16F18446 - setting baudrate for HW EUSART
+ Reply to Thread
Results 1 to 6 of 6
    SWITZERLAND (french speaking)
    Default 16F18446 - setting baudrate for HW EUSART
    Hi All,
    I had an example from Richard lately where he configured my 16F18446 HW serial's port.
    I didn't pay that much attention to it...
    Now that I'm looking closer on "how he did it", I can't figure it out.
    So I went to "visit" the DS and after lots of calculations and trials, I'm still stuck.
    This is an extract from Richard's code (as said from another thread/project), the piece of code I'm working on.
    ' ====== PIC 16F18446 FUSES =======================================================================
    ' Internal oscillator
        __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
        __config _CONFIG2, _MCLRE_ON & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_SBOREN & _BORV_LO & _ZCDDIS_OFF & _PPS1WAY_OFF & _STVREN_ON
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
    @ ERRORLEVEL -306
    @ ERRORLEVEL -202
    ' ====== DEFINES / REGISTERS ======================================================================
    DEFINE OSC 32
    DEFINE ADC_BITS 12      'Number of bits in ADCIN result
    DEFINE HSER_TXSTA 24h   'Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1   'Clear overflow automatically
    BAUDCON.3 = 1     'Enable 16 bit baudrate generator
    ' Baudrates @ 32MHz
    ' 9600
    'DEFINE HSER_SPBRG 832
    'SP1BRGH = 51
    ' 19200
    ''DEFINE HSER_SPBRG 416
    'SP1BRGH = 25
    ' 57600
    'DEFINE HSER_SPBRG 138
    SP1BRGH = 0
    ' 115200
    'DEFINE HSER_SPBRG 68
    'SP1BRGH = 0
    ' ====== VARIABLES ================================================================================
    RC3PPS = 15 'TX PORTC.3 - set RC3 to EUSART TX
    ' ====== TEST PROGRAM =============================================================================
    HW_SERIAL:
        HSerout ["Hello World!",13,10]
        HSerout ["Testing...",13,10]
        PAUSE 1000
        GOTO HW_SERIAL:
    While the settings for baudrates 57600 and 115200 work perfectly, I can't make it work for slower baudrates like 19200 or even 9600.
    I tried to follow the DS and, even if in Richard's example some values don't chage like for instance the SP1BRGH on, I thought I should use the following formula.
    It doesn't work.
    But looking at the baudrate examples table, I can't find the difference for all proposed baudrates.
    Can anyone please explain whre I'm missing the point (or points)?
    Roger
    Default Re: 16F18446 - setting baudrate for HW EUSART
    when you get a result like
    DEFINE HSER_SPBRG 832 you realize something is very wrong since an 8 bit register can not accept that value ever
    you have enabled the 16 bit baud rate generator in every case
    for 19200
    SP1BRGL = 160:SP1BRGH = 1
    for 9600
    SP1BRGL = 64:SP1BRGH = 3
    BAUDCON.3 = 0 '8 bit baudrate generator
    for 9600
    SP1BRGH = 51
    for 19200
    SP1BRGH = 25
    its probably better to say
    there are two baudrate clock source dividers brgh=0 ; fosc/64 and brgh=1 ; fosc/16 and
    and you have the choice of 8 or 16 bit baud rate generators, so 4 options for every baud rate
    brgh=1
    for 19200
    for 9600
    brgh=0
    for 19200
    SP1BRGL = 103:SP1BRGH =0
    for 9600
    SP1BRGL = 207:SP1BRGH = 0
    brgh=1
    for 9600
    SP1BRG = 207
    for 19200
    SP1BRG = 103
    brgh=0
    for 9600
    SP1BRG = 51
    for 19200
    SP1BRG = 25
    Thanks a lot Richard.
    All your settings work like a charm
    Still a question: why would one choose the 8 bit baudrate generator - seems less accurate, no?
    Roger
    in reality accuracy is not always critically important, 1% or larger errors still work well in 90% of cases for tty serial transmission.
    8bit generator results can be equally accurate anyway.
    if you want to switch between rates rapidly a 8bit change is twice as quick to implement as a 16 bit one
    Thanks, Richard
    Roger
  1. 16F18446 - limit program memory size for burning time saving
    Last Post: - 22nd December 2024, 21:44
  2. 16F18446 - maybe missing some registers settings
    Last Post: - 20th December 2024, 17:43
  3. Blinker for 16F18446 - OSC settings and PORT addressing
    Last Post: - 10th February 2024, 13:40
  4. HSER baudrate
    By pedja089 in forum Serial
    Last Post: - 7th August 2011, 19:46
  5. different baudrate
    By danial in forum Serial
    Last Post: - 2nd February 2010, 11:37
Members who have read this thread : 12
