the .LST file, so would it be better to allocate the variables ppm and ppm_n to bank 3 and have this particular ISR always point to bank 3? Or should I add in some operations to point to the correct bank? It seems calculating the correct bank could require more time especially if the array straddles different banks?
    Thanks again for the feedback!
    The Access Bank consists of the first 96 bytes of memory(00h-5Fh) so if you create your asm vars in that space you can use the opcode access field rather than needing to switch banks
    eg
    ppm_n var byte $5f [in access bank]
    pausetime var byte $5d [in access bank]
    asm
    movf _ppm_n, W ,a
    movf _pausetime, W,a
    or let pbp store the vars anywhere it likes
    ppm_n var byte [anywhere]
    pausetime var byte
    asm
    banksel _ppm_n
    movf _ppm_n, W
    banksel _pausetime
    movf _pausetime, W
    or store all the asm vars in the same bank
    ppm_n var byte bank0
    pausetime var byte bank0
    asm
    banksel 0
    movf _ppm_n, W
    movf _pausetime, W
    Huntsville, AL
    Thanks for the insight! I ended up putting all the variables used in the ISR in bank 3 and starting the interrupt with "banksel _ppm_n" in case I every move them to a different bank. I may not need the subsequent "movlw 0" and "addwfc FSR0H, f" operations since the variables are now in the same bank?
    I also consolidated a few operations. The ISR now is able to initiate, run, and return to the main program in ~127 instruction cycles, which is great:
    PULSE_WIDTH:
    asm
       banksel _ppm_n                     ; Variables used in interrupts are stored one bank via config definition - can change bank # as long as vars are in same bank
       rlncf  WREG, W                     ; Multiply WREG by 2 since ppm array is words (16bit)
       addwf  FSR0L, f                    ; Add offset from WREG to low byte of pointer
       movff  TMR3L, POSTINC0             ; Move TMR0L into ppm and automatically increment FSR0
       movff  TMR3H, INDF0                ; Move TMR0H into ppm
       clrf   TMR3H                       ; reset TMR0H by loading 0 into TMR3H buffer
       clrf   TMR3L                       ; reset TMR0 by loading 0 into low byte and pushing in high byte buffer
    INT_RETURN
    endasm
    Now I'm working on converting the other ISR to asm, and am having some issues. I suspect it's how I'm trying to update the outputs on PORTC or how I'm trying to preload the highbyte of timer1 (timer1 is configured for two 8-bit R/W operations). I think the issues with the code are in red? PORTC is configured entirely as outputs and is updated with a precalculated byte from motor[mcount] that has zeros for the 4 LSBs (i.e. %XXXX0000). The value in preload[mcount] is also precalculated. Any thoughts or suggestions are much appreciated!
    mcount       var byte     bank3
    motor        var BYTE[6]  bank3
    preload      var BYTE[7]  bank3
    T1CON = %00010000
    TRISC = %00000000
    '----------[High Priority Motor Interrupt]------------
    INT_Handler TMR1_INT, _MOTOR_CONTROL, ASM, yes
    INT_CREATE
    MOTOR_CONTROL:
       banksel _mcount                    ; Variables used in interrupts are stored one bank via config definition - can change bank # as long as vars are in same bank
       movf   _mcount, W                  ; Get index value from variable 'mcount' for array address, store in WREG
       lfsr   FSR0,  _motor               ; Load the full 12-bit address of motor array into FSR0
       movlw  0                           ; clear WREG although carry flag is still active in STATUS REGISTER bit0
       MOVFF  INDF0, LATC                 ; Change PORTC output to adjust which motors are powered
       incf   _mcount, f                  ; Increment mcount
       lfsr   FSR0,  _preload             ; Load the full 12-bit address of preload array into FSR0
       MOVFF  INDF0, TMR1H                ; Load preload byte into TMR1H
    INT_RETURN
    endasm
    whether the vars are in the same bank or not is irrelevant with indirect addressing, the point is that with pic18 chips an array can be more than 255 bytes in length and may cross a bank boundary. when adding an 8 bit offset to a 16 bit fsr register it is always prudent to check if the addition caused the low byte to overflow and increment the high byte if it did.
