Can't reliably transfer over serial connection between two PICs
+ Reply to Thread
Results 1 to 30 of 30
    Default Re: Can't reliably transfer over serial connection between two PICs
    if I reduce control values to 1 or two, then it works, but totally wrong data is being decoded.
    How about this code:
    x vart word
    x=345
    barka:
    serout2 portc.3,84,["s",x]
    goto barka
    RX (45K80)
    x var word
    taka:
    serin2 portc.3,84,[wait("s"), x]
    if x=345 then lcdout $fe, $c0, "X=", dec x, "    "
    goto taka
    Bombay, India
    Why 22k? It seems pretty high to have. Your post suggests you've tried a lower value like 1K; if both PICs are running at the same voltage levels, then altogether do away with the resistor. Due to the resistor, it is possible the logic low level is not being met. If you fix this and still get the problem, then continue below.
    I suspect the problem could be the software serial not getting the start bit reliably.
    What you can do - since you use the 1936 is to configure the receive pin as interrupt on change pin; I believe all pins have IOC ability on this chip.
    When you get the IOC interrupt, invoke the serin2 command in the ISR
    I cannot advise with code as I am not up-to-date with PicBasic since some time now.
    Both 1K and 22K are actually suggested in PBP manual.
    So I tried both, I tried 100 ohm resistor, I tried direct connection. No practical difference - actual "junk" bytes are getting different, but proper one still not delivered. The above slow code, suggested by AI, works with either 100 ohm, 1K or 22K.
    Currently I'm sending data from 1936 to K80 because K80 has LCD screen so I can use it for debugging. In the real life, K80 will be sending data to 1936.
    As a side "improvement", I can use additional data line from K80 to 1836, so SHIFTOUT/SHIFTIN should work then. I guess it will be more reliable?
    The 22K is used ONLY when you are driving the INPUT of the PIC from a real RS232 line, which does -12 to +12 Volts on the pulses!
    No need to have it on TTL connection as in your case. Remove it.
    The 1K is used ONLY when you drive from the OUTPUT of the PIC to the RS232 line, to lower the current that PIC is forced to supply.
    Again no need to have it on TTL connection as in your case. Remove it.
    Have you tested the code on #6 with no resistors?
    works ok in simulator, apart from initial sync issue due to the comms line not beginning at a proper tty level before reception enabled
    and then again i used complete programs not snippets full of guess work
    @Ioannis you missed the spam in faq section
    I haven't tried that code yet, will try it today later.
    Regarding "other" code, there is none, except config and variable assignments.
    Here's complete code for 16F1936 before I launch that part of code:
    ;----[16F1937 Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F1936"
      #DEFINE MCU_FOUND 1
    cfg1 = _FOSC_INTOSC           ; INTOSC oscillator: I/O function on CLKIN pin
    cfg1&= _WDTE_OFF              ; WDT disabled
    cfg1&= _PWRTE_OFF             ; PWRT disabled
    cfg1&= _MCLRE_OFF             ; MCLR/VPP pin function is digital input
    cfg1&= _CP_ON                 ; Program memory code protection is enabled
    cfg1&= _CPD_OFF               ; Data memory code protection is disabled
    cfg1&= _BOREN_OFF             ; Brown-out Reset disabled
    cfg1&= _CLKOUTEN_OFF          ; CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin
    cfg1&= _IESO_ON               ; Internal/External Switchover mode is enabled
    cfg1&= _FCMEN_ON              ; Fail-Safe Clock Monitor is enabled
      __CONFIG _CONFIG1, cfg1
    cfg2 = _WRT_OFF               ; Write protection off
    cfg2&= _VCAPEN_OFF            ; All VCAP pin functionality is disabled
    cfg2&= _PLLEN_OFF             ; 4x PLL disabled
    cfg2&= _STVREN_ON             ; Stack Overflow or Underflow will cause a Reset
    cfg2&= _BORV_19               ; Brown-out Reset Voltage (Vbor), low trip point selected.
