DS3231 code using hardware I2C capabilities?
+ Reply to Thread
Results 1 to 4 of 4
    Default DS3231 code using hardware I2C capabilities?
    Hello.
    I'm using DS3231, but I'm also running MIBAM on the same chip, so it screws up I2CREAD/I2CWRITE statements. Have anyone succeed with using MSSP for interacting with DS3231 ?
    Default Re: DS3231 code using hardware I2C capabilities?
    The connection for this site is not secure
    support.melabs.com uses an unsupported protocol.
    ERR_SSL_VERSION_OR_CIPHER_MISMATCH
    Tried different browsers/proxies/etc.
    it works spasmodically theses days. [one more nail in pbp coffin]
    i find it will work with edge or chrome , sometimes incognito window works better
    ;*  Name    : I2C EEPROM                                        *
    ;*  Author  : Daniel T. Barber                                  *
    ;*  Notice  : Copyright (c) 2018                                *
    ;*          : No expressed or implied reliability               *
    ;*  Date    : 1/25/2018                                         *
    ;*  Version : 1.0                                               *
    ;*  Notes   : Written for PIC16F1877. If using a differnt PIC   *
    ;*          : adjust MSSP Module Variables consistent with      *
    ;*          : the specific PIC datasheet                        *
    ;*          : Written for use with LabX-1 development board     *
    ;*          : and 24LC64 EEPROM (WORD size memory addressing)   *
    ;*          : Adjust CTRL address value as necessary            *
    ;*          : Software I2C routines are for debugging           *
    ;*          : If necessary, uncommment routines in Main Code    *
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = ON
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    define OSC 64
    OSCCON = %11110000
    osctune.6=1
    ANSELb = 0
    ANSELA = 0
    ANSELC = 0
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    Define LCD_Bits 4
    DEFINE LCD_LINES 4
    Define LCD_Commandus 2000
    Define LCD_DATAUS 50
    ;************ LCD Instruction Constants & Variables *************
    Cmd                 Con     $FE     ;Used to send instructions to LCD
    CLR                 Con     $01     ;Clears LCD & Homes Cursor
    Cursor_Off          Con     $0C     ;Turns OFF Cursor
    Cursor_Underline    Con     $0E     ;Turns on Underline cursor
    Cursor_Block        Con     $0F     ;Turns on Blinking block cursor
    Cursor_Right        Con     $14     ;Advance cursor 1 space to right
    Cursor_Left         Con     $10     ;Advance cursor 1 space to left
    Home                Con     $02     ;Sends Cursor to Home position
    'LCD_PWR             VAR     PORTD.7 ;Connects LCD to VCC
    Line_1              Con     $80     ;Position Cursor at beginning of line 1
    Line_2              Con     $C0     ;Position Cursor at beginning of line 2
    Scroll_Left         Con     $18     ;Scroll all lines 1 space to left
    Scroll_Right        Con     $1C     ;Scroll all lines 1 space to right
    Blank_Display       Con     $08     ;Blank display without clearing
    Restore_Display     Con     $0C     ;Restores display with cursor hidden (same as Cursor_Off)
    CG_RAM	            Con	    $40     ;Special-character RAM, address 0.
    DD_RAM	            Con	    $80     ;Display RAM, address 0
    ;************ I2C Variables ************
    SCL     VAR     PORTC.3    ; Clock pin
    SDA     VAR     PORTC.4    ; Data pin
    ;**************** General Variables ****************
    I       VAR    word    ;General purpose counter
    ;**************** I2C Controller Variables ****************
    CTRL        Con      $A0     ;Specific address for this I2C device
    Address_B   Var      byte    ;Use with EEPROM using byte memory addresses
    Address_W   Var      Word    ;Use with EEPROM using word memory addresses
    Data_Out_B  VAR      byte    ;Byte Data to be shifted out
    Data_Out_W  VAR      word    ;Word Data to be shifted out
    Data_In_B   Var      byte    ;Byte Data to be shifted In
    Data_In_W   Var      word    ;Word Data to be shifted In
    I2C_DATA    var      byte    ;Hardare I2C variable
    tries       var      byte
    i2c_error    var      byte
    ;**************** Hardware I2C Variables ****************
    CTRL_W          con     $A0
    CTRL_R          con     $A1
    ;************ MSSP Module Variables *************
    WCOL        var     SSP1CON1.7   ;Write collision indicator
    SSPOV       var     SSP1CON1.6   ;Receive overflow indicator
    SSPEN       var     SSP1CON1.5   ; I2C Serial Port Enable
