serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
+ Reply to Thread
Results 1 to 2 of 2
    Jan 2022
    Default serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
    Hello everyone,
    I'de like to share this project, may come handy for hobbyist working around LCD display.
    My search for a serial LCD that can receive serial data from 300 to 19200 baud on the internet was not successful
    then I roll-up my sleeves and build this LCD backpack that use a common Hitachi HD44780 display. (still popular today)
    My project was simple with parts already on hand like PIC16F690, NPN smd transistor, potentiometer, resistor. and PBP3 Basic code.
    So enjoy,
    '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Name  : 16F690 LCD BACKPACK
    ' Date  : Sep 27-2025
    ' Note  : 393 words used  of 2048
    ' Notes : Serin2 Baud Rate 300 ~ 19200 Intrc_OSC 8Mhz
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_OFF
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_OFF
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_OFF
    cfg&= _IESO_OFF
    cfg&= _FCMEN_OFF
      __CONFIG cfg
    DEFINE OSC 8        ' Core is running at EXT-CRYSTAL 16MHz PBP 33,217
    ANSEL = 0           ' Set all pins digital
    ANSELH = 0          ' Set all pins digital
    OPTION_REG.7 = 0    ' PORTA/PORTB pull-ups are enabled by individual port latch values
    CM1CON0 = 0         ' Analog comparators off
    En var Portb.4 : low en
    RS var Portb.6 : low rs
    B1 var byte : b1 = 0
    ' 300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
    BaudR var byte : baudr = 32
    TRISA = 0 : TRISB = 100000 : TRISC = 0
    PORTA = 0 : PORTB = 0 : PORTC = 0
    OSCCON = $70
    high Porta.0              ' Backlight ON
    gosub LCDinit             ' initialise LCD
    'Serin2
        serin2 Portb.5,baudr,3,main,[b1]
        if b1 < 253 then     ' Characters
            PORTC = b1
            HIGH EN : PAUSEus 5 : LOW EN
        elseif b1 = 254 then  ' LCD Command
            low RS
            PORTC = b1          ' output the data
            high RS           ' character mode
        elseif b1 = 255 then
            low rs            ' LCD Command
            if b1 = 0 then
                low porta.0   ' Back Light OFF
            high rs
            if b1 = 8 then
                high porta.0  ' Back Light ON
            high rs
           goto main             ' loop back to top
    LCDINIT:                  ' Standard LCD Module Initialisation
    PORTC = 000001          ' 2, Clear Display
        HIGH EN : PAUSEus 300 : LOW EN ' Send data
        pause 4
    PORTC = 000010          ' 4, Return Home
        pause 4
    PORTC = 111000         ' 1, 8 bit, 2 line, 5x8 Characters
        pause 4
    ' PORTC = 001100          ' Display on, no cursor, no blink
    PORTC = 001110          ' 1, Display on, cursor, blink
        pause 4
    PORTC = 000110          ' 1, Entry mode
        pause 4
        high rs                  ' character mode
    Jan 2022
    Default Re: serial LCD 1602 Backpack using PIC16F690 for Hitach HD44780
    Here's an code update
    on the LCD backpack code the line
    BaudR var byte should be replace with: BaudR var Word
    and here's the serial sender code updated as well. (use an 12F683)
    'Project : 12F683 Serial LCD Test 300 ~ 19200 baud for 16F690 Lcd Backpack
    'Date    : Sep 27-2025
    'Notes   : 285 words used  of 2048
    'Notes   : Serout2 300 ~ 19200  Intrc_OSC 8Mhz
    '300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
     __config  _INTOSCIO & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOD_OFF  & _CP_OFF & _CPD_OFF
    LCD Var GPIO.0         ' Serial out
    ANSEL = 0              ' Set all digital  PULLUP Resistor  page:10
    TRISIO = %00000000     ' INPUT=1 OUTPUT = 0
    OSCCON = $70           ' $70=8Mhz  $60=4mhz  $50=2MHZ  $40=1MHZ  $30=500KHZ
    BaudR var word
    baudR = 32 ' 300=3313  600=1646  1200=813  2400=396  4800=188  9600=84  19200=32
    Pace var byte          ' for serout2
    pace = 0
    SEROUT2 lcd,baudR,pace,[ 254, 1] ' Clear LCD
    pause 40
    DO
    ' LCD 1602
        sEROUT2 lcd,baudR,pace,[254,128,"ABCDEFGHIJKLMNOP"] ' Line 1 16 Char.
        SEROUT2 lcd,baudR,pace,[254,192,"0123456789-=,./>"] ' Line 2 16 Char.
    ' LCD 2004
        'SEROUT2 lcd,BaudR,pace,[254,128,"ABCDEFGHIJkLMNOPQRST"] ' Line 1 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,192,"0123456789-=,./;!@#$"] ' Line 2 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,148,"ABCDEFGHIJkLMNOPQRST"] ' Line 3 20 Char.
        'SEROUT2 lcd,BaudR,pace,[254,212,"0123456789-=,./;!@#$"] ' Line 4 20 Char.
        PAUSE 2000
        SEROUT2 lcd,baudR,pace,[ 255, 0] ' Back Light OFF
        PAUSE 200
        SEROUT2 lcd,baudR,pace,[ 255, 8] ' Back Light ON
        PAUSE 2000
    LOOP
  1. Using 16F1503 as Serial LCD Backpack
    Last Post: - 11th March 2015, 19:58
  2. 16F877A and LCD HD44780
    By epilot in forum mel PIC BASIC Pro
    Last Post: - 1st November 2013, 18:17
  3. FREE Serial LCD Backpack Board
    By rmteo in forum Off Topic
    Last Post: - 29th July 2010, 02:32
  4. Lcd Hd44780
    By alaaodeh in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 14:04
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 16:52
