LCDOUT command followed by variable data
+ Reply to Thread
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default LCDOUT command followed by variable data
    This must be recurrent subject but/and I can't recall how to handle this.
    My project is about displaying time and adapting the output format to the number of digits to display adjusting mainly the number of spaces.
    Since each LCDOUT command is 47 WORDs heavy, I'd like to avoid having to repeat this command all over my program.
    This is a piece of my current code where one can see that I need to repeat the LCDOUT command often to fit the placement of characters.
    ' Display time in "0:00:00" format
    IF Hours > 0 THEN    ' " 0:00:00"
        LCDOUT $FE,$2," ",DEC Hours,":",DEC2 Minutes,":",DEC2 Seconds
    IF Minutes > 9 THEN ' "   00:00"
        IF LapDisplay THEN 'Lap is displayed
            IF Lap > 9 THEN 'Lap is 2 characters wide
                LCDOUT $FE,2,DEC2 Lap," ",DEC Minutes,":",DEC2 Seconds
            ELSE 'Lap is 1 character wide
                LCDOUT $FE,2,DEC1 Lap,"  ",DEC Minutes,":",DEC2 Seconds
        ELSE 'no Lap display
            LCDOUT $FE,2,"   ",DEC Minutes,":",DEC2 Seconds
    IF Minutes >= 0 THEN    ' "    0:00"
        IF LapDisplay THEN
            IF Lap > 9 THEN
    How can I set a number of SPACEs by the mean of a variable?
    Is there another way to achieve this?
    Roger
    Default Re: LCDOUT command followed by variable data
    I assume you are trying to achieve something like this where the minutes/seconds remain at a fixed location regardless of the other formatted field widths in either lap mode or not
    Name:  Screenshot 2026-03-12 154522.png
    its quite simple if you use a frame buffer for the lcd line and designate a frame address for each element to show, the fixed elements [that never change] can be set once off at code startup. you then just need to update each changeable element according to the rules/mode that currently apply when necessary. the display is updated from the buffer when necessary. its not only much faster it uses considerably less code space
           LCDBUFF VAR BYTE[12]
           lsecD0 var byte ext
           lminD0 var byte ext
           lhrsD0 var byte ext
           lapdD0 var byte ext
           lsecD1 var byte ext
           lminD1 var byte ext
           lhrsD1 var byte ext
           lapdD1 var byte ext
           LapDisplay VAR BYTE
           Lap VAR BYTE
     clear
    asm
    lsecD1 =  _LCDBUFF + 8
    lsecD0 =  _LCDBUFF + 9
    lminD1 =  _LCDBUFF + 5
    lminD0 =  _LCDBUFF + 6
    lhrsD0 =  _LCDBUFF + 3
    lhrsD1 =  _LCDBUFF + 4
    lapdD1 =  _LCDBUFF
    lapdD0 =  _LCDBUFF + 1
    endasm
        arraywrite LCDBUFF,["LL h:mm:ss",0]
        GOSUB ResetTime
        GOSUB StartTimer
        GOSUB update
        pause 2000
        hserout [ "Ready",13,10]
        Minutes = 8
        LapDisplay = 0
        Seconds = 55
        hours = 9
        IF MinutesChanged THEN
        LapDisplay =   !LapDisplay
        MinutesChanged =0
        IF SecondsChanged THEN
            lap=lap+1
            led=!led
            GOSUB update
            LCDout $FE,2, str LCDBUFF ;
            SecondsChanged = 0
    update:
        lsecD1 = seconds dig 1 + "0"    ;leading zero
        lsecD0 = seconds dig 0 + "0"
        lminD1 = Minutes dig 1 + "0"    ;leading zero
        lminD0 = Minutes dig 0 + "0"
        IF   LapDisplay THEN
              if (lap dig 1 ) then           ;two digits left justify
                lapdD1 = lap dig 1 + "0"
                lapdD0 = lap dig 0 + "0"
              else                           ;one digits left justify
                lapdD1 = lap dig 0 + "0"
                lapdD0 = " "
              lhrsD1 = " "
              lhrsD0 = " "
              IF   lminD1 == "0"  THEN   lminD1 = " " ;NO leading zero
              lhrsD1 = ":"
              lhrsD0 = Hours dig 0 + "0"
              lapdD1 = " "
              lapdD0 = " "
    Thanks Richard.
    I think I get the idea.
    Is it mandatory to use ASM?
    I'd prefer not use it since I have no knowledge with this
    Roger
    no , you can create your alias names for the array address' in the buffer in any way that you prefer or just use array notation and have no alias' at all
    Thanks a lot Richard!
    It works like a charm and I can spare a lot of memory space not having to desperately repeat code consuming commands.
    I should have first, but I totally forgot to give a look to the PBP manual:
    Name:  2026-03-15 15_54_15-2026-03-15 15_52_42-PICBasicPro_Compiler-Manual_2013.pdf - [PICBASIC PRO™ Co.jpg
    May I ask what the semicolon at the end of the LCDOUT command does? I tried with and without and can't see the difference.
    LCDBUFF VAR BYTE[8]
    LCDBUFF[0] = "0"
    LCDBUFF[1] = "1"
    LCDBUFF[2] = "2"
    LCDBUFF[3] = "3"
    LCDBUFF[4] = "4"
    LCDBUFF[5] = "5"
    LCDBUFF[6] = "6"
    LCDBUFF[7] = "7"
    MAIN:
        LCDOUT $FE,2, STR LCDBUFF ;
        GOTO MAIN
    Roger
    comments begin with an apostrophe or a semicolon, so its a blank comment
    Sorry for my dumb question!
    I'm mixing things up between PBP and another programming language where the semicolon supresses the CR/LF (Liberty Basic).
    Sorry...
    Roger
    I would be too worried about it, afaics it's totally undocumented for pbp and if you don't do much asm work you may rarely come across its usage
    I'm using this for such cases:
    topline: 'top line updater sub
    ofs=pos*16 'modify position offset
    for x=0 to 15
    i2cread sda, scl, adr, x+ofs, [y] 'write from eeprom
    tline[x]=y 'write into array
    next
    lcdout $FE, $02 ' top row
    for y=0 to 15
    lcdout tline[y]
    next
    This is for top row and have similar for botton row.
  1. LCDOUT with a LONG Variable
    By MarkEngineer in forum mel PIC BASIC Pro
    Last Post: - 16th January 2015, 16:31
  2. Newbie - LCDOUT command
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 16th December 2010, 23:45
  3. LCD without LCDOUT command
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 14:22
  4. LCDout Command causes Interrupt!!??
    Last Post: - 31st March 2005, 04:18
  5. LCDout Command w/ LCD 4x40 display
    By beto in forum mel PIC BASIC Pro
    Last Post: - 21st January 2005, 01:22
Members who have read this thread : 14
