RC5 Transmitter
Results 1 to 7 of 7
Thread: RC5 Transmitter
    Feb 2005
    Default RC5 Transmitter
    Hi all!
    After trying to build RC5 InfraRed Transmitter for a week
    i'm quite frustrated.
    I'll be much obliged if anyone could help me with it.
    Better are your chance to have an answer if you provide all the details
    code
    pic used
    schematic
    some beer
    Apr 2004
    Default RC5 transmitter
    John,
    Have a look here: http://www.picbasic.nl/indexes_uk.htm
    It's the site from a guy who made some RC5 applications.
    The programs are written with Proton Plus so the timing, which is quite important in RC5, might not be correct.
    I tried some of the apps. with the PBP compiler and it didn't work.
    However when I tried a test version of Proton it worked.
    So remember timing issues are to be solved when using PBP.
    Post
    I ripped the interesting parts from a working program. It transmits RC5 codes via an IRLED, modulation is 38.5kHz. Not exactly 38kHz but close enough. There are loads of information on the net regarding addresses, commands and all the rest you need to know about RC5.
    This link seems to cover just about all you need to know.
    http://info.fuw.edu.pl/~pablo/s/opis...dge/ir/rc5.htm
    Have fun.
    /Ingvar
    SendIRword      VAR WORD
    SendIRcommand   VAR BYTE
    SendIRaddr      VAR BYTE
    SendIRtoggle    VAR BIT
    SendIRbit       VAR BIT
    Counter         VAR BYTE
    SendIRpin       VAR PortB.0 'connect IRLED via resistor to ground
    LOW SendIRpin
    Send_IR:
        SendIRword = %0000000000000110
        SendIRword = (SendIRword + SendIRtoggle) << 5
        SendIRword = (SendIRword + SendIRaddr) << 6
        SendIRword = (SendIRword + SendIRcommand)
        FOR bitcounter = 13 TO 0 STEP -1
            SendIRbit = ~(SendIRword.0(bitcounter))
            GOSUB ToggleSendPin
            SendIRbit = SendIRword.0(bitcounter)
            GOSUB ToggleSendPin
        NEXT
        SendIRpin = 0
    ToggleSendPin:
        IF SendIRbit THEN
            FOR Counter = 1 TO 34
                SendIRpin = 1
                nop
                nop
                nop
                nop
                nop
                nop
                nop
                nop
                SendIRpin = 0
                nop
                nop
                nop
                nop
                nop
                nop
                nop
                nop
            NEXT
            PAUSEUS 875
    Quote Originally Posted by jrt4fun
    John,
    TIP OF THE DAY: never trust anybody else than you
    paramotor's Avatar
    paramotor Guest
    assembly code for RC5 TX
    RC5 TX
    aloncha's Avatar
    aloncha Guest
    Paramotor, could you send to me that RC5 TX code?
    [email protected]
    Thanks a lot!!!
  1. RC5 code for infrared receiver
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 11th January 2017, 13:34
  2. transmitter receiver help
    By Deorge M in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 08:17
  3. Replies: 1
    Last Post: - 9th February 2009, 23:40
  4. Replies: 23
    Last Post: - 23rd September 2008, 19:20
  5. RC5 decode on a 10F + Question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 11th September 2008, 09:20