    bugs caused by incorrect fsr manipulation are tricky to find
    the code you have posted is not complete or even compliable i have no idea what you are even trying to do
    as an example this is what i came up with for your first question
      CONFIG  FOSC=INTIO67, FCMEN=OFF, IESO=OFF, PWRT=OFF, BOREN=SBORDIS, BORV=18
      CONFIG  WDTEN=ON, WDTPS=512, CCP2MX=PORTC, PBADEN=OFF, LPT1OSC=OFF, HFOFST=ON
      CONFIG  MCLRE=ON, STVREN=ON, LVP=OFF, XINST=OFF, DEBUG=OFF, CP0=OFF, CP1=OFF
      CONFIG  CP2=OFF, CP3=OFF, CPB=OFF, CPD=OFF, WRT0=OFF, WRT1=OFF, WRT2=OFF
      CONFIG  WRT3=OFF, WRTC=OFF, WRTB=OFF, WRTD=OFF, EBTR0=OFF, EBTR1=OFF
      CONFIG  EBTR2=OFF, EBTR3=OFF, EBTRB=OFF
    DEFINE OSC 16
    pausetime   var   word   bank0
    ppm         var   word[16]
    aflags      var   byte   bank0
    ppmwrite    var   aflags.0
    LED         VAR   LATA.0
    T3CON = % 10110000 'ppm timer: Prescaler = 8:1,  Timer off; bit 5-4 is prescaler (00=1:1, 01=2:1 ... 11=8:1)
    TRISA = % 11111110
    ANSEL = $CF
    OSCCON = $70
    RCSTA  = $90   ' Enable serial port & continuous receive
    TXSTA  = $20   ' Enable transmit, BRGH = 0
    SPBRG  = 25    ' 38400 Baud @ 16MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
    ;INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    PAUSE 1000
    HSErout  [ "READY",13,10]
    ppm_n=0
    ppmloop:
        if   ppmwrite then
            ;HSErout [dec ppm_N,13,10]
            HSErout [13,10,13,10]
    ;  print timer value at capture
            HSErout [dec ppm[0]," ",dec ppm[1]," ",dec ppm[2]," ",dec ppm[3]," ",dec ppm[4]," ",dec ppm[5]," ",_
            dec ppm[6]," ",dec ppm[7]," ",dec ppm[8]," ",dec ppm[9]," ",dec ppm[10]," ",dec ppm[11]," ",dec ppm[12]," ",_
            dec ppm[13]," ",dec ppm[14]," ",dec ppm[15],13,10]
    ;   print interval between interrupts
            HSErout [dec ppm[1]- ppm[0]  ," "]
            HSErout [dec ppm[3]- ppm[2]  ," "]
            HSErout [dec ppm[5]- ppm[4]  ," "]
            HSErout [dec ppm[7]- ppm[6]  ," "]
            HSErout [dec ppm[9]- ppm[8]  ," "]
            HSErout [dec ppm[11]- ppm[10]  ," "]
            HSErout [dec ppm[13]- ppm[12]  ," "]
            HSErout [dec ppm[15]- ppm[14]  ,13,10]
            intcon.1=0     ;clr int0 flag
            ppmwrite = 0
    goto ppmloop
    PULSE_WIDTH:
       BTG LATA,0,A
       banksel 0
       lfsr   FSR0,  _ppm                 ; set fsr0
       rlncf  _ppm_n, W                   ; Multiply index by 2 since ppm array is words (16bit)
       addwf  FSR0L, F                    ; Add offset to low byte of pointer
       addwfc FSR0H, F                    ; Add carry to high byte of pointer
       incf   _ppm_n,F                    ; increment index ppm_n
       BTFSS  _ppm_n,  4
       GOTO WWW
       clrf    _ppm_n                     ; clear index after index == 16
       bsf    _aflags,0                   ; set ppmwrite to signal main program  data captured
    WWW
     INT_RETURN
    Name:  Screenshot 2026-02-13 194242.png
  1. Multi servo interrupt program in Mikro Basic converting to PBP
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2015, 18:17
  2. 16F1827 ASM Interrupt
    By abbtech in forum mel PIC BASIC Pro
    Last Post: - 16th February 2011, 07:47
  3. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  4. Replies: 3
    Last Post: - 16th October 2007, 01:01
  5. ASM Interrupt
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2004, 21:06
Members who have read this thread : 6
