serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780 - Page 2
+ Reply to Thread
Page 2 of 2 FirstFirst 12
Results 41 to 60 of 60
  1. #41
    Default Re: serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
    My code honours the timing as specified by the lcd defines , timing that most lcd displays need esp the cheapest and oldest examples of them.
    If you send data at a rate that exceeds the specified time constraints as defined it will of course fall. The solution is to either pace data transmission or set the defines to the actual speed the lcd can tolerate . The intent of my code is to match data rate to the real speed that the lcd can manage
    Jan 2022
    set pace to 1 , and it's working
    sEROUT2 lcd,baudR,pace,[254,128,"ABCDEFGHIJKLMNOP"]
    thanks.
  3. #43
    I only tested at 19200 and the Backlight works OK.
    But text, could not send up to this moment.
    WIll try different Baud Rate. Though I test on a PIC16F1827 at 32MHz.
    Jan 2022
    when testing baud rate, usualy I start at 300 and up
    when it stopped working then I set pace = 1
    and re-start from the last baud rate tested.
    16F690 Xtal 20Mhz
    set pace to 1
    from my code here's the tested baud rate .
    and when booting the PIC's at different baud rate the sender 12F683 and receiver 16F690 the LCD screen light up right away and start displaying text, and back light on/off
    there's no lag for the first receiving if I remember correctly the pace for the sender is set = 0.
    Name:  Baud Rate Chart-A.jpg
    Also I add baud rate selection jumpers on the Backpack''
    Name:  LCD Backpack with Jumpers.jpg
    ' Jumpers
    J3 300 600 1200 2400 4800 9600 14400 19200 28800 38400
    ' 1--2 RB7 On On On On On On
    ' 3--4 RA2 On On On On
    ' 5--6 RA1 On On On On
    ' 7--8 RA3 On On On
    ' Baud Rate SW Selection (PCB J3)
    If PORTA = 001110 And PORTB.7 = 1 Then BaudR = 3313 ' 300
    If PORTA = 001110 And PORTB.7 = 0 Then BaudR = 1646 ' 600
    If PORTA = 001010 And PORTB.7 = 1 Then BaudR = 813 ' 1200
    If PORTA = 001100 And PORTB.7 = 1 Then BaudR = 396 ' 2400
    If PORTA = 000110 And PORTB.7 = 1 Then BaudR = 188 ' 4800
    If PORTA = 001010 And PORTB.7 = 0 Then BaudR = 84 ' 9600
    If PORTA = 001100 And PORTB.7 = 0 Then BaudR = 49 ' 14400
    If PORTA = 000110 And PORTB.7 = 0 Then BaudR = 32 ' 19200
    If PORTA = 001000 And PORTB.7 = 0 Then BaudR = 15 ' 28800
    If PORTA = 000000 And PORTB.7 = 0 Then BaudR = 6 ' 38400
  5. #45
    Jan 2022
    from my last edit,
    ' Jumpers
    ' J3 300 600 1200 2400 4800 9600 14400 19200 28800 38400
    ' 7--8 RA3 On On On
    I think courier new does not take spaces !
    better use screen cap
    Name:  LCD Backpack with Jumpers code.jpg
  6. #46
    Jan 2022
    edited BaudR var word : baudr = 3313 and TRISA = 111110
    1st receiving random characters
    2nd normal
    what could be done to avoid the first
    thanks.
