not really they all are running the same pulse width with different freq.I ran your program and according to the scope they all are running the same freq. with different pulse width
Well, I don't know what to say. I get all the same frequency with different pulse width.
Even the program shows different pulse width.
I even went back to the pick basic plus and i'm running for with four different timers, and they all run the same frequency, and if you set it for a different frequency, they shut down pulse width, I can control
what do you mean ,that makes little senseEven the program shows different pulse width.
my code works perfectly on the simulator and the actual hardwareWell, I don't know what to say. I get all the same frequency with different pulse width.
post your code and schematic .
Walking and talking on the phone does not work well.
I ran your program my scope has measure function all 3 channels showed the same frequency. But the duty cycle was the only difference. I used pbp setting ccp1, ccp2, ccp3 and ccp5 port c1, c2, and port b0, b5 there is also no control of individual frequency only duty cycle
If you don't get three frequencies with 50% duty cycle then you are not using my code ,chip or schema.
Post your code and schema
I will rerun tomorrow and post scope pictures. Its
definitely possible. I did something wrong. I am only running at 40 MHz. At this time, I have 16 mhz crystal's coming.
totally not needed for this simple test, it uses internal oscI have 16 mhz crystal's coming.
