I'm also stuck with FSR error when using DT's elapsed timer on 16F1936
+ Reply to Thread
Results 1 to 4 of 4
    Default I'm also stuck with FSR error when using DT's elapsed timer on 16F1936
    No MIBAM this time
    I tried to use original files, but they got that error, then I found this post:
    https://www.picbasic.co.uk/forum/sho...=elapsed+timer
    tried code from it, but it won't compile, since 16F1936 does not have Timer 3, it has timer 1-2-4-6.
    So as I understand, I should modify that code and change all references to timer3 to another timer. But which one to choose?
    Default Re: I'm also stuck with FSR error when using DT's elapsed timer on 16F1936
    why timer3 ?
    any timer that can provide a 10mS interrupt could be employed, the self configuring aspect of the code will not function for modern pic chips. the code will need a tickle to adapt it to valid timer settings for your chosen chip
    what have you tried ?
    I don'know - author on the link above used timer3.
    I guess, mechanically changing it to timer1 or 2 won't work, since there's some ASM code involved...
    if you don't try you will never know
  1. Replies: 18
    Last Post: - 6th October 2024, 23:54
  2. DT Elapsed Timer
    Last Post: - 14th December 2017, 23:21
  3. PBP, 16F1827, FSR, and Error 113
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 13th January 2014, 09:04
  4. Compiling error on Elapsed timer
    By tacbanon in forum General
    Last Post: - 9th September 2012, 13:09
  5. DT Elapsed Timer
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:17
Members who have read this thread : 10