    cfg2&= _LVP_OFF               ; High-voltage on MCLR/VPP must be used for programming
      __CONFIG _CONFIG2, cfg2
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    'nixie led clock electronics direct drive
    ADCON1=%11110011 'enable adc internal reference and justify
    FVRCON=%11001111   'set internal reference to 4.096V
    OSCCON=%11110000 'SET INTOSC TO 8MHZ
    'ANSELE=%00000000 'enable adc input porte.2
    ANSELA=%00000000 'disable ADC on A
    ANSELB=%00000000 'disable ADC on B
    'ANSELD=%00000000 'disable ADC on D
    TRISC=%00000000 'set PORTC as output all
    'TRISD=%00000000 'set PORTD as output all
    TRISB=%00000000 'set PORTB as output all
    TRISA=%00000000 'set PORTA 2 as input, others as output
    TRISE=%00000000  'set PORTE as output all
    WPUB=%00000000 'DISABLE B PULL UPS
    OPTION_REG=%100000000
    LCDCON=%00000000  'disable LCD controller pins
    LCDSE0=%00000000
    LCDSE1=%00000000
    'LCDSE2=%00000000
    DEFINE OSC 32 'set oscillator speed
    ;____[ For 12F/16F only - Interrupt Context save locations]_________________
    wsave       var byte    $20     SYSTEM  ' location for W if in bank0
    'wsave       var byte    $70     SYSTEM  ' Alternate save location for W
                                            ' if using $70, comment out wsave1-3
    ' --- IF any of these next three lines cause an error ?? -------------------
    ' -- The chip being used determines which variables are needed -------------
    wsave1      VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2      VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3      VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    '---DO NOT change these-----------------------------------------------------
    ssave       VAR BYTE    BANK0   SYSTEM      ' location for STATUS register
    psave       VAR BYTE    BANK0   SYSTEM      ' location for PCLATH register
    ;----[ MIBAM Setup ]--------------------------------------------------------
    BAM_COUNT CON 13                     ; How many BAM Pins are used?
    INCLUDE "MIBAM.pbp"                 ; Mirror Image BAM module
    dta       var porta.6 'LED PINS
    clk       var porta.7
    FET var portc.2 'current control fet pin
    VALUE VAR BYTE 'DIGIT DECODER VALUE VARIABLE
    LOLD VAR BYTE 'OLD LEFT VALUE FOR DECODER
    ROLD VAR BYTE 'OLD RIGHT VALUE FOR DECODER
    'LED COLOR VALUES 'LEFT AND RIGHT
    LR  VAR BYTE
    LG  VAR BYTE
    LB  VAR BYTE
    LX VAR BYTE 'LEFT BRIGHTNESS
    PACKED VAR BYTE 'LED PACKER
    RR VAR BYTE
    RG VAR BYTE
    RB VAR BYTE
    RX VAR BYTE 'RIGHT BRIGHTNESS
    new var byte 'current display value
    old var byte 'old display value
    maxbr var byte  'brightness holder
    CURBR VAR BYTE 'CURRENT RELATIVE BRIGHTNESS HOLDER
    ANIT var byte 'animation type digits
    DOTA var byte 'dot animation type
    x var word ' main small counter
    y var word 'additional var
    BR1 var byte 'brightness comparator 1
    BR2 var byte '2
    DCMODE var byte '6 or 10 digit mode selector
    tmp var byte 'temporal var for counting
    TEXTLINE VAR BYTE[8] 'MAIN ARRAY FOR TEXT STORAGE
     'DIGIT PINS
    D0 VAR BYTE
    D1 VAR BYTE
    D2 VAR BYTE
    D3 VAR BYTE
    D4 VAR BYTE
    D5 VAR BYTE
    D6 VAR BYTE
    D7 VAR BYTE
    D8 VAR BYTE
    D9 VAR BYTE
    DF VAR BYTE   'TEMPERATURE SIGN
    DT1 VAR BYTE  'DOTS
    DT2 VAR BYTE
    eval var byte 'eeprom reader
    ELOC VAR BYTE 'EEPROM LOCATION
    BAM_LIST  macro                     ; Define PIN's to use for BAM
    BAM_PIN (PORTB,3, D0)
    BAM_PIN (PORTA,0, D1)
    BAM_PIN (PORTB,4, D2)
    BAM_PIN (PORTC,4, D3)
    BAM_PIN (PORTB,5, D4)
    BAM_PIN (PORTC,7, D5)
    BAM_PIN (PORTB,2, D6)
    BAM_PIN (PORTC,5, D7)
    BAM_PIN (PORTB,1, D8)
    BAM_PIN (PORTB,0, D9)
    BAM_PIN (PORTC,6, DF)
    BAM_PIN (PORTA,3, DT1)
    BAM_PIN (PORTA,2, DT2)
      BAM_INIT  BAM_LIST                ; Initialize the Pins
  1. Csv file transfer directly into excel using vb for serial coms
    Last Post: - 20th May 2016, 08:43
  2. Usb to ttl modules - connection to pics at 3.3v
    Last Post: - 12th March 2015, 20:03
  3. Replies: 1
    Last Post: - 23rd December 2006, 10:38
  4. large file transfer petween pics
    By Ron Marcus in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 17:04
  5. Can serial transfer binary data?
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 12th March 2005, 08:27
Members who have read this thread : 14
