K42 and Timer Interrupts
+ Reply to Thread
Results 1 to 9 of 9
    Default K42 and Timer Interrupts
    I wonder if anyone managed to work with DT-INTS18 with the K42 series chips.
    The latest DT_INTS-18_K42c.bas file that tumbleweed posted (on this closed thread https://www.picbasic.co.uk/forum/sho...=interrupt+k42) never compiled for me.
    The erros I get are:
    [ASM ERROR] Symbol not previously defined (INT_ENTRY_H) (0) : Error[113]
    [ASM ERROR] Symbol not previously defined (INT_ENTRY_L) (0) : Error[113]
    Would like to use Timer 1 interrupts for housekeeping.
    Default Re: K42 and Timer Interrupts
    sheldon sent me these for a project i was assisting with. it all seemed to work
    Thanks Richard.
    Tried the files and indeed it worked OK. Sort off...
    I tried to setup the Timer 0 as 16bit timer, cloked by Fosc/4 with system clock at 64MHz.
    Reload value $C187
    The toggle happens every 4 seconds instead of 1sec. Cannot see my error.
    Have checked the OSCFRQ value and it read as $08.
    This is the test code:
    'PIC18F47K42
        CONFIG FEXTOSC = OFF                ;Oscillator not enabled
        CONFIG RSTOSC = HFINTOSC_64MHZ      ;HFINTOSC with HFFRQ = 64 MHz and CDIV = 1:1
        CONFIG CLKOUTEN = OFF               ;CLKOUT function is disabled
        CONFIG PR1WAY = OFF	    ;PRLOCK bit can be set and cleared repeatedly
        CONFIG CSWEN = ON	    ;Writing to NOSC and NDIV is allowed
        CONFIG FCMEN = ON	    ;Fail-Safe Clock Monitor enabled
        CONFIG MCLRE = INTMCLR	    ;If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR
        CONFIG PWRTS = PWRT_64	    ;PWRT set at 64ms
        CONFIG MVECEN = OFF	    ;Interrupt contoller does not use vector table to prioritze interrupts
        CONFIG IVT1WAY = OFF	    ;IVTLOCK bit can be cleared and set repeatedly
        CONFIG LPBOREN = OFF	    ;ULPBOR disabled
        CONFIG BOREN = ON	    ;Brown-out Reset enabled according to SBOREN
        CONFIG BORV = VBOR_245	    ;Brown-out Reset Voltage (VBOR) set to 2.45V
        CONFIG ZCD = OFF	    ;ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON
        CONFIG PPS1WAY = OFF	    ;PPSLOCK bit can be set and cleared repeatedly (subject to the unlock sequence)
        CONFIG STVREN = ON	    ;Stack full/underflow will cause Reset
        CONFIG DEBUG = OFF	    ;Background debugger disabled
        CONFIG XINST = OFF	    ;Extended Instruction Set and Indexed Addressing Mode disabled
        CONFIG WDTCPS = WDTCPS_31	    ;Divider ratio 1:65536; software control of WDTPS
        CONFIG WDTE = SWDTEN	    ;WDT enabled/disabled by SWDTEN bit
        CONFIG WDTCWS = WDTCWS_7	    ;window always open (100%); software control; keyed access not required
        CONFIG WDTCCS = LFINTOSC	    ;WDT reference clock is the 31.0 kHz LFINTOSC
        CONFIG BBSIZE = BBSIZE_512	    ;Boot Block size is 512 words
        CONFIG BBEN = OFF	    ;Boot block disabled
        CONFIG SAFEN = OFF	    ;SAF disabled
        CONFIG WRTAPP = OFF	    ;Application Block not write protected
        CONFIG WRTB = OFF	    ;Configuration registers (300000-30000Bh) not write-protected
        CONFIG WRTC = OFF	    ;Boot Block (000000-0007FFh) not write-protected
        CONFIG WRTD = OFF	    ;Data EEPROM not write-protected
        CONFIG WRTSAF = OFF	    ;SAF not Write Protected
        CONFIG LVP = OFF	    ;HV on MCLR/VPP must be used for programming
        CONFIG CP = OFF	    ;PFM and Data EEPROM code protection disabled
    DEFINE OSC 64
    Include "c:\users\pikst\desktop\coil\DT_INTS-18xv.bas"
