serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 40 of 60
    Feb 2022
    Default serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
    Hello everyone,
    I'de like to share this project, may come handy for hobbyist working around LCD display.
    My search for a serial LCD that can receive serial data from 300 to 19200 baud on the internet was not successful
    then I roll-up my sleeves and build this LCD backpack that use a common Hitachi HD44780 display. (still popular today)
    My project was simple with parts already on hand like PIC16F690, NPN smd transistor, potentiometer, resistor. and PBP3 Basic code.
    So enjoy,
    '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Name  : 16F690 LCD BACKPACK
    ' Date  : Sep 27-2025
    ' Note  : 393 words used  of 2048
    ' Notes : Serin2 Baud Rate 300 ~ 19200 Intrc_OSC 8Mhz
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_OFF
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_OFF
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_OFF
    cfg&= _IESO_OFF
    cfg&= _FCMEN_OFF
      __CONFIG cfg
    DEFINE OSC 8        ' Core is running at EXT-CRYSTAL 16MHz PBP 33,217
    ANSEL = 0           ' Set all pins digital
    ANSELH = 0          ' Set all pins digital
    OPTION_REG.7 = 0    ' PORTA/PORTB pull-ups are enabled by individual port latch values
    CM1CON0 = 0         ' Analog comparators off
    En var Portb.4 : low en
    RS var Portb.6 : low rs
    B1 var byte : b1 = 0
    ' 300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
    BaudR var byte : baudr = 32
    TRISA = 0 : TRISB = 100000 : TRISC = 0
    PORTA = 0 : PORTB = 0 : PORTC = 0
    OSCCON = $70
    high Porta.0              ' Backlight ON
    gosub LCDinit             ' initialise LCD
    'Serin2
        serin2 Portb.5,baudr,3,main,[b1]
        if b1 < 253 then     ' Characters
            PORTC = b1
            HIGH EN : PAUSEus 5 : LOW EN
        elseif b1 = 254 then  ' LCD Command
            low RS
            PORTC = b1          ' output the data
            high RS           ' character mode
        elseif b1 = 255 then
            low rs            ' LCD Command
            if b1 = 0 then
                low porta.0   ' Back Light OFF
            high rs
            if b1 = 8 then
                high porta.0  ' Back Light ON
            high rs
           goto main             ' loop back to top
    LCDINIT:                  ' Standard LCD Module Initialisation
    PORTC = 000001          ' 2, Clear Display
        HIGH EN : PAUSEus 300 : LOW EN ' Send data
        pause 4
    PORTC = 000010          ' 4, Return Home
        pause 4
    PORTC = 111000         ' 1, 8 bit, 2 line, 5x8 Characters
        pause 4
    ' PORTC = 001100          ' Display on, no cursor, no blink
    PORTC = 001110          ' 1, Display on, cursor, blink
        pause 4
    PORTC = 000110          ' 1, Entry mode
        pause 4
        high rs                  ' character mode
    Feb 2022
    Default Re: serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
    Here's an code update
    on the LCD backpack code the line
    BaudR var byte should be replace with: BaudR var Word
    and here's the serial sender code updated as well. (use an 12F683)
    'Project : 12F683 Serial LCD Test 300 ~ 19200 baud for 16F690 Lcd Backpack
    'Date    : Sep 27-2025
    'Notes   : 285 words used  of 2048
    'Notes   : Serout2 300 ~ 19200  Intrc_OSC 8Mhz
    '300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
     __config  _INTOSCIO & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOD_OFF  & _CP_OFF & _CPD_OFF
    LCD Var GPIO.0         ' Serial out
    ANSEL = 0              ' Set all digital  PULLUP Resistor  page:10
    TRISIO = %00000000     ' INPUT=1 OUTPUT = 0
    OSCCON = $70           ' $70=8Mhz  $60=4mhz  $50=2MHZ  $40=1MHZ  $30=500KHZ
    BaudR var word
    baudR = 32 ' 300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
    Pace var byte          ' for serout2
    pace = 0
    SEROUT2 lcd,baudR,pace,[ 254, 1] ' Clear LCD
    pause 40
    DO
    ' LCD 1602
        sEROUT2 lcd,baudR,pace,[254,128,"ABCDEFGHIJKLMNOP"] ' Line 1 16 Char.