    ACKSTAT     var     SSPCON2.6   ;Slave ACK Response: 1 = ACK received, 0 NACK received
    ACKDT       var     SSPCON2.5   ;Master ACK Response: 1 = send ACK, 0 send NACK
    ACKEN       var     SSPCON2.4   ;Send the Master ACK Response
    RCEN        var     SSPCON2.3   ;Set Master to Receive Mode - Auto clears at end of receive
    PEN         var     SSPCON2.2   ;Send Stop Sequence
    RSEN        var     SSPCON2.1   ;Send Repeated Start Sequence
    SEN         var     SSPCON2.0   ;Send Start Sequence
    TX_Stat     var     SSPSTAT.2   ;Status of TX Sequence: 1 = TX in progress, 0 = TX finished
    BF          var     SSPSTAT.0   ;Buffer Full Status bit: 1 = Receive Complete, 0 = Receive not complete
    SSPIF       var     PIR1.3      ;Serial Port Interrupt flag: 1 = operation complete
    ;************ Configure MSSP Module *************
    SSP1CON1 = $28    ;Master Mode
    SSPEN = 1       ; I2C enabled
    SSPSTAT = $80   ;100 KHz bus
    SSPADD = $26   ;Set Baud Rate
    ;************ Initialize *************
     PAUSE 1000
     Gosub Initialize_LCD
     PAUSE 100
    ;************ Main Code *************
    do
    ;Software I2C routines
    ;Gosub Software_I2C_WB  ;Write byte sized data using PPB commands
    ;Gosub Software_I2C_RB  ;Read byte sized data using PPB commands
    ;Gosub Software_I2C_WW  ;Write Word sized data using PPB commands
    ;Gosub Software_I2C_RW  ;Read Word sized data using PPB commands
    ;Hardware I2C routines
    gosub Hardware_I2C_WB   ;Write byte sized data using MSSP
    gosub Hardware_I2C_RB   ;Read byte sized data using MSSP
    gosub Hardware_I2C_WW   ;Write word sized data using MSSP
    gosub Hardware_I2C_Rw   ;Read word sized data using MSSP
    loop
    ;************ Sub-Routines ************
    ;************ Initialize LCD ************
    Initialize_LCD:
    '    high LCD_PWR    ;Turn on LCD
            pause 1000 ;Wait for LCD to power up
                Lcdout Cmd, Clr
                    lcdout CMD,Cursor_off
                        lcdout CMD, Line_1 + 5,  "I2C Demo"
                            Pause 3000   ;Display message for 3 seconds
                                 lcdout CMD,clr  ;Clear display
    ;************ Software I2C Byte Write *************
    Software_I2C_WB:  ;Write byte sized data using PPB commands
      SSPEN = 0 ;MSSP module off
      Lcdout Cmd, Clr
      lcdout CMD, Line_1 + 2,"Software I2C"
      lcdout CMD, Line_2, "Write Byte Variables"
      pause 2000
       For I = 0 to 5 Step 1
           address_W = I  ;Address_W is a word size variable
                Data_Out_B = I * 10   ;Data_Out_B is byte size variable
                   i2cwrite SDA, SCL, $A0, address_W,[Data_Out_B]
                        Pause 10
                            Lcdout Cmd, Clr
                                lcdout CMD, Line_1,  "Write Address = ", dec address_W
                                    lcdout CMD, Line_2, "Byte Data = ", dec Data_Out_B
                                            next I
    ;************ Software I2C Byte Read *************
    Software_I2C_RB:  ;Read byte sized data using PPB commands
     Lcdout Cmd, Clr
     lcdout CMD, Line_2,  "Read Byte Values"
     pause 2000
        For I = 0 to 5 step 1
            address_W = I
               i2cread SDA, SCL, $A0, address_W,[Data_In_B]
                    Pause 10
                        Lcdout Cmd, Clr
                            lcdout CMD, Line_1,  "Read Address = ", dec address_W
                                lcdout CMD, Line_2, "Byte Data = ", dec Data_In_B
                                        next I
    ;************ Hardware I2C Write Byte Sized Variables  *************
    Hardware_I2C_WB:
    SSPEN = 1 ;MSSP module on
      Lcdout Cmd, Clr
      lcdout CMD, Line_1 + 2,"Hardware I2C"
      lcdout CMD, Line_2 + 2, "Byte Variables"
      pause 2000
      ;************ Write to EEPROM *************
                Data_Out_B = (I * 10) + 1   ;Data_Out_B is byte size variable
    Lcdout Cmd, Clr
    gosub I2C_START   ;Begin I2C sequence
    I2C_DATA = CTRL_W  ;Send Control + write command
    gosub I2C_TX
    'I2C_DATA = address_W.byte1  ;Address high byte
    'gosub I2C_TX
    I2C_DATA = address_W.byte0  ;Address low byte
    gosub I2C_TX
    I2C_DATA = Data_Out_B   ;Data byte
    gosub I2C_TX
    gosub  I2C_STOP   ;Stop Write sequence
    pause 1000       ;Delay for LCD display of values
    Next I
    ;************ Hardware I2C Read Byte Sized Variables *************
    Hardware_I2C_RB:  ;Read byte sized data using hardware I2C
     Lcdout Cmd, Clr
     lcdout CMD, Line_2 + 1,  "Read Byte Values"
     pause 2000
         address_W = I
