FSK demodulator in firmware
+ Reply to Thread
Results 1 to 15 of 15
    Default FSK demodulator in firmware
    I have what looks to be a 1.6/3.2kHz FSK signal that I'd like to demodulate to a bitstream using a suitable PIC.
    It's a two wire system with bursts of the FSK signal riding on top of the DC supply, so no carrier like with radio.
    Never dealt with FSK signal before so asking if anyone has done anything like this using PBP?
    I'm thinking of using the ZeroCrossingDetector peripheral together with a timer or two. Either just polling the ZCD Out bit and start/stop the timer(s) or possibly tie it in to the timer gate or go the interrupt route. Being such a low frequency signal I think polling will be more than adequate to get started.
    The goal, for now, is "just" to get the signal into a digital bitstream that I can then capture with a logic analyzer. I know this is analog domain stuff, PLL's and such but when all you've got is a hammer (PBP in this case)....
    Default Re: FSK demodulator in firmware
    Although it is a low frequency, still a zero cross happens every 156.2 usec for the 3.2KHz signal.
    Will the pic be fast enough to process that signal? I am sure ZCD and timers will be enough, but then you have to do some work in less than that period.
    Plenty fast, I'd say.
    At 32MHz an instruction cycle is 125ns. That's ~1250 cycles between zero crossings.
    I'm not trying to interpret/decode the data, just demodulate the signal.
    Every other zero crossing, grab timer value, do some comparison, flip a bit (or not), reset/restart timer. My gut feeling says we should be able to do that in less than 100 instructions - even with PBP compiled code but we'll see.
    What's "bothering me" is the fact the line is idle for extended periods of time meaning there's no zero crossing and timer will overflow/wrap around. I'll need to detect that.
    there are some good ideas here
    https://www.romanblack.com/DTMF/DTMF_alg.htm
    Thanks Richard,
    I had actually read Romans article but, thankfully, my signal never shows two simultanouse tones - it's always one or the other which makes it easier.
    I started with ZCD module but due to the nature of the signal I could not get reliable results (worked fine with waveform generator feeding it a symetric signal but I was unsucessfull in removing the DC-bias from the actual signal so had to abandon ZCD). Once again goes to show that simulations or even half-assed hardware tests doesn't (always) cut it.
    Currently using a comparator with FVR at 2.048V to one input and the signal to the other. Comparator output drives TMR1 gate. TMR1 gate interrupt flag is used to signal "end of measurement". Pushing TMR1 values into an array, resetting TMR0 each time. When TMR0 overflows the line has been idle for 4ms which is my end of frame indicator.
    i have zero experience with zcd module but reading the blurb it seems to bias the pin to about 0.7 ish volts. the signal is applied through a suitable R, so that when the signal goes negative the bias is removed and a crossing is detected. if your input never goes negative its not going to work afaics. the comparator is the next best choice. you also might be able to drive the timer gate directly through a voltage divider if the modulation is deep enough
  1. RF transmission and FSK modules
    By boban in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 07:19
  2. Replies: 3
    Last Post: - 27th October 2008, 15:08
  3. Firmware only USB (16F84A)
    By shahidali55 in forum General
    Last Post: - 23rd September 2008, 12:44
  4. supply FSK COB modules and FSK modules
    By Elsa zhang in forum Adverts
    Last Post: - 8th August 2006, 06:40
  5. PicBasic Pro FSK Modem
    By mikep in forum mel PIC BASIC Pro
    Last Post: - 29th October 2003, 14:21
Members who have read this thread : 14