  7. #47
    its always better to use the hardware than bit-banged routines and there is nothing better than a ring-buffer to overcome traffic snarls
    ' Name  : 16F690 LCD BACKPACK
    ' Date  : oct 2025    richard
    ' Note  : RING BUFFERED
    ' Notes : 19200 Intrc_OSC 8Mhz
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_OFF
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_OFF
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_OFF
    cfg&= _IESO_OFF
    cfg&= _FCMEN_OFF
      __CONFIG cfg
        DEFINE OSC 8
        DEFINE INTHAND myint
        ANSEL = 0           ' Set all pins digital
        ANSELH = 0          ' Set all pins digital
        OPTION_REG.7 = 0    ' PORTA/PORTB pull-ups are enabled by individual port latch values
        CLEAR
        DEFINE LCD_BITS 8     'defines the number of data interface lines (4 or 8)
        DEFINE LCD_DREG PORTC    'defines the port where data lines are connected to
        DEFINE LCD_RSREG PORTB    'defines the port where RS line is connected to
        DEFINE LCD_RSBIT 6     'defines the pin where RS line is connected to
        DEFINE LCD_EREG PORTB     'defines the port where E line is connected to
        DEFINE LCD_EBIT 4     'defines the pin where E line is connected
        DEFINE LCD_COMMANDUS 1500     'defines the delay after LCDOUT statement
        DEFINE LCD_DATAUS 50         'delay in micro seconds
        RCSTA = $90   ' Enable serial port & continuous receive
        TXSTA = $20   ' Enable transmit, BRGH = 0
        SPBRG = 25    ' 19200 Baud @ 8MHz, 0.16%
        SPBRGH = 0
        BAUDCTL.3 = 1 ' Enable 16 bit baudrate generator
        wsave VAR BYTE $70 SYSTEM ;wsave in access RAM
        ssave VAR BYTE BANK0 SYSTEM
        psave VAR BYTE BANK0 SYSTEM
        index_in         VAR BYTE bank0         ' Pointer - next empty location in buffer
        index_out        VAR BYTE bank0         ' Pointer - location of oldest character in buffer
        errflag          VAR BYTE bank0         ' Error flag
        UartFlag         VAR errflag.0
        BufferFlag       VAR errflag.1
        buffer_size      CON  32                               ' Sets the size of the ring buffer
        buffer           VAR  BYTE[buffer_size]     ' Array variable for holding received characters
        bufchar          VAR  BYTE          ' Stores the character retrieved from the buffer
        Bl               var byte
    GOTO overint ' Jump over the interrupt handler
    myint
       if CODE_SIZE <= 2 ; If less than 2K code space
            ; Save the state of critical registers (PIC12/PIC16)
           movwf wsave ; Save W
           swapf STATUS,W ; Swap STATUS to W (swap avoids changing STATUS)
           clrf STATUS ; Clear STATUS
           movwf ssave ; Save swapped STATUS
           movf PCLATH,W ; Move PCLATH to W
           movwf psave ; Save PCLATH
    ; Check for hardware overrun error
       btfsc   RCSTA,OERR   ; Check for usart overrun
       goto    usart_err    ; jump to assembly error routine
    ; Test for buffer overrun
       incf   _index_in,W   ; Increment index_in to W
       subwf  _index_out,W  ; Subtract indexes to test for buffer overrun
       btfsc  STATUS,Z      ; check for zero (index_in = index_out)
       goto  buffer_err    ; jump to error routine if zero
    ; Increment the index_in pointer and reset it if it's outside the ring buffer
       incf   _index_in,F   ; Increment index_in to index_in
       movf   _index_in,W   ; Move new index_in to W
       sublw  _buffer_size-1; Subtract index_in from buffer_size-1
       btfss  STATUS, C     ; If index_in => buffer_size
       clrf   _index_in     ; Clear index_in
    ; Set FSR with the location of the next empty location in buffer
       movlw    _buffer  ;Store the High byte of buffer to FSR
       movwf   FSR
       addwf   _index_in,W  ; Add index_in to point to next empty slot
       movwf   FSR        ; Store Low byte of pointer in FSR
    ; Read and store the character from the USART
       movf   RCREG,W       ; Read the received character
       movwf  INDF          ; Put the received character in FSR  location
       BTFSC  PIR1,RCIF     ;ANY MORE ?