    gosub I2C_TX
    'gosub I2C_TX
    gosub I2C_TX
    gosub I2C_Restart ;Reset bus before sending Read control byte
    I2C_DATA = CTRL_R  ;Send Control + read command
    gosub I2C_TX
    gosub I2C_RX   ;Clock data into MSSP buffer
    gosub I2C_NACK ;Terminate EPPROM sending data
    gosub  I2C_STOP   ;Stop Read sequence
    Data_IN_B = SSPBUF  ;Read data from MSSP buffer
    Lcdout Cmd, Clr
    Next I
    ;************ Software I2C Word Write *************
    Software_I2C_WW:  ;Write word sized data using PPB commands
      Lcdout Cmd, Clr
      lcdout CMD, Line_2, "Write Word Variables"
      pause 2000
       For I = 0 to 10 Step 2
                Data_Out_W = I * 1000   ;Data_Out_W is word size variable
                   i2cwrite SDA, SCL, $A0, address_W,[Data_Out_W.byte1,Data_Out_W.byte0]
                        Pause 10
                            Lcdout Cmd, Clr
                                    lcdout CMD, Line_2, "Word Data = ", dec Data_Out_W
                                            next I
    ;************ Software I2C Read Word *************
    Software_I2C_RW:  ;Read byte sized data using PPB commands
     Lcdout Cmd, Clr
     lcdout CMD, Line_2,  "Read Word Values"
     pause 2000
        For I = 0 to 10 step 2
            address_W = I
               i2cread SDA, SCL, $A0, address_W,[Data_In_W.byte1,Data_In_W.byte0]
                    Pause 10
                        Lcdout Cmd, Clr
                                lcdout CMD, Line_2, "Word Data = ", dec Data_In_W
                                        next I
    ;************ Hardware I2C Write Word Sized Variables  *************
    Hardware_I2C_WW:
      Lcdout Cmd, Clr
      lcdout CMD, Line_2 + 2, "Word Variables"
      pause 2000
       For I = 0 to 10 Step 2  ;Word values require 2 bytes
    Lcdout Cmd, Clr
    gosub I2C_TX
    'gosub I2C_TX
    gosub I2C_TX
    I2C_DATA = Data_Out_W.byte1  ;Word value high byte
    gosub I2C_TX
    I2C_DATA = Data_Out_W.byte0  ;Word value low byte
    gosub I2C_TX
    Next I
    ;************ Hardware I2C Read Word Sized Variables *************
    Hardware_I2C_RW:  ;Read word sized data using hardware I2C
    ;Word is the result of seqentially reading two consecutive memory addresses
     Lcdout Cmd, Clr
     lcdout CMD, Line_2 + 1,"Read Word Values"
     pause 2000
     For I = 0 to 10 step 2 ;Word values occupy two bytes
         address_W = I
    gosub I2C_TX
    'gosub I2C_TX
    gosub I2C_TX
    gosub I2C_Restart ;Reset I2C bus before sending read command
    gosub I2C_TX
    gosub I2C_RX    ;receive byte
    Data_IN_w.byte1 = SSPBUF   ;High byte of word variable
    gosub I2C_ACK   ;Signal EEPROM to send next byte
    Data_IN_w.byte0 = SSPBUF  ;Low byte of word variable
    gosub I2C_nACK
    Lcdout Cmd, Clr
    Next I
    ;**************** I2C Hardware Subroutines ****************
    I2C_Restart:  ;Send Restart Sequence
    RSEN = 1 ; RSEN - Repeat Start Condition Enable Bit
    SSPIF = 0; Reset Interrupt  flag
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by Re-start sequence
    I2C_START:  ;Send Start Sequence
    SEN = 1 ; SEN - Start Condition Enable Bit
    SSPIF = 0;  Must reset flag
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by Start sequence
    I2C_RX:
    RCEN = 1 ; RCEN - Enable receive mode
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by Receive sequence
    ;pause 1
    I2C_TX:
    ;tries=5   ;see below
    SSPBUF = I2C_DATA ; Move data to SSPBUF
    WHILE TX_Stat  : WEND
    WHILE ACKSTAT : WEND  ;or use something like this for a timeout
     ;timeout if no ack
    'WHILE (ACKSTAT&&tries)   ;wait for slave to respond
    'tries=tries-1
    'pauseus 15
    'WEND
    'if !tries then i2c_error=1
    I2C_STOP: ;Send Sotp Sequence
    PEN = 1 ; PEN - send stop bit
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by Stop sequence
    ;pause 1
    I2C_NACK:  ;Send NACK
    ACKDT = 1 ; ACKDT - Set Ack bit to NotAck
    ACKEN = 1 ; ACKEN - send ACKDT bit
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by NACK sequence
    I2C_ACK:  ;Send ACK
    ACKDT = 0 ; ACKDT - Set Ack bit to Ack
    WHILE SSPIF = 0 : WEND ; Wait for SSPIF to be set to 1 by ACK sequence
    'pause 1
  1. Hardware I2C
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2022, 10:53
  2. Hardware I2C ?
    By dsicon in forum mel PIC BASIC Pro
    Last Post: - 16th January 2012, 18:19
  3. HARDWARE I2C SAMPLE CODE question
  4. Hardware I2C
    Last Post: - 13th March 2008, 13:24
  5. how can i use I2C and SPI hardware
    By micro in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 15:33
Members who have read this thread : 13