        SEROUT2 lcd,baudR,pace,[254,192,"0123456789-=,./>"] ' Line 2 16 Char.
    ' LCD 2004
        'SEROUT2 lcd,BaudR,pace,[254,128,"ABCDEFGHIJkLMNOPQRST"] ' Line 1 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,192,"0123456789-=,./;!@#$"] ' Line 2 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,148,"ABCDEFGHIJkLMNOPQRST"] ' Line 3 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,212,"0123456789-=,./;!@#$"] ' Line 4 20 Char.
        PAUSE 2000
        SEROUT2 lcd,baudR,pace,[ 255, 0] ' Back Light OFF
        PAUSE 200
        SEROUT2 lcd,baudR,pace,[ 255, 8] ' Back Light ON
        PAUSE 2000
    LOOP
    Feb 2022
    final code update in "16F690 LCD BACKPACK"
    the low rs and high rs lines are not needed, since it control PortA.0 and not the HD44780 chip.
    ' low rs ' LCD Command
    if b1 = 0 then
    ' high rs
    if b1 = 8 then
    ' high rs
    Thanks for posting your project.
    But why not use the Hardware USART instead of the Software one?
    Feb 2022
    Hello Ioannis,
    good question,
    when I design the PCB I used the PortB.5 with a 20Mhz crystal with bigger pcb foot print 46x17mm
    then I decided to lower the parts count and the PCB foot print to a bare minimum (41 x 17mm)
    Also theses HD44780 are still in use by many hobbyist around the world, I guess, and the baud rate I was looking is plenty for this kind of display.
    thank's for asking.
    Name:  new PCB 41x17mm.jpg
    Feb 2022
    Hello,
    you're right
    my assumption was that software or hardware control serial communication are the same
    and one way or another I'll get the same result.
    if I may ask in this project what the benefit of hardware over software serial control.
    thank's again.
    Less code usage. If for some reason you need Serin, it may hang if the device is not replying correctly. Hserin has timout and will save the day.
    For your project it may not have any meaning, but I think it is good practice to use as much as you can the hardware features than the emulated software.
    doubtful there is any since the 690 does nothing else anyway and the lcd's speed is the real bottle neck
    Feb 2022
    I aggree on both comment, Hserin is more convenient than Serin2
    the goal of this project was to learn base on inexpensive parts on-hand
    you can strech the total cost for less than $12 pcb included not bad for an hobbyist who's looking to add a simple but pratical alphanumeric display
    I really appreciate comments
    btw , what is happening with MELab Forum, is it close for good.
    The Melabs Forum is(was?) supported by the company itself. So little is known as to what is happening.
    The company does not really have a future.
    Some of us here are also dinosaures and reluctant to switch to C or other platforms. So we stay and try to support its operation, as long as our host, honorable Lester, allows this forum to live.
    Feb 2022
    very kind of you to reply,
    Roughly 12 years ago, I started learning Basic Pic programming with Picaxe, then GCBasic
    now I'm mostly using MELab PBP Pro, and Positron both are like twin of Pic Basic compiler.
    my guess is these IDE Compilers are the last ones on the market, now the current trend is
    with Arduino, Python etc..
    if I may ask,
    are you aware of any good sources on how,
    to learn asm, and understand the asm files structure, to write assembler code, compile it and to download to a PIC
    regards.
    What is the use of learning ASM when C is better with great support and portable too?
    I think it is a waste of time if you choose ASM. Also you have to deal with pages, Banks and will be very much difficult to keep your mind checking all the time if your code has to change banks, pages etc in order to access registers correctly.
    But if you insist on diving in the deep dark waters of ASM, then I guess Microchip is the first to think. But these video tutorials also help https://www.youtube.com/@IESD2013
    Feb 2022
    thanks for the advice, it's helping what to consider.
    Feb 2022
    as for C is considered, which IDE/Compiler you use or recommend
    Feb 2022
    quick update for the Backpack code: High RS line should be remove to avoid random character on screen when booting.
    PORTC = %00000110 : High En : DelayUS 1 : Low En : DelayMS 1 ' Entry mode
    ' High RS
    Feb 2022
    correct order for display control
    PORTC = %00001110 ' %00001DCB Display on/off, cursor on/off, blink y/n
    Regarding C, MPLABX is the one to try and sure the last. It includes also the MCC tool to setup any microcontroller with ease.