       goto    myint
    finished
    ; Restore the state of critical registers (PIC12/PIC16)
       movf psave,W ; restore PCLATH
       movwf PCLATH
       swapf ssave,W ; restore STATUS
       movwf STATUS
       swapf wsave,F ; restore W (swap avoids changing STATUS)
       swapf wsave,W
       retfie ; Return from interrupt
    ; Error routines
    buffer_err              ; Jump here on buffer error
       bsf   _errflag,1     ; Set the buffer flag
    usart_err               ; Jump here on USART error
       bsf   _errflag,0     ; Set the USART flag
       movf  RCREG, W       ; Trash the received character
       goto finished       ; Restore state and return to program
    overint:
        TRISC = 0
        TRISB = % 10101111
        TRISA = % 11111110
        OSCCON = $70
        PAUSE 500
        hserout ["ready @19200"]
        LCDOUT $FE,1
        LCDOUT "ready @19200"
        PAUSE 500
    @  bsf   LCD_RSREG ,LCD_RSBIT
        INTCON = $C0
        PIE1.5 = 1
    GOSUB ERROR
       IF errflag Then GOSUB error ' Goto error routine if needed
       IF index_in = index_out Then main ' loop if nothing in buffer
       GoSub getbuf         ' Get a character from buffer
    '   hserout [bufchar]        ' Send the character to terminal
       if bl then
            if bufchar = 0 then
                 porta.0 = 0  ' Back Light OFF
            if bufchar = 8 then
                 porta.0 = 1 ' Back Light ON
            bl = 0
       if bufchar = 255 then
             bl = 1
       if bufchar = 254 then
    @  bcf   LCD_RSREG ,LCD_RSBIT
    @  MOVE?BB _bufchar,R3
    @  L?CALL lcdsend
    goto main             ' loop back to top
    error:                          ' Display error message
       INTCON = 0                   ' Disable interrupts while in the error routine
       IF errflag.1 Then            ' Determine the error
          hserout ["B!",13]' Display buffer error on line-2
       Else
          hserout ["U!",13]  ' Display usart error on line_2
       EndIF
       PIR1.5=0
       errflag = 0          ' Reset the error flag    ;clear any rcsta error
       RCSTA.4=0           'CREN = 0 Disable continuous receive to clear hardware error
       RCSTA.4=1           'CREN = 1 Enable continuous receive
       INTCON = %11000000   ' Enable interrupts
       RETURN         ' repeat
    getbuf:  ' Move the next character in buffer to bufchar
       index_out = index_out + 1     ' Increment index_out pointer (0 to 31)
       IF index_out => buffer_size Then index_out = 0 ' Reset pointer if outside buffer
       bufchar = buffer[index_out]  ' Read buffer location(index_out)
    Jan 2022
    ASM , very impressif code,
    thanks.
  9. #49
    Jan 2022
    here's the revised baud rate test chart
    Name:  Baud Rate Chart.jpg
  10. #50
    Tried different baud rate but still only Backlight work. The rest is just irrelevant characters on screen.
    Then tried the new code of Richards, but have 1827 chip, so asm code is not compatible.
    Gave up...
    Jan 2022
    maybe the chip?
    for my part I used
    12F683, 16F690 old regular Pic.
    I tried richard code, and it's impressive asm code, that I can't do for sure.
    so I stick to basic.
    when you're back on this LCD, try this 'self text' backpack for 16F690 maybe it will give a hint.
    ' Name  : 16F690 LCD BACKPACK  Self Text
    ' File  : "D:\PIC\PBP3\16F690\LCD BACKPACK\16F690 LCD BACKPACK Self Text.pbp"
    ' Date  : Oct 4-2025
    ' Serin2
    '#CONFIG
    '  __config  _INTRC_OSC_CLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    '#ENDCONFIG
     ' HSERIN
      __config  _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
    DEFINE OSC 20       ' Core is running at EXT-CRYSTAL 20MHz PBP 33,217
    'DEFINE OSC 8
    CM1CON0 = 0         ' Analog comparators off
    En var Portb.4 : low en
    RS var Portb.6 : low rs
    B1 var byte : b1 = 0
    C VAR BYTE : C = 100
    I VAR BYTE
    ' 1602
    ArrayA var Byte [16] : ARRAYWRITE ArrayA,["ABCDEF1234567890"] ' Line 1
    ArrayB var Byte [16] : ARRAYWRITE ArrayB,["1234567890!@#$%^"] ' Line 2
    ' 2004
    'ArrayC var Byte [20] : ARRAYWRITE ArrayC,["ABCDEF1234567890!@#$"] ' Line 1
    'ArrayD var Byte [20] : ARRAYWRITE ArrayD,["1234567890!@#$%^!@#$"] ' Line 2
    'ArrayE var Byte [20] : ARRAYWRITE ArrayE,["ABCDEF1234567890!@#$"] ' Line 3
    'ArrayF var Byte [20] : ARRAYWRITE ArrayF,["1234567890!@#$%^!@#$"] ' Line 4
    TRISA = 0 : TRISB = %00100000 : TRISC = 0
    PORTA = 0 : PORTB = 0 : PORTC = 0
    OSCCON = $70
