Converting PBP interrupt to ASM - 18F25K20
+ Reply to Thread
Results 1 to 5 of 5
    Huntsville, AL
    Default Converting PBP interrupt to ASM - 18F25K20
    I have a couple interrupt routines using DT's instant interrupts in PBP that I'd like to convert to asm to reduce execution time. One of the ISRs uses an external interrupt to time pulses and store the results in an array (ppm) and increments to the array index (ppm_n). Bit 4 of ppm_n is set to 0 so that ppm_n rolls over from 15 to 0. I read the array outside of the interrupt and verify the bit ppmwrite hasn't changed while reading the data, else the interrupt could have occured while reading the data.
    This compiles but it appears none of the array values are updating except for index 15, which appears to be randomly assigned and never changes even though the array is cleared at startup. However it appears the index ppm_n is incrementing and ppmwrite is being toggled. Typical output from the code below looks like this (first 16 values are the ppm array, red is ppm_n, and blue is ppmwrite):
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 8 0
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 6 0
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 5 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 3 1
    0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 29184 2 0
    I cobbled together the code below from some helpful posts in these forums and the datasheet. I still include "ReEnterPBP-18.bas" since I use that for another ISR that still uses PBP, but that is not included in this test code. I'm not that experienced with asm (yet), so any pointers are greatly appreciated!
    pausetime   var   word
    ppm         var   word[16]
    ppm_n       var   byte
    n           var   byte
    ppmwrite    var   bit
    T3CON = %10110000 'ppm timer: Prescaler = 8:1,  Timer off; bit 5-4 is prescaler (00=1:1, 01=2:1 ... 11=8:1)
    INCLUDE "DT_INTS-18.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP interrupts
    '----[High Priority PPM Interrupt]----------------------------------------------
    INT_Handler INT0_INT, _PULSE_WIDTH, ASM, yes
    'clear ppm array
    for n=0 to 15
    ppm[n]=0
    next n
    ppm_n=0
    @ bsf     T3CON, TMR3ON   ; Start timer
    @ INT_ENABLE INT0_INT ; enable external (INT) interrupts
    ppmloop:
    @ INT_DISABLE INT0_INT ; disble external (INT) interrupts
    serout2 PIN_OUT,6,[dec ppm[0]," ",dec ppm[1]," ",dec ppm[2]," ",dec ppm[3]," ",dec ppm[4]," ",dec ppm[5]," ",dec ppm[6]," ",dec ppm[7]," ",dec ppm[8]," ",dec ppm[9]," ",dec ppm[10]," ",dec ppm[11]," ",dec ppm[12]," ",dec ppm[13]," ",dec ppm[14]," ",dec ppm[15]," ",dec ppm_n," ",dec ppmwrite,13,10]
    goto ppmloop
    PULSE_WIDTH:
       movff  TMR3L, _pausetime           ; Read LB and store in variable 'pausetime' - also loads TMR3H into buffer
       movff  TMR3H, _pausetime + 1       ; Read HB from buffer
       movf   _ppm_n, W                   ; Get index value from variable 'ppm_n' for array address, store in WREG
       rlncf  WREG, W                     ; Multiply by 2 since ppm array is words (16bit)
       addlw  _ppm                        ; add base address of ppm array to offset in W
       movwf  FSR0                        ; store the calculated address in FSR0
       movf   _pausetime, W               ; load pausetime LB into WREG
       movwf  INDF0                       ; move LB into ppm[ppm_n]
       incf   FSR0                        ; move to next pointer loation for HB
       movf   _pausetime + 1, W           ; load pausetime HB into WREG
       movwf  INDF0                       ; move HB into ppm[ppm_n]
       incf   _ppm_n, f                   ; increment array index variable ppm_n
       bcf    _ppm_n, 4                   ; clear bit 4 so array starts over after index 15 (b1111)
       btg    _ppmwrite                   ; toggle ppmwrite to check if interrupt occured in main program
    INT_RETURN
    Huntsville, AL
    Default Re: Converting PBP interrupt to ASM - 18F25K20
    I might have figured it out. It looks like I wasn't loading the full pointer into FSR0 since it's a 12-bit pointer. Also I hit on the POSTINC0 option, which is nifty. I believe the ISR should be something like this (see below). I am currently assuming that word arrays in PBP are allocated with the low byte in the lower address and the high byte at the next address (I need to verify this). Any errors in the code or any suggestions to consolidate instructions are much appreciated!
    PULSE_WIDTH:
       lfsr   FSR0,  _ppm                 ; Load the full 12-bit address of ppm into FSR0
       addwf  FSR0L, f                    ; Add offset to low byte of pointer
       movlw  0                           ; clear WREG although carry flag is still active in STATUS REGISTER bit 0 (pretty sure that's how it works?)
       addwfc FSR0H, f                    ; Add carry to high byte of pointer
       movf   _pausetime, W               ; Load pausetime LB into WREG
       movwf  POSTINC0                    ; Store pausetime LB in ppm location and automatically increment FSR0
       movf   _pausetime + 1, W           ; Load pausetime HB into WREG
       movwf  INDF0                       ; Store pausetime HB in ppm location
    INT_RETURN
    looks close but if the vars used in asm are not in access ram you still need to ensure the correct bank is set, it may look likes it works depending on where the compiler places your vars but its not safe
    eg
    movf _ppm_n, W // movf takes an 8bit address field, ppm would need to be in the currently set bank
    ditto for bcf,btg etc
    Huntsville, AL
    Thank you for your feedback! The test code seems to work ok, but when I roll this ISR into my main program, it could occur at any time so it seems setting the correct bank would be important.
    What I have now puts variable ppm_n at 000000DFh and ppm at 000001F6h. Since ppm is 16 words (32 bytes), I believe the ppm array rolls over into bank 2. The next variable starts at 00000216h, so I believe that it did roll over.
    It looks like I'm not completely filling bank 2 according to the .LST file, so would it be better to allocate the variables ppm and ppm_n to bank 3 and have this particular ISR always point to bank 3? Or should I add in some operations to point to the correct bank? It seems calculating the correct bank could require more time especially if the array straddles different banks?
    Thanks again for the feedback!
    The Access Bank consists of the first 96 bytes of memory(00h-5Fh) so if you create your asm vars in that space you can use the opcode access field rather than needing to switch banks
    eg
    ppm_n var byte $5f [in access bank]
    pausetime var byte $5d [in access bank]
    asm
    movf _ppm_n, W ,a
    movf _pausetime, W,a
    or let pbp store the vars anywhere it likes
    ppm_n var byte [anywhere]
    pausetime var byte
    asm
    banksel _ppm_n
    movf _ppm_n, W
    banksel _pausetime
    movf _pausetime, W
    or store all the asm vars in the same bank
    ppm_n var byte bank0
    pausetime var byte bank0
    asm
    banksel 0
    movf _ppm_n, W
    movf _pausetime, W
  1. Multi servo interrupt program in Mikro Basic converting to PBP
    By queenidog in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2015, 18:17
  2. 16F1827 ASM Interrupt
    By abbtech in forum mel PIC BASIC Pro
    Last Post: - 16th February 2011, 07:47
  3. 18F2480 asm interrupt
    By Richard Storie in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 20:40
  4. Replies: 3
    Last Post: - 16th October 2007, 01:01
  5. ASM Interrupt
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2004, 21:06
Members who have read this thread : 4