    Tried a couple of times C but i guess i am too old to change ...
    Feb 2022
    I did try MPLAB X a year ago and it's was a bitter chalenge comparing to what I'm used to do with PBP3,Picaxe, Positron
    Feb 2022
    Oct 2 2025
    update on 16F690 Backpack, new LCDINT pause to accomodate 28800,38400 baud rate for (Xtal = 20Mhz)
    __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    PORTC = %00000001 : HIGH EN : PAUSEus 1 : LOW EN : pause 4 ' Clear Display
    PORTC = %00000010 : HIGH EN : PAUSEus 1 : LOW EN : pause 2 ' Return Home
    PORTC = %00111000 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' 8 bit, 2 line, 5x8 Characters
    PORTC = %00000110 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' Entry mode
    PORTC = %00001110 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' %00001DCB Display on/off, Cursor on/off, Blink y/n
    Agree that MPLABX is a bit scarry but has all the tools to complete a task regarding C at least.
    You have MCC, Simulator, breakpoints etc. Basic does not give all these goodies.
    As for your LCD driver, I think it is a little bit dependant on the specific LCD characteristics. Some are slow and some are a bit faster, so user has take that into account.
    Feb 2022
    totally agree, the LCD is kind of an old tech, but for an hobbyist it's a good learning tool.
    to clarify the baud rate turn around, just include this chart to figure it out.
    with each OSC setup, it can manage baud rate from 300 ~ 38400.
    Name:  Baud Rate Chart.jpg
    I meant the LCD timing specs that have differencies. So the end user may have to take into account that.
    Things to adjust include these DEFINEs (from the manual):
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    44 maybe on the edge. 50 maybe more safe.
    Feb 2022
    thanks, to clarify
    I know you have already done your PCBs, but an idea for future update, might be to include other type of Character LCDs like:
    2x20,
    2x40,
    4x16
    4x20
    and be able the user to select these with jumpers. Or even sending serial commands only! This would better need feedback on the serial port but no need for jumpers, so can be implemented on your current PCB.
    for my money i would let pbp do all the heavy lifting and leverage their nice efficent routines like this
    works for 4 or 8 bit mode and all
    'Name  : 16F690 LCD BACKPACK
    ' Date  : oct 2025    richard
    ' Note  : 300 words used  of 2048
    cfg&= _WDT_OFF
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_OFF
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_OFF
    cfg&= _IESO_OFF
    cfg&= _FCMEN_OFF
      __CONFIG cfg
        DEFINE OSC 8
        CLEAR
        DEFINE LCD_BITS 8     'defines the number of data interface lines (4 or 8)
        DEFINE LCD_DREG PORTC    'defines the port where data lines are connected to
        DEFINE LCD_RSREG PORTB    'defines the port where RS line is connected to
        DEFINE LCD_RSBIT 6     'defines the pin where RS line is connected to
        DEFINE LCD_EREG PORTB     'defines the port where E line is connected to
        DEFINE LCD_EBIT 4     'defines the pin where E line is connected
        DEFINE LCD_COMMANDUS 1500     'defines the delay after LCDOUT statement
        DEFINE LCD_DATAUS 50         'delay in micro seconds
        B1 var byte
        Bl var byte
        TRISC = 0
        TRISA = % 11111110
        OSCCON = $70
        PAUSE 500
        Porta.0 = 1    ' Backlight ON
        LCDOUT $FE,1
    '    LCDOUT "ready @19200"
    @  bsf   LCD_RSREG ,LCD_RSBIT
       if bl then
            if b1 = 0 then
                 porta.0 = 0  ' Back Light OFF
            if b1 = 8 then
                 porta.0 = 1 ' Back Light ON
            bl = 0
       if b1 = 255 then
             bl = 1
       if b1 = 254 then
    @  bcf   LCD_RSREG ,LCD_RSBIT
    @  MOVE?BB _B1,R3
    @  L?CALL lcdsend
    ps forgot to add it is now so easy to add a flash screen on boot
    what is that bl (second line after main)? I guess bl should be b1.
    But then, if b1 gets a 0 from the serial in, how the if-then's will work?