    high Porta.0              ' Backlight ON
    gosub LCDinit             ' initialise LCD
    ' 1602
    Low RS : PORTC = 128 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 1
    For I = 0 To 15
        PORTC = ArrayA[I]
        Pause C
    Next I
    Low RS : PORTC = 192 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 2
    For I = 0 To 15
        PORTC = ArrayB[I]
        Pause C
    Next I
    ' 2004
    'Low RS : PORTC = 128 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 1
    'For I = 0 To 19
    '    PORTC = ArrayC[I]
    '    High En : PauseUS 1 : Low En
    '    Pause C
    'Next I
    'Low RS : PORTC = 192 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 2
    'For I = 0 To 19
    '    PORTC = ArrayD[I]
    '    Pause C
    'Next I
    'Low RS : PORTC = 148 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 3
    'For I = 0 To 19
    '    PORTC = ArrayE[I]
    '    Pause C
    'Next I
    'Low RS : PORTC = 212 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 4
    'For I = 0 To 19
    '    PORTC = ArrayF[I]
    '    Pause C
    'Next I
    Pause 1000
    Low RS : PORTC = 1 : High En : PauseUS 1 : Low En : High RS : PauseUS 4  ' Clear display
    Pause 500
    'Low PORTA.0      ' Bacck Light off
    Pause 200
    High PORTA.0     ' Bacck Light on
    Pause 200
    C = C - 20
    If C < 20 Then
    C = 100
    EndIf
    GoTo main
    LCDINIT:				  ' Standard LCD Module Initialisation
    PORTC = %00000001 : HIGH EN : PAUSEus 1 : LOW EN : pause 4 ' Clear Display
    PORTC = %00000010 : HIGH EN : PAUSEus 1 : LOW EN : pause 2 ' Return Home
    PORTC = %00111000 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' 8 bit, 2 line, 5x8 Characters
    PORTC = %00000110 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' Entry mode
    PORTC = %00001100 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' %00001DCB Display on/off, Cursor on/off, Blink y/n
    For a 1827 it would look like this [untested]
    ' Name  : 16F1827 LCD BACKPACK                                                *
    ' Date  : oct 2025    richard                                                 *
    ' Note  : RING BUFFERED                                                       *
    ' Notes : DEFA BAUD RATE 9600 Intrc_OSC 8Mhz                                  *
    '         eeprom full case is unhandled,factory reset would be advisable      *
      __config  _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config  _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_19 & _LVP_OFF
    ;commands eg   SEROUT2 lcd,84,[255,11]  set baudrate from 9600 to 19200
    '255 0/8  backlight
    '255 10/11/12  baud rate  9600/19200/38400
    '255 "F"  factory reset
        DEFINE OSC 8
        DEFINE WRITE_INT 1
        ANSELA = 0           ' Set all pins digital
        ANSELB = 0          ' Set all pins digital
        CLEAR
        DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
        DEFINE LCD_DREG PORTA	'defines the port where data lines are connected to
        DEFINE LCD_DBIT 4
        SP1BRG = 51    ' 19200 Baud @ 8MHz, 0.16%, 51 ' 9600 Baud @ 8MHz, 0.16%, 12 ' 38400 Baud @ 8MHz, 0.16%
        SP1BRGH = 0
        BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
        Bl               var byte
        inx              var byte
        Br               var byte
    myint
       movwf   FSR0
       movwf   FSR0        ; Store Low byte of pointer in FSR
       movwf  INDF0         ; Put the received character in FSR location
       goto    myint
    finished
    ; Error routines
    overint:
        TRISB = % 00101111
        TRISA = % 11110000
        OSCCON = $70
        PAUSE 500
        gosub getbaud
        PAUSE 5
        LCDOUT $FE,1
        hserout [13,"ready"]
        LCDOUT "ready "
        if br==51 then
          hserout ["@9600"]
          LCDOUT  "@9600"
        elseif br==25 then
          hserout ["@19200"]
          LCDOUT  "@19200"
          hserout ["@38400"]
          LCDOUT  "@38400"
        PAUSE 500
        GOSUB error
        INTCON = $C0
        PIE1.5 = 1
       if bl then
            if bufchar = 0 then
            if bufchar = 8 then
            if bufchar = 10 then
                 write inx+1,51
                 gosub getbaud
            if bufchar = 11 then
                 write inx+1,25
                 gosub getbaud
            if bufchar = 12 then
                 write inx+1,12
                 gosub getbaud
            if bufchar = "F" then
                 gosub factory
