InfraRed ramblings
+ Reply to Thread
Results 1 to 9 of 9
    Default InfraRed ramblings
    Using this 940nm LED set on Amazon: https://www.amazon.ca/dp/B01HGIQ8NG
    Can I have the transmitter LED on without any pulsing? (resistor values are temporary, did not do any calculations yet)
    Name:  IR schematic.png
    This circuit was inspired by this tutorial: https://www.instructables.com/Intro-to-IR-Circuits/
    I just want to detect a hole in a disk; no communication.
    Examples on google often use 38kHz or 56kHz, but their receiver has 3 pins; VDD, VSS and DAT. That leads to me to believe there's more going on in that receiver.
    This guy has a really nice way to calculate the values:
    Default Re: InfraRed ramblings
    if there is any ambient light leakage a ir sensor like SEN-19018 would be better than a photo diode, with the bonus of making
    led modulation unnecessary too.
    if the distance between led and sensor is small [under 10mm] then you only need a small current through led 5 to 20 mA
    would be heaps
    There will be minimal light leakage. These will be on either side of a disk, as close as I can get them.
    I plan on putting black heatshrink over the LEDs as close as I can to the rotating disk.
    This will be used as a way to home a stepper (fuel gauge on a flight sim); I need to find 0 easily. I'm sure there as more precise techniques, but I'm looking for a simple low-cost solution that works.
    I was planning on using these steppers: https://www.amazon.ca/dp/B0CPSLS944
    Search optical interrupter. These are used often for homing.
    https://www.amazon.ca/s?k=optical+in...ref=nb_sb_noss
    ARGH! That's what they're called. I knew these existed, I just didn't know their names.
    You can also use a hall effect IC and a small magnet. The hall effect ic's come in a 3 pin TO-92 package and are easy to interface to your micro.
    For example
    https://dronebotworkshop.com/stepper-motor-hall-effect/
    Thanks Mark!
    I was considering laying a limit switch flat along the outer edge of the disk, and use a notch to catch the limit switch roller. But I'm liking the hall sensor even more:
    - no moving parts,
    - impervious to dirt or light seepage,
    - can sit directly on the PCB,
    - lower cost,
    - and waaaay less bulky.
    Going to try this hall sensor:
    https://www.digikey.ca/en/products/d...ULPGM/12165112
    And these magnets:
    https://www.digikey.ca/en/products/d...c/8189/5400498
    I bought some of those stepper motors you linked above. Really cheap, small with a gearbox, but be aware they are wired so you cannot use them with a standard stepper driver module. These have five leads (4 phases and a common) so your micro must generate four phases to make it run. It is easier to use a step and direction driver like the one in the hall effect video. I was able to modify the motors to run on a standard driver using this info.
    https://forum.arduino.cc/t/howto-mod...-4wire/1132680
    Yeah, these are unipolar steppers, not bipolar.
    I'm using the ULN2003 as driver that came with them. I'll be switching to a ULN2803 for my use.
  1. InfraRed communication
    By Alexey in forum General
    Last Post: - 15th February 2020, 05:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 15:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 18:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 05:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 16:35
Members who have read this thread : 8
