Gathering chip temperature from PIC18F26K83
+ Reply to Thread
Results 1 to 4 of 4
    Dec 2010
    Melbourne Australia
    Default Gathering chip temperature from PIC18F26K83
    I have an application where I'd like to gather approximate internal chip temperature from a PIC 18F26K83. From the datasheet this requires looking up calibration data stored on the processor as part of the process. That data appears to be stored in a thing called the Device Information Area (DIA) not in specific readily accessible registers. So, my question is: to gather that data, do I use a PEEK command and use the relevant address listed in the datasheet table at the address used for the Peek statement?
    Troy
    Default Re: Gathering chip temperature from PIC18F26K83
    it looks to be pretty much the same as for any of the non volatile memory for that chip
    once region is set
    Dec 2010
    Melbourne Australia
    Okay, thanks Richard. I was really hoping to avoid assembly, but it is what it is.
    Troy
    Dec 2010
    Melbourne Australia
    Thanks again for that Richard. I'm discovering the only assembly instruction I really need as an assembly call is the table read command. Everything else (reading & writing to registers) can be done in Pic Basic.
    Cheers,
    Troy
  1. Value of temperature
    By cobuccit in forum mel PIC BASIC
    Last Post: - 26th May 2020, 10:16
  2. Temperature does not go below 0
    By amodpathak in forum mel PIC BASIC Pro
    Last Post: - 11th June 2015, 14:56
  3. read temperature
    By breeno in forum General
    Last Post: - 6th October 2010, 12:55
  4. Temperature with the LM34C
    By StoneColdFuzzy in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2009, 00:32
  5. temperature controller
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 20:01
Members who have read this thread : 10