            bl = 0
             bl = 1
    @  L?CALL lcdsend
       Else
       EndIF
       RCSTA.4 = 0           'CREN = 0 Disable continuous receive to clear hardware error
       RCSTA.4 = 1           'CREN = 1 Enable continuous receive
    RETURN         ' repeat
    getbaud:
        bufchar = 0
        inx = 255
        read inx,Br
        while Br==255
            read inx,Br
            if  Br==255  then
                if inx == 0  then
                    br=51
                    write inx,51
                    hserout [13,"init@9600 " ,dec inx,",",dec Br]
                    inx = inx-1
        wend   ;note if inx=255 then eeprom full
        hserout [" index " ,dec inx,",",dec Br]
        SP1BRG = Br
    factory:
      write 0,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 16,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 32,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 48,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 64,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 80,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 96,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 112,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 128,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 144,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 160,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 176,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 192,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 208,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 224,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      write 240,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff,$ff
      gosub getbaud
    a bit out of practice , forgot porta.4 is input only plus 1827 has bits and pieces in other banks
    so tested and working version
    '255 0/8  backlight
    ;TX PORTB.2  RX PORTB.1 BACKLIGHT PORTB.0
        DEFINE OSC 8
        DEFINE WRITE_INT 1
    '    OPTION_REG.7 = 0    ' PORTA/PORTB pull-ups are enabled by individual port latch values
        CLEAR
        DEFINE LCD_DBIT 0
        SP1BRGH = 0
        Bl               var byte
        inx              var byte
        Br               var byte
    myint
       banksel RCSTA
       banksel 0
       movlw   High _buffer  ;Store the High byte of buffer to FSR0H
       movwf   FSR0H
       movlw   Low _buffer  ; Get the Low byte of buffer[0]
       movwf   FSR0L        ; Store Low byte of pointer in FSR0
       banksel RCREG
       banksel PIR1
       goto    myint
    finished
       RST?RP
    ; Error routines
       banksel  _errflag
       banksel RCREG
    overint:
        TRISB = %10101010
        TRISA = %11110000
        OSCCON = $70
        PAUSE 500
        gosub getbaud
        PAUSE 5
        LCDOUT $FE,1
        LCDOUT "ready "
        if br==51 then
          hserout ["@9600"]
          LCDOUT  "@9600"
        elseif br==25 then
          hserout ["@19200"]
          LCDOUT  "@19200"
          hserout ["@38400"]
          LCDOUT  "@38400"
        PAUSE 500
        GOSUB error
        INTCON = $C0
        PIE1.5 = 1
       if bl then
            if bufchar = 0 then
                 portB.0 = 0 ' Back Light OFF
            if bufchar = 8 then
                 portB.0 = 1 ' Back Light ON
                 write inx+1,51
                 gosub getbaud
                 write inx+1,25
                 gosub getbaud
                 write inx+1,12
                 gosub getbaud
                 gosub factory
            bl = 0
             bl = 1
    @  MOVE?CT 1,FLAGS ,0
    @  L?CALL lcdsend
       Else
       EndIF
    RETURN         ' repeat
    getbaud:
        bufchar = 0
        inx = 255
        read inx,Br
        while Br==255
            read inx,Br
            if  Br==255  then
                if inx == 0  then
                    br=51
                    write inx,51
                    inx = inx-1
        SP1BRG = Br
    factory:
      gosub getbaud
    Thanks Richard.
    The new code:
    1. works OK with LCD Backlight On/Off
    2. works OK sending text over the serial port
    3. works OK sending commands to LCD over serial port
    4. On power up LCD shows ready@38400 and this does not change. But the communication baud rate is 9600. With 255,10 or 11 or12 can change baud rate but it is not displayed on LCD. Though higher baud rates need pace.
    5. On power up the terminal shows ready@38400U!
    Have done two changes on port b to drive the RS and E signal on PortB.3 and PortB.4.
