Connecting 24vdc power supply to 110vac
+ Reply to Thread
Results 1 to 9 of 9
    Default Connecting 24vdc power supply to 110vac
    110vac here in Québec has black and white wires. Which is N, which is L?
    Default Re: Connecting 24vdc power supply to 110vac
    Hmm, won't let me edit.
    I assume L is load (black wire connected to breaker), N is neutral (white wire to common bus bar).
    Just wanna make sure.
    in general... in US and I see in Canada..... L is for live or line..........(ps... don't kill yourself, or your dog)
    Quick Answer: What Does N and L Mean in Wiring?
    L (Line / Live / Hot): The conductor that carries voltage from the power source to your device. It can cause electric shock if touched.
    N (Neutral): The return path that completes the circuit back to the source. In the U.S., neutral is bonded to ground at the main service but must be kept isolated from ground on branch circuits and subpanels.
    It really doesn't matter as long as you connect 110V across the L & N connections.
    Here in Sweden, we use Schucko connectors for 230V outlets and they're not polarised so depending on which way around you insert the plug live/neutral would be switched. The connected load doesn't care one bit and it doesn't make any difference. Some audiophools might not agree but lets not go there.
    Now, with 3-phase it's obviously another story but that's not the case here.
    really really bad advice
    It really does matter how you connect 110V across the L & N connections if you live in a country that has a grounded neutral. while your device may function either way, there is no guarantee any of the safety devices employed in it still will and any poor sucker who comes along later to service the unit might get a rather nasty or fatal surprise due to an active neutral swap.
    if you don't know don't mess with it .
    Neutral and ground/earth are of course bonded here, in fact the incoming feed is usually 4-wire, three phases and a combined neutral/earth conductor (TN-C).
    Again, there is absolutely NO WAY I can/could make sure that neutral will in fact be connected to N on single phase device that's meant to be plugged into an outlet since it depends on which way around the user inserts the plug. It makes zero practical difference for the device.
    Now, if you DO have a polarised connector then there are benefits of doing "it right", if you have a single phase switch for example you are certain that you're breaking the phase so the device is safe - not that I recommend relying on it of course.
    Show me a single phase device that doesn't work or becomes dangerous if you swap L & N.
  1. 12bit Power Supply
    By ztoti in forum Adverts
    Last Post: - 16th October 2014, 00:29
  2. power supply help ?
    By iugmoh in forum Schematics
    Last Post: - 27th February 2009, 21:01
  3. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 08:07
  4. Transformerless Power Supply
    By volkov in forum General
    Last Post: - 3rd July 2006, 00:13
  5. OT - power supply problem
    Last Post: - 2nd March 2006, 01:14
Members who have read this thread : 8