    One var is B1 the other is BL, as in bl for bachlight .
    I would need to paid more for properly named vars and valid meaningful comments
    Well, ok then. BL stands for the back light. But where does it get set?
    When B1=255
    Oops...!
    Feb 2022
    yes that's a very good idea, the one I have tested are 1601, 1602, 2004
    Feb 2022
    Here's a shrink down version for displaying messages from internal arrays no serial input involved.
    practical if just an operating device with control buttons attach to the remaining 5 ports is needed
    ' Project : LCD Backpack Self Text  (Write text on LCD no serial port)
    ' Name    : 16F690 LCD BACKPACK for Hitachi HD44780  1601 / 1602 / 2004
    ' Date    : Oct 3 2025
    ' Notes   : 320 words used of 4096
    Device = 16F690
    'Declare Xtal = 8
    'Config INTRC_OSC_NOCLKOUT, WDT_OFF, PWRTE_OFF, MCLRE_OFF, CP_OFF, CPD_OFF, IESO_OFF, FCMEN_OFF
    Declare Xtal = 20
    Config HS_OSC, WDT_OFF, PWRTE_OFF, MCLRE_OFF, CP_OFF, CPD_OFF, IESO_OFF, FCMEN_OFF
    TRISA = 0 : TRISB = %00100000 : TRISC = 0 : PORTA = 0 : PORTB = 0 : PORTC = 0
    OSCCON = $70
    Dim I As Byte
    ' 1601 1602 16 Char 1/2 Lines
    Dim MyArrayA[16] As Byte = "0123456789ABCDEF"
    Dim MyArrayB[16] As Byte = "abcdefghijklmnop"
    ' 2004  20 Char 4 Lines
    'Dim MyArrayC[20] As Byte = "ABCDDE1234567890ABCD"
    'Dim MyArrayD[20] As Byte = "abcdefghijklmnop1234"
    'Dim MyArrayE[20] As Byte = "ABCDDE1234567890abcd"
    'Dim MyArrayF[20] As Byte = "abcdefghijklmnop1234"
    GoSub LCDINIT                ' initialise LCD
    PORTA = 1                      ' Backlight ON
    ' 1601 / 1602
    PORTB = 0 : PORTC = 128 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 3 ' Line 1
    For I = 0 To 15
        PORTC = MyArrayA[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I
    PORTB = 0 : PORTC = 192 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 3 ' Line 2
    For I = 0 To 15
        PORTC = MyArrayB[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I
    ' 2004
    (*PORTB = 0 : PORTC = 128 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 3 ' Line 1
    For I = 0 To 19
        PORTC = MyArrayC[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I
    For I = 0 To 19
        PORTC = MyArrayD[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I
    PORTB = 0 : PORTC = 148 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 3 ' Line 3
    For I = 0 To 19
        PORTC = MyArrayE[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I
    PORTB = 0 : PORTC = 212 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 3 ' Line 4
    For I = 0 To 19
        PORTC = MyArrayF[I] : PORTB = %01010000 : DelayUS 1 : PORTB = %01000000 : DelayMS 1
    Next I*)
    DelayMS 2000
    PORTB = 0 : PORTC = 1 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : PORTB = %01000000 : DelayMS 4  ' Clear display
    DelayMS 255
    PORTA = 0             ' Bacck Light off
    DelayMS 255
    PORTA = %00000001     ' Bacck Light on
    DelayMS 255
    GoTo main
    LCDINIT:
    PORTC = %00000001 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : DelayMS 4  ' Clear display
    PORTC = %00000010 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : DelayMS 2  ' Return Home
    PORTC = %00111000 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : DelayMS 2  ' 5x8 Character 8 Bit, 2 Line
    PORTC = %00001100 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : DelayMS 2  ' %00001DCB Display on/off, cursor on/off, blink y/n
    PORTC = %00000110 : PORTB = %00010000 : DelayUS 1 : PORTB = 0 : DelayMS 2  ' Entry mode
    This code is not for PicBasic dialect...
    Tried to test Richards code, but seems i cant make the LCD work at all.
    For starters the Backlight does not turn off.
    What is the sequence that should be sent over the serial port to control backlight and then send some text over to LCD?
    The backlight is controlled by 255d and 0d or 255d and 8d.
    Have yet to send some text over the LCD.
