Calculating base resistor on mosfet AO3400A
Results 1 to 6 of 6
Threaded View
  1. #5
    Default Re: Calculating base resistor on mosfet AO3400A
    Richard brings up an important point about the PIC's drive current capacity. I'll use 10mA in my calculations.
    R = V / I
    = 5 / 0.010
    = 500
    P = V * I
    = 5 * 0.010
    = 0.050 W (just to confirm resistor package at JLCPCB)
    Qg = 6 nC
    Ig = 10 mA
    t = 0.000 000 006 / 0.010
    = 0.000 000 6
    0.6 uSec is not a problem for my application. I just want to activate a solenoid long enough to properly activate a limit switch, then let if fall back using the built-in return spring.
    The specs for Qg on the AO3400A use:
    - Vgs = 4.5V
    - Vds = 15V
    - Id = 5.7A
    I'm nowhere near that with only Vds 8.5V at 1A max.
  1. Replies: 8
    Last Post: - 20th March 2017, 09:34
  2. Code for WWVB time base
    By gmglickman in forum mel PIC BASIC Pro
    Last Post: - 12th March 2014, 19:37
  3. Calulating BJT base resistance for PIC led switching?
    Last Post: - 20th November 2008, 08:41
  4. Tristated output to two common Base transistor issue
    Last Post: - 14th September 2007, 14:35
  5. Is there a way to expand the base bootloader program?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 15th June 2005, 15:24
Members who have read this thread : 9
