NE555 with solenoid
Results 1 to 4 of 4
Threaded View
    Default NE555 with solenoid
    I'd like to activate a solenoid for a brief moment. Does this timer look correct?
    Name:  NE555 monostable.png
    - I added a large cap alongside the solenoid; value is just preliminary.
    - the opto is to isolate the solenoid, it will be on a separate 5V line.
    - the 10K pot is just to start, I'll bump up to 25K if 110ms is not enough time.
    The solenoid will eventually be driven by a PIC, this is only for testing purposes (like figuring out exactly how much correct this thing consumes, how short a pulse of 5V it will accept - I have no datasheet).
    Never having used a solenoid before, a quick touch of wire makes it pulse several times. I assume it's normal that it cycles non-stop if I leave it connected - I figure it's the coil charging and discharging.
    It's one of these tiny 5V solenoids:
    https://www.aliexpress.com/item/1005002278950915.html
  1. IR trasmitter using PIC 16F84 and NE555
    By tonixxx in forum mel PIC BASIC
    Last Post: - 27th December 2012, 00:55
  2. PIC16F690 with NE555
    Last Post: - 3rd October 2008, 09:40
Members who have read this thread : 5
