Internal OSC vs Extenal
Results 1 to 5 of 5
    Mar 2025
    Quebec, Canada
    Default Internal OSC vs Extenal
    Hi ! I was wondering if some of you simply ditch the external resonator for the internal clock. On the newer PIC are they more reliable/useful ?
    Thank you !
    Default Re: Internal OSC vs Extenal
    Yes, whenever possible - which is most of the time. YMMV.
    I used to use crystals, preferably 20-40MHz way back when (10-15 years).
    But today, internals at max speed all the time.
    Unless you need the utmost critical timing.
    For any other application, even USART at 115Kbps, internal HS Osc works just fine.
    Mar 2025
    Quebec, Canada
    Thank you all !
    I will be using the internal clock for now on. But keeping the external in the design, just in case.
  1. About PIC internal OSC...
    By matto1 in forum General
    Last Post: - 25th September 2011, 00:10
  2. 18F2450 internal osc
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 7th February 2011, 13:32
  3. Internal OSC, how to?
    By PICante in forum mel PIC BASIC Pro
    Last Post: - 7th January 2008, 00:03
  4. Internal Osc help
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 12th January 2007, 20:50
  5. 16F628 with internal OSC
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 26th September 2004, 12:19