    Feb 2022
    OOP'S!
    usualy I code in both Positron & PBP3.
    here's the PBP3 code. (added Pause C)
    ' Name  : 16F690 LCD BACKPACK  Self Text
    ' Date  : Oct 4-2025
    ' Serin2
    '#CONFIG
    '  __config  _INTRC_OSC_CLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    '#ENDCONFIG
     ' HSERIN
    DEFINE OSC 20       ' Core is running at EXT-CRYSTAL 20MHz PBP 33,217
    C VAR BYTE : C = 10
    I VAR BYTE
    ' 1601 - 1602
    ArrayA var Byte [16] : ARRAYWRITE ArrayA,["ABCDEF1234567890"] ' Line 1
    ArrayB var Byte [16] : ARRAYWRITE ArrayB,["1234567890!@#$%^"] ' Line 2
    ' 2004
    'ArrayC var Byte [20] : ARRAYWRITE ArrayC,["ABCDEF1234567890!@#$"] ' Line 1
    'ArrayD var Byte [20] : ARRAYWRITE ArrayD,["1234567890!@#$%^!@#$"] ' Line 2
    'ArrayE var Byte [20] : ARRAYWRITE ArrayE,["ABCDEF1234567890!@#$"] ' Line 3
    'ArrayF var Byte [20] : ARRAYWRITE ArrayF,["1234567890!@#$%^!@#$"] ' Line 4
    OSCCON = $70
    ' 1601 - 1602
    Low RS : PORTC = 128 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 1
    For I = 0 To 15
        PORTC = ArrayA[I]
        Pause C
    Next I
    Low RS : PORTC = 192 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 2
    For I = 0 To 15
        PORTC = ArrayB[I]
        Pause C
    Next I
    ' 2004
    'Low RS : PORTC = 128 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 1
    'For I = 0 To 19
    '    PORTC = ArrayC[I]
    '    High En : PauseUS 1 : Low En
    '    Pause C
    'Next I
    'Low RS : PORTC = 192 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 2
    'For I = 0 To 19
    '    PORTC = ArrayD[I]
    '    Pause C
    'Next I
    'Low RS : PORTC = 148 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 3
    'For I = 0 To 19
    '    PORTC = ArrayE[I]
    '    Pause C
    'Next I
    'Low RS : PORTC = 212 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 4
    'For I = 0 To 19
    '    PORTC = ArrayF[I]
    '    Pause C
    'Next I
    Pause 1000
    Low RS : PORTC = 1 : High En : PauseUS 1 : Low En : High RS : PauseUS 4  ' Clear display
    Pause 500
    'Low PORTA.0      ' Bacck Light off
    Pause 200
    High PORTA.0     ' Bacck Light on
    Pause 200
    GoTo main
    PORTC = %00001100 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' %00001DCB Display on/off, Cursor on/off, Blink y/n
    Feb 2022
    the code I use are similar, you can try to adapt.
    for the Hitachi HD44780 the decimal 254 represent the low RS then you need ot receive the line # as 128 line #1, 192 line #2, 148 line #3, 212 line #4
    as for Richard code , for the Back Light he's using a toggle on,off with b1. (by receiving b1 turn On, then again turn Off)
    Or more like
    SEROUT2 lcd,baudR,pace,[ 255, 8] ' Back Light OFF
    SEROUT2 lcd,baudR,pace,[ 255, 0] ' Back Light ON
    depending on how you connected the backlight of course
    Feb 2022
    just set:
    BaudR var word
    work fine here
    Feb 2022
    tested richard code, work fine 300 to 9600 at 8Mhz (_INTRC_OSC_NOCLKOUT)
    19200 not working at 8Mhz and 20Mhz Xtal
    back light working fine 300~19200
    Name:  richard forum.jpg
  1. Using 16F1503 as Serial LCD Backpack
    Last Post: - 11th March 2015, 20:58
  2. 16F877A and LCD HD44780
    By epilot in forum mel PIC BASIC Pro
    Last Post: - 1st November 2013, 19:17
  3. FREE Serial LCD Backpack Board
    By rmteo in forum Off Topic
    Last Post: - 29th July 2010, 03:32
  4. Lcd Hd44780
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 15:04
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 17:52
Members who have read this thread : 16
