16F690 MCLR as Input
+ Reply to Thread
Results 1 to 3 of 3
    Jan 2022
    Default 16F690 MCLR as Input
    Hello everyone,
    a very basic question,
    I have a 16F690 with the RA3 MCLR configured as input, and the RA3 pin
    is connected to a 4k7 resistor pulldown and a switch tied to the VDD and it's working fine when the switch
    is open I detect a low and when the switch is close I detect a high.
    with the MCLRE bit #5 to = 0 the MCLR is tied to VDD
    (0 = RA3/MCLR/VPP pin function is digital input, MCLR internally tied to VDD)
    if the MCLR is tied to VDD, how come my pulldown + switch are working as it is.
    does the MCLR has already an internal pullup resistor
    if I remove the pulldown resistor with the switch open, the MCLR act as if it is high.
    it need the pulldown resistor to be a low.
    any suggestion ?
    Also the internal EEPROM of the 16F690 is divided into 256 bytes location with address from 0 to 255
    if I write 0, word B, C, does it mean the address 0 and 1 will contain the word variable B and at address 2 will contain variable C (byte)
    Thanks for all comments.
    Default Re: 16F690 MCLR as Input
    Because when you configure RA3 to act as a normal input the MCLR signal is disconnected from the pin and instead connected to Vdd internally. In other words, it's not the PIN that's connected to Vdd but the MCLR-signal. Does that make sense?
    Yes.
    Jan 2022
    many thanks Henrik to clarify this post.
    that make more sense to me now with further test, when the pin RA3
    has nothing connected to it, the input is floating thus
    when adding a pulldown it's state is stable.
    I found from the datasheet a diagram of the MCLR input circuit, my guess is the red line indicate the path of the input configuration.
  1. Using MCLR pin at Input
    By JakeMend in forum mel PIC BASIC
    Last Post: - 6th July 2017, 22:39
  2. ICSP with MCLR as input
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 13th June 2013, 16:40
  3. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  4. MCLR line input only
    Last Post: - 10th April 2008, 23:14
  5. Mclr As Input Pin?
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 06:33
Members who have read this thread : 10