    Include "c:\users\pikst\desktop\coil\ReEnterPBP-18xv.bas"
    'Include "c:\users\pikst\desktop\coil\ReEnterPBP-18xvLP.bas"
    ' Congigure I/O Digital/Analog ********************************
    ANSELA = %00000011  ' RA0, RA1 analog, other PORTA digital
    ANSELB = %00000000  ' PORTB digital
    ANSELC = %00000000  ' PORTC digital
    ANSELD = %00000000  ' PORTD digital
    ANSELE = %00000000  ' PORTE digital
    LATA = %00000000
    LATB = %00001010
    LATC = %00000000
    LATD = %00000000
    LATE = %00000000
    TRISA = %00000011
    TRISB = %00000000
    TRISC = %00110000
    TRISD = %00000000
    TRISE = %00000000
    ;           ADC Settings
    Define ADC_BITS     12  ' Set number of bits in result
    ADCON0 = %00010100   ' ADC clock = internal RC, right-justify ADC results in ADRES
    'ADCON1=%10110000
    'ADCON2=%00000000
    '    Timer0 Setup
    T0CON0=%00010000    'Timer 0 set as 16bit timer
    T0CON1=%01000000    'Timer 0 clock source Fosc/4
    Timer0  var T0CON0.7'Timer Enable bit
    TMR0L=$80  'Load Timer 0 with start value $C180
    TMR0H=$C1  'to count up 16000 steps until rollover
    'Timer0 Setup end ********************************************
    adval   Var word    ' Create adval to store result
    temp    var word
    temp1   var word
    tempb   var byte
    seconds var word
    goto over_ISR
    Timer0_ISR:         'Timer 0 overflow interrupt every 1msec
        if seconds<1000 then
            seconds=seconds+1
            seconds=0
            Timer0=0    'Stop timer0
            TMR0L=$87   'Load Timer 0 with start value $C187
            Timer0=1    'Start timer0
            toggle portc.5
    @ INT_RETURN
    over_ISR:
            INT_Handler     TMR0_INT,    _Timer0_ISR, PBP,    yes
        INT_CREATE
    @ INT_ENABLE  TMR0_INT
    Timer0=1    'start timer 0
    mainloop:
        Goto  mainloop        ' Do it forever
    looks like not reloading the tmr count every ms....... after first int, tmr counter looping from 0 .....???
    Aug 2011
    Two things...
    Since you're using FOSC/4 as the source, set ASYNC bit in T0CON1.
    Also, when using 16 bit mode (MD16=1) you should always write TMR0H then TMR0L in that order so that the high byte is latched.
    Sure it is. Inside the ISR, Timer 0 is stopped, reloaded and restarted.
    Two things...
    I think is it obligatory to use Fosc/4. Unless I misunderstood the DS. Then why is it necessary to use ASYNC=1? Could not fine any notes on the DS.
    Same for TMR0H. Is it in the DS this?
    Thank you for the suggestions, will test them the soonest.
    Aug 2011
    The SYNC block uses FOSC/4 as its sync clock, so it's difficult to use it if it's using FOSC/4 as its input source for counting too.
    for 16-bit read/write see sec 20.1.1.1:
    In 16-bit mode the operations should be: write TMR0H, TMR0L and read TMR0L, TMR0H
    Thanks for the explanation.
    I misinterpreted these paragraphs. My understanding was to have ASYNC cleared and use Fosc/4.
  1. Timer Interrupts
    By gadelhas in forum General
    Last Post: - 19th August 2011, 17:00
  2. fast timer block other interrupts?
    By flipper_md in forum mel PIC BASIC Pro
    Last Post: - 9th November 2010, 03:06
  3. Handling External/Timer Interrupts
    By Tacky3000 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 12:09
  4. 3 Timer Interrupts Running simultaneously
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 20th February 2007, 04:49
  5. Timer overflows and interrupts
    By barkerben in forum General
    Last Post: - 18th December 2004, 02:42
Members who have read this thread : 15
