Can't reliably transfer over serial connection between two PICs
+ Reply to Thread
Results 1 to 30 of 30
    Default Re: Can't reliably transfer over serial connection between two PICs
    So to check theory about whenever MIBAM causes issues to serial timings, I've connected 16 led strip (longest I had at moment) with APA102Cs to it, and mibam code was running in background and I was shifting out data without any issues.
    its not a valid test, it means nothing. shiftout clock timing for a slave is synchronous , serin serout are asynchronous
    pbp has no synchronous reception commands as a slave device
    Aug 2011
    "I didn't see the problem, therefore it doesn't exist "
    Famous last words. Just ask Murphy.
    I did not went that far so far
    Will do more tests this weekend.
    Did a detailed analysis of how MIBAM affects pause and general code execution at PIC16F1936 running at 32mhz and with 13 BAM outputs.
    This is the simple code, and output is monitored with scope.
    ;----[16F1937 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1936"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_ON                 ; Program memory code protection is enabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; All VCAP pin functionality is disabled
    cfg2&= _PLLEN_ON            ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    ADCON1=%11110011 'enable adc internal reference and justify
    FVRCON=%11001111   'set internal reference to 4.096V
    'OSCCON=%01111000 'SET INTOSC TO 16MHZ
    OSCCON=%11110000 'SET INTOSC TO 16MHZ
    ANSELA=%00000000 'disable ADC on A
    ANSELB=%00000000 'disable ADC on B
    TRISC=%00000000 'set PORTC as output all
    TRISB=%00000000 'set PORTB as output all
    TRISA=%00000000 'set PORTA 2 as input, others as output
    TRISE=%00000000  'set PORTE as output all
    WPUB=%00000000 'DISABLE B PULL UPS
    OPTION_REG=%100000000
    LCDCON=%00000000  'disable LCD controller pins
    LCDSE0=%00000000
    LCDSE1=%00000000
    ;____[ For 12F/16F only - Interrupt Context save locations]_________________
    wsave       var byte    $20     SYSTEM  ' location for W if in bank0
    'wsave       var byte    $70     SYSTEM  ' Alternate save location for W
                                            ' if using $70, comment out wsave1-3
    ' --- IF any of these next three lines cause an error ?? -------------------
    ' -- The chip being used determines which variables are needed -------------
    wsave1      VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2      VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3      VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    '---DO NOT change these-----------------------------------------------------
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 13                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    DEFINE OSC 32 'set oscillator speed
     'DIGIT PINS
    D0 VAR BYTE
    D1 VAR BYTE
    D2 VAR BYTE
    D3 VAR BYTE
    D4 VAR BYTE
    D5 VAR BYTE
    D6 VAR BYTE
    D7 VAR BYTE
    D8 VAR BYTE
    D9 VAR BYTE
    DF VAR BYTE   'TEMPERATURE SIGN
    DT1 VAR BYTE  'DOTS
    DT2 VAR BYTE
    eval var byte 'eeprom reader
    ELOC VAR BYTE 'EEPROM LOCATION
    BAM_LIST  macro                     ; Define PIN's to use for BAM
    BAM_PIN (PORTB,3, D0)
    BAM_PIN (PORTA,0, D1)
    BAM_PIN (PORTB,4, D2)
    BAM_PIN (PORTC,4, D3)
    BAM_PIN (PORTB,5, D4)
    BAM_PIN (PORTC,7, D5)
    BAM_PIN (PORTB,2, D6)
    BAM_PIN (PORTC,5, D7)
    BAM_PIN (PORTB,1, D8)
    BAM_PIN (PORTB,0, D9)
    BAM_PIN (PORTC,6, DF)
    BAM_PIN (PORTA,3, DT1)
    BAM_PIN (PORTA,2, DT2)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
    D0=10: D1=10: D2=10: D3=0: D4=10: D5=10: D6=10: D7=10: D8=10: D9=10: DF=10 'set bam ports
    mama:
    high portc.3
    pause 1
    low portc.3
    pause 1
    goto mama
    The above code should generate square wave output with 1ms high and 1ms low frequency. It does, but the "high" period slowly increases from 1ms to 1.3ms in several iterations of the loop, while "low" period remains the same. The jitter remains almost the same, and on values of PAUSE 20 and above, becomes almost non-existent.
    Based on, that, I've developed a simple "protocol" which appears to be working, and is based on pulse with measurement:
    receiver:
    if portc.3=1 then
    xcount=xcount+1   'increase counter while pin is high
    gosub dcder        'go to decoder when it is low
    xcount=0            'reset counter
    pauseus 1
    goto receiver
    dcder:
    if xcount>10 and xcount<50 then rxvalue=0
    if xcount>60 and xcount<100 then rxvalue=1
    if xcount>110 and xcount<150 then rxvalue=2
    if xcount>160 and xcount<200 then rxvalue=3
    if xcount>210 and xcount<250 then rxvalue=4
    if xcount>260 and xcount<300 then rxvalue=5
    if xcount>310 and xcount<350 then rxvalue=6
    if xcount>360 and xcount<400 then rxvalue=7
    if rxvalue<>oldvalue then
    gosub deco 'send to display
    oldvalue=rxvalue
    This works quite reliably and no issues so far, but it is very slow and is only good as a temporal solution.
    So I'm going to redesign PCB and use hardware serial ports on both transmitter and receiver, but will it 100% work? won't be it also affected by MIBAM?
  1. Csv file transfer directly into excel using vb for serial coms
    Last Post: - 20th May 2016, 09:43
  2. Usb to ttl modules - connection to pics at 3.3v
    Last Post: - 12th March 2015, 21:03
  3. Replies: 1
    Last Post: - 23rd December 2006, 11:38
  4. large file transfer petween pics
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 18:04
  5. Can serial transfer binary data?
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 12th March 2005, 09:27
Members who have read this thread : 12
