HC-05 Bluetooth
Results 1 to 4 of 4
Thread: HC-05 Bluetooth
    Mar 2025
    Default HC-05 Bluetooth
    I'm trying to interface an HC-05 Bluetooth module with my microcontroller using PicBasic, but it doesn’t seem to respond to AT commands. I’ve double-checked the baud rate and wiring. Has anyone encountered this issue before?
    Default Re: HC-05 Bluetooth
    happens frequently.
    usual causes :-
    the code you did not post is no good.
    the device is wired incorrectly. ie not as per the schematic you did not post
    the power supply is inadequate.
    the device has been damaged by poor handling.
    a little elementary and you may already know....... are you using the 'escape sequences?' and, with a usb to serial thingy, you can address the 05 from the serial side
    Miami, Florida USA
    I found out the hard way that not all HC-05 modules work the same. Use the version AT command and look for modules with the latest firmware versions. Try to establish a serial communication first with a serial communication app.
    Anonymous
  1. Bluetooth HC-05 Question
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 24th September 2020, 21:04
  2. Bluetooth HC-05 Parity
    By brainless in forum Bluetooth
    Last Post: - 26th June 2018, 16:31
  3. Bluetooth headset for non bluetooth devices?
    By Normnet in forum Bluetooth
    Last Post: - 26th September 2015, 11:22
  4. Help with bluetooth...
    By mbox in forum Bluetooth
    Last Post: - 8th October 2009, 06:16
  5. Bluetooth
    By Beavis in forum General
    Last Post: - 16th January 2006, 10:19