    PortB.1 is the RS-232 driver TX output from PIC
    PortB.2 is the RS-232 driver RX input to PIC
  15. #55
    Jan 2022
    Excellent news,,
  16. #56
    removed debug messages that are sent before spbrg set to correct value
    since 1827 has more resources have increased buffer size, u may not need pacing any longer to compensate for
    the 4 bit lcd interface being a bit slower
    baud rate is only shown on lcd at boot , setting is stored in eeprom
    '255 0/8  backlight
        DEFINE OSC 8
        DEFINE WRITE_INT 1
        CLEAR
        DEFINE LCD_DBIT 0
        SP1BRGH = 0
        buffer_size      CON 64                ' Sets the size of the ring buffer
        Bl               var byte
        inx              var byte
        Br               var byte
    myint
       banksel RCSTA
       banksel 0
       movwf   FSR0H
       banksel RCREG
       banksel PIR1
       goto    myint
    finished
       ;RST?RP
    ; Error routines
       banksel  _errflag
       banksel RCREG
    overint:
        TRISB = % 00101010
        TRISA = % 11110000
        OSCCON = $70
        PAUSE 500
        gosub getbaud
        PAUSE 5
        LCDOUT $FE,1
        LCDOUT "ready "
        if br==51 then
          hserout ["@9600"]
          LCDOUT  "@9600"
        elseif br==25 then
          hserout ["@19200"]
          LCDOUT  "@19200"
          hserout ["@38400"]
          LCDOUT  "@38400"
        PAUSE 500
        GOSUB error
        INTCON = $C0
        PIE1.5 = 1
       if bl then
            if bufchar = 0 then
                 portB.7 = 1 ' Back Light OFF
            if bufchar = 8 then
                 portB.7 = 0 ' Back Light OFF
                 write inx+1,51
                 gosub getbaud
                 write inx+1,25
                 gosub getbaud
                 write inx+1,12
                 gosub getbaud
                 gosub factory
            bl = 0
             bl = 1
    @  L?CALL lcdsend
          hserout [" Buffer overflow",13]' Display buffer error on line-2
       Else
          hserout [" Uart reset",13]  ' Display usart error on line_2
       EndIF
       INTCON = % 11000000   ' Enable interrupts
    RETURN         ' repeat
    getbaud:
        bufchar = 0
        inx = 255
        read inx,Br
        while Br==255
            read inx,Br
            if  Br==255  then
                if inx == 0  then
                    br=51
                    write inx,51
    '                hserout [13,"init@9600 " ,dec inx,",",dec Br]
                    inx = inx-1
    '    hserout [" index " ,dec inx,",",dec Br]
        SP1BRG = Br
    factory:
      gosub getbaud
    Great work Richard!
    Works very well. Thank you.
    I had to change LCD_COMMANDUS to 2000 from 1500 for best performance.
    I just did not understood what all these ff's at the end of the code do.
  18. #58
    not to be unexpected, the LCD timing defines need to match the display in use. some are very slow
    not pretty I agree but its one simple way to erase the eeprom at run time, hence "factory" as in factory reset
    Jan 2022
    one last update:
    added an PGM Sw on RA3
    to edit the baud rate:
    turn off the LCD display, press & hold the PGM sw, turn on the LCD
    line 1 will show "Press to Select" , line 2 : "Baud Rate:"
    release the sw and press it again to select next value (at this point the new value is save to EEPROM memory)
    when the desire value is reach, turn off the LCD and turn it on again at this point the LCD will display the baud rate on line 2
    and the display is ready to receive a clear LCD command, and data from the sender.
    As for different LCD module eg: 1601,1602,2004 1 line, 2 lines 4 lines etc.. the LCD commands is use to control position of the data on the screen.
    as of today the 1601, 1602, 2004 have been tested successfuly.
