InfraRed ramblings
+ Reply to Thread
Results 1 to 9 of 9
    Default Re: InfraRed ramblings
    Search optical interrupter. These are used often for homing.
    https://www.amazon.ca/s?k=optical+in...ref=nb_sb_noss
    ARGH! That's what they're called. I knew these existed, I just didn't know their names.
    You can also use a hall effect IC and a small magnet. The hall effect ic's come in a 3 pin TO-92 package and are easy to interface to your micro.
    For example
    https://dronebotworkshop.com/stepper-motor-hall-effect/
    Thanks Mark!
    I was considering laying a limit switch flat along the outer edge of the disk, and use a notch to catch the limit switch roller. But I'm liking the hall sensor even more:
    - no moving parts,
    - impervious to dirt or light seepage,
    - can sit directly on the PCB,
    - lower cost,
    - and waaaay less bulky.
    Going to try this hall sensor:
    https://www.digikey.ca/en/products/d...ULPGM/12165112
    And these magnets:
    https://www.digikey.ca/en/products/d...c/8189/5400498
    I bought some of those stepper motors you linked above. Really cheap, small with a gearbox, but be aware they are wired so you cannot use them with a standard stepper driver module. These have five leads (4 phases and a common) so your micro must generate four phases to make it run. It is easier to use a step and direction driver like the one in the hall effect video. I was able to modify the motors to run on a standard driver using this info.
    https://forum.arduino.cc/t/howto-mod...-4wire/1132680
    Yeah, these are unipolar steppers, not bipolar.
    I'm using the ULN2003 as driver that came with them. I'll be switching to a ULN2803 for my use.
  1. InfraRed communication
    By Alexey in forum General
    Last Post: - 15th February 2020, 05:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 15:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 18:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 05:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 16:35
Members who have read this thread : 9