    DEFINE OSC 20                           ' Running @ 20MHz PBP 33,217
    ANSEL = 0 : ANSELH = 0                  ' Set all pins digital
    TRISA = 001000 : TRISB = 100000 : TRISC = 0 ' 0 = OUT, 1 = IN
    PORTA = 000001 : PORTB = 0 : PORTC = 0         ' 0 = Low  1 = High
    OSCCON = $78                            ' $78=External Xtal $70 = Internal
    BaudR var word                          ' Baud Rate word var
    En var Portb.4                          ' LCD Enable
    RS var Portb.6                          ' LCD Register Set
    B1 var byte                             ' Serial IN Byte
    Flag var bit                            ' Display Baud Rate on Power-up
    I VAR BYTE : II VAR BYTE : III VAR BYTE ' use in Set1
    read 0, word baudr,ii : pause 2         ' Read Baud Rate from EEPROM
    if ii < 0 or ii > 7 then
        baudr = 84 : ii = 3
        WRITE 0, Word baudr,ii : pause 2    ' Write to EEPROM
    ArrayA var Byte [65]
    ' Array index (III) 0    5    10   15   20   25   30   35   40~55           56~65
    ARRAYWRITE ArrayA,[" 1200 2400 4800 960014400192002880038400Press to Select:Baud Rate:"]
    gosub LCDinit                           ' Initialise LCD
    IF PORTA.3  = 1 THEN                    ' PGM Switch
        GOTO Set1
        flag = 1
        gosub set2
        serin2 Portb.5,baudr,3,main,[b1]    ' Serial IN
        if b1 < 253 then                    ' if Characters
            PORTC = b1
        elseif b1 = 254 then                ' if LCD Command
            low RS
            PORTC = b1                      ' output the data
            high RS                         ' character mode
        elseif b1 = 255 then                ' if Port Command
            if b1 = 0 then TOGGLE PORTA.0   ' Toggle Back Light OFF / ON
            if b1 = 1 then TOGGLE PORTB.7   ' Toggle PORTB.7 ON / OFF
            if b1 = 2 then TOGGLE PORTA.2   ' Toggle PORTA.2 ON / OFF
    PORTC = 000001 : HIGH EN : PAUSEus 1 : LOW EN : pause 4 ' Clear Display
    PORTC = 000010 : HIGH EN : PAUSEus 1 : LOW EN : pause 2 ' Return Home
    PORTC = 111000 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' 8 bit, 2 line, 5x8 Characters
    PORTC = 000110 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' Entry mode
    PORTC = 001110 : HIGH EN : PAUSEus 1 : LOW EN : Pause 2 ' 001DCB Display on/off, Cursor on/off, Blink y/n
    Set1: ' Baud Rate Selection and EEPROM Save at Power ON with Switch press
    PAUSE 10                               ' "Press to Select:"
    For I = 40 To 55
        PORTC = ArrayA[I]
        PAUSE 2
    Next I
    Set2:
    PAUSE 10                               ' "Baud Rate:"
    For I = 56 To 65
        PORTC = ArrayA[I]
        PAUSE 2
    Next I
    Set3:
    Low RS : PORTC = 203 : High En : PauseUS 1 : Low En : High RS : Pause 3 ' Line 2
    PAUSE 2       ' Index
    IF II = 0 THEN III = 0  : baudr = 813 ' 1200
    IF II = 1 THEN III = 5  : baudr = 396 ' 2400
    IF II = 2 THEN III = 10 : baudr = 188 ' 4800
    IF II = 3 THEN III = 15 : baudr = 84  ' 9600
    IF II = 4 THEN III = 20 : baudr = 49  ' 14400
    IF II = 5 THEN III = 25 : baudr = 32  ' 19200
    IF II = 6 THEN III = 30 : baudr = 15  ' 28800
    IF II = 7 THEN III = 35 : baudr = 6   ' 38400
    For I = III To (IIi + 4)
        PORTC = ArrayA[I]
        PAUSE 2
    Next I
    if flag = 1 then
        flag = 0 : return
    II = II + 1
    IF II > 7 THEN II = 0
    while PORTA.3 = 1                       ' Switch Press
    wend
    PAUSE 250
    while PORTA.3 = 0                       ' Switch Release
    wend
    pause 250
    GOTO set3
  20. #60
    Nov 2019
    Newhaven Display (newhavendisplay.com) offers a collection of 10 different character LCDs in 2x16, 2x20 and 4x20 formats that are exclusively serial inputs -- I2C, SPI and Async TTL -- and reasonably priced at $15 to $20 U.S. I have a couple of the 2x20's, and they work nicely in all 3 interface modes. Nevertheless, this is a very interesting project as I (like everyone else) have a drawer full of parallel interface HD44780 type LCDs that will be put to better use with this serial interface. Many thanks, and I'll provide you feedback if I have anything useful to contribute.
  1. Using 16F1503 as Serial LCD Backpack
    Last Post: - 11th March 2015, 19:58
  2. 16F877A and LCD HD44780
    By epilot in forum mel PIC BASIC Pro
    Last Post: - 1st November 2013, 18:17
  3. FREE Serial LCD Backpack Board
    By rmteo in forum Off Topic
    Last Post: - 29th July 2010, 02:32
  4. Lcd Hd44780
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 14:04
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 16:52
Members who have read this thread : 16
